I get this same error as well.
Iām not sure if it will fix it for you, but try just using the following in your wink.cfg
auth_service=delegated
auth_service_token=<token from herokuapp>
You should only need the Wink App ID and Wink App Secret if you are not using the herokuapp.
Joel
You donāt need both. If you use delegated, then all you need to do is authenticate with the heroku app and then use the token in your config. I would guess there is some other issue going on. Suggest clearing the tmp and cache folders on openhab and restarting openhab.
S.
Thank you Shawn. I appreciate youāre attempting to help me. Iāve tried restarting, clearing the tmp and cache folders, and also removing/re-adding the Wink Hub 2, and still experience the same issue on Device Discovery.
2018-07-08 16:19:58.889 [WARN ] [eclipse.jetty.servlet.ServletHandler] -
javax.servlet.ServletException: org.glassfish.jersey.server.ContainerException: java.lang.IncompatibleClassChangeError: Expected static field org.openhab.binding.wink.internal.discovery.WinkDeviceDiscoveryService.scheduler
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:489) [167:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) [167:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) [167:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) [167:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) [167:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) [15:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:848) [85:org.eclipse.jetty.servlet:9.3.21.v20170918]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:584) [85:org.eclipse.jetty.servlet:9.3.21.v20170918]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [183:org.ops4j.pax.web.pax-web-jetty:6.0.9]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) [82:org.eclipse.jetty.security:9.3.21.v20170918]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1180) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:284) [183:org.ops4j.pax.web.pax-web-jetty:6.0.9]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:512) [85:org.eclipse.jetty.servlet:9.3.21.v20170918]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1112) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [183:org.ops4j.pax.web.pax-web-jetty:6.0.9]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.Server.handle(Server.java:534) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:333) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:251) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:283) [76:org.eclipse.jetty.io:9.3.21.v20170918]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:108) [76:org.eclipse.jetty.io:9.3.21.v20170918]
at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93) [76:org.eclipse.jetty.io:9.3.21.v20170918]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.executeProduceConsume(ExecuteProduceConsume.java:303) [87:org.eclipse.jetty.util:9.3.21.v20170918]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceConsume(ExecuteProduceConsume.java:148) [87:org.eclipse.jetty.util:9.3.21.v20170918]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:136) [87:org.eclipse.jetty.util:9.3.21.v20170918]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:671) [87:org.eclipse.jetty.util:9.3.21.v20170918]
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:589) [87:org.eclipse.jetty.util:9.3.21.v20170918]
Caused by: org.glassfish.jersey.server.ContainerException: java.lang.IncompatibleClassChangeError: Expected static field org.openhab.binding.wink.internal.discovery.WinkDeviceDiscoveryService.scheduler
at org.glassfish.jersey.servlet.internal.ResponseWriter.rethrow(ResponseWriter.java:278) ~[?:?]
at org.glassfish.jersey.servlet.internal.ResponseWriter.failure(ResponseWriter.java:260) ~[?:?]
at org.glassfish.jersey.server.ServerRuntime$Responder.process(ServerRuntime.java:509) ~[170:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:334) ~[170:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) ~[169:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) ~[169:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:315) ~[169:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:297) ~[169:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:267) ~[169:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) ~[169:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) ~[170:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) ~[170:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) ~[167:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
ā¦ 31 more
Caused by: java.lang.IncompatibleClassChangeError: Expected static field org.openhab.binding.wink.internal.discovery.WinkDeviceDiscoveryService.scheduler
at org.openhab.binding.wink.internal.discovery.WinkDeviceDiscoveryService.startScan(WinkDeviceDiscoveryService.java:53) ~[?:?]
at org.eclipse.smarthome.config.discovery.AbstractDiscoveryService.startScan(AbstractDiscoveryService.java:208) ~[?:?]
at org.eclipse.smarthome.config.discovery.internal.DiscoveryServiceRegistryImpl.startScan(DiscoveryServiceRegistryImpl.java:427) ~[?:?]
at org.eclipse.smarthome.config.discovery.internal.DiscoveryServiceRegistryImpl.startScans(DiscoveryServiceRegistryImpl.java:412) ~[?:?]
at org.eclipse.smarthome.config.discovery.internal.DiscoveryServiceRegistryImpl.startScan(DiscoveryServiceRegistryImpl.java:260) ~[?:?]
at org.eclipse.smarthome.io.rest.core.internal.discovery.DiscoveryResource.scan(DiscoveryResource.java:97) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory$1.invoke(ResourceMethodInvocationHandlerFactory.java:81) ~[170:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:144) ~[170:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:161) ~[170:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$ResponseOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:160) ~[170:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:99) ~[170:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:389) ~[170:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:347) ~[170:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:102) ~[170:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:326) ~[170:org.glassfish.jersey.core.jersey-server:2.22.2]
ā¦ 31 more
2018-07-08 16:19:58.959 [WARN ] [org.eclipse.jetty.server.HttpChannel] - //openhabianpi:8080/rest/discovery/bindings/wink/scan
javax.servlet.ServletException: javax.servlet.ServletException: org.glassfish.jersey.server.ContainerException: java.lang.IncompatibleClassChangeError: Expected static field org.openhab.binding.wink.internal.discovery.WinkDeviceDiscoveryService.scheduler
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:88) [183:org.ops4j.pax.web.pax-web-jetty:6.0.9]
Caused by: javax.servlet.ServletException: org.glassfish.jersey.server.ContainerException: java.lang.IncompatibleClassChangeError: Expected static field org.openhab.binding.wink.internal.discovery.WinkDeviceDiscoveryService.scheduler
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:489) ~[?:?]
at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) ~[?:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) ~[?:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) ~[?:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) ~[?:?]
at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) ~[?:?]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:848) ~[?:?]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:584) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) ~[?:?]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) ~[?:?]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226) ~[?:?]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1180) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:284) ~[?:?]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:512) ~[?:?]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185) ~[?:?]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1112) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) ~[?:?]
ā¦ 13 more
at org.glassfish.jersey.server.ServerRuntime$Responder.process(ServerRuntime.java:509) ~[?:?]
at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:334) ~[?:?]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) ~[?:?]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) ~[?:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:315) ~[?:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:297) ~[?:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:267) ~[?:?]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) ~[?:?]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) ~[?:?]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) ~[?:?]
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) ~[?:?]
ā¦ 13 more
at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory$1.invoke(ResourceMethodInvocationHandlerFactory.java:81) ~[?:?]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:144) ~[?:?]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:161) ~[?:?]
at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$ResponseOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:160) ~[?:?]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:99) ~[?:?]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:389) ~[?:?]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:347) ~[?:?]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:102) ~[?:?]
at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:326) ~[?:?]
ā¦ 13 more
These are the same errors I got when I was running OH 2.3 with the Wink far build for OH 2.2. Are you running OH 2.3?
Hi All,
Very new to openHab, but this thread is incredible. Watching this come from an idea that someone volunteered to help put together, to something that seems to be working for many people is pretty awesome.
I am also getting same error. Iām on OpenHab 2.3 but used the 2.3 version of the binding provided by Shawn above after the bug fix I believe. Iāve tried clearing my cache and tmp folders as well as well as restarting OpenHab multiple times. More than happy to help troubleshoot however I can. My logs look exactly the same as Jamesā.
Iām also trying to use this with an original Wink Hub, which others have stated theyāve had success with.
Good evening Nathan,
Yes, I am currently running openHAB 2.3.0-1 (Release Build) (with all recent updates/improvements installed).
The Wink binding jar file that Iām using is called org.openhab.binding.wink-2.3.0-SNAPSHOT.jar, which I believe is the latest as well.
Are you also using Wink Hub 1?
Adding on as there was a new error code that happened that may be related, may not be. After I start discovery, I get the error noted above by James. However, if I let it sit for a long time, I ultimately get this error.
2018-07-11 01:24:54.337 [WARN ] [org.eclipse.jetty.http.HttpParser ] - Illegal character 0x3 in state=START for buffer HeapByteBuffer@27ac985a[p=1,l=43,c=8192,r=42]={\x03<<<\x00\x00+&\xE0\x00\x00\x00\x00\x00Cookie:...hello\r\n\x01\x00\x08\x00\x03\x00\x00\x00>>>json\r\nContent-Len...\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00}
2018-07-11 01:24:54.345 [WARN ] [org.eclipse.jetty.http.HttpParser ] - bad HTTP parsed: 400 Illegal character 0x3 for HttpChannelOverHttp@296b62df{r=0,c=false,a=IDLE,uri=null}
Well, I actually have two (2) Wink hubsā¦a Wink 1 hub and a Wink 2 hub (in different parts of the house). The one that added automatically was the Wink 2 Hub.
I have a binding that is working with the 2.3 stable release you can try. I have been developing thermostat support, so you may have some additional log messages for debugging json that will eventually get removed.
Here is a link to it. Just drop it in your addons folder to give it a try. The debugging Iāve been doing is in this thread, just for reference.
Iām not an openHAB pro, but from what Iāve gathered when a jar file says 2.3.0-SNAPSHOT, this indicates it is built against the 2.2.0 platform. When I setup my IDE to build against the 2.3.0 (latest as of July 2018) platform, my resulting jar has a 2.4.0-SNAPSHOT name. I am thinking that the 2.3.0-SNAPSHOT jar you are using is not compatible with the 2.3.0 release build. @shawncrosbys, can you confirm this?
Joel
Success! That made the difference. After I loaded the new jar file (Thank you Joel), I ran a Discovery, and my Wink items showed up instantly.
Separately, I have another question. Iād like to fully decommission Wink; however, there are few items that I donāt have any other way to communicate with:
Pivot Power Genius
Quirky Refuel Smart Propane Tank Gauge
Leaksmart leak sensors (older ZigBee devices)
The Pivot Power Genius devices and the leak sensors, I could most definitely replace with z-wave devices; however, Iād love to avoid the additional costs right now.
For the propane tank gauge, I donāt think it uses z-wave or ZigBee (same as pivot power genius), but instead uses some type of WiFi communications.
Does anyone have any thoughts on how I could possibly communicate with these devices?
Thanks again!
I can confirm as well that this fixed the issue. Looks like the 2.3 build on the referenced download site was not working with Jamesā nor my openhab version (which for me is 2.3.0 based on āopenhab-cli infoā).
Also, for those out there wondering, I can confirm this worked with the original Wink Hub. My lights and Ring Doorbell connected to Wink immediately showed up.
Awesomeness! That did the trick. I can see all my devices on the Wink 2 including a Nest Thermostat. The hub still needed to be added manually, but when you go back and search for devices the rest all showed up via discovery.
Continuing the discussion from Offering to implement the Wink Hub 2 bindings:
Hey Guys,
sorry dig this thread from the grave, but Iāve been trying to find instructions to install this thing (where do I begin?) for the past hour or so and I couldnāt find it.
Is there instructions how to install this and get started?
PS: Assume that I have close to zero knowledge to openhab, but tons of knowledge on Linux, networking, oauth, etc.
PS2: Iām not confortable using your OAuth service, But I canāt find how to properly set the URI (Iām getting āRedirect URI is not authorizedā error).
Thank you all for your time and for putting this together.
Here is what I did a while to get Oauth working, maybe this will help you out:
First, I setup an account on the Wink Developer Portal. This can take a few days to setup.
This also assumes you are using myopenhab.org.
Then, I setup my application like this (you can try different urls, I put a few in there to get it working and never removed some to figure out which one was right):
Then I went thru the Oauth process using Chrome to get my tokens for the wink.cfg:
step 1
https://api.wink.com/oauth2/authorize?response_type=code&client_id=<your_client_id_from_Wink_Developer_Website>&redirect_uri=https://myopenhab.org/rest/items/&state=123
step 1 returns:
https://myopenhab.org/rest/items/?code=<The_Code>&state=123
step 2
Goto Winkās reference website to make the next call.
https://api.wink.com/oauth2/token
"client_secret": "<your_client_secret_from_Wink_Developer_Website>",
"grant_type": "authorization_code",
"code": "<The_Code_From_Step_One>"
step 2 returns:
"access_token": "<your_access_token>",
"refresh_token": "<your_refresh_token>",
OpenHAB Wink.cfg:
"client_id": "<your_client_id_from_Wink_Developer_Website>",
"grant_type": "refresh_token",
"refresh_token": "<your_refresh_token_from_the_calls_above>"
Hi ā I use Wink Hub 2 to control a wide-ranging home automation system and have read through the above discussion with great interest! With Stringify set to disappear (bummer!), Iāve been looking for another solution that will help me tie things together so I can control things via complex command strings, and hoped openHAB might be a suitable solution to replace how weāve been using Stringify. But since the Wink Hub 2 isnāt currently in the list of supported devices, I presume the binding development being discussed here is still in Alpha stage. Any updates, or projections for when Wink Hub 2 might get added to the list of supported devices for openHAB? Thanks in advance! - Jim
Hi all, any chance of getting this binding to work with 2.5. The depreciation on bundle context seems to be the problem I tried to get it to work by adding it back in but not having much luck. Thanks all and happy xmas.
