I see that when I run discovery in the app, the openhab log shows the following error many times over:
2018-05-19 17:18:32.432 [ERROR] [ersey.server.ServerRuntime$Responder] - An I/O error has occurred while writing a response message entity to the container output stream.
org.glassfish.jersey.server.internal.process.MappableException: org.eclipse.jetty.io.EofException
at org.glassfish.jersey.server.internal.MappableExceptionWrapperInterceptor.aroundWriteTo(MappableExceptionWrapperInterceptor.java:92) [170:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.message.internal.WriterInterceptorExecutor.proceed(WriterInterceptorExecutor.java:162) [169:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.message.internal.MessageBodyFactory.writeTo(MessageBodyFactory.java:1130) [169:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.server.ServerRuntime$Responder.writeResponse(ServerRuntime.java:711) [170:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ServerRuntime$Responder.processResponse(ServerRuntime.java:444) [170:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ServerRuntime$Responder.process(ServerRuntime.java:434) [170:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:329) [170:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [169:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [169:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [169:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [169:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [169:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) [169:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) [170:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) [170:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) [167:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) [167:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) [167:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) [167:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) [167:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) [15:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:848) [85:org.eclipse.jetty.servlet:9.3.21.v20170918]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:584) [85:org.eclipse.jetty.servlet:9.3.21.v20170918]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [183:org.ops4j.pax.web.pax-web-jetty:6.0.9]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) [82:org.eclipse.jetty.security:9.3.21.v20170918]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1180) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:284) [183:org.ops4j.pax.web.pax-web-jetty:6.0.9]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:512) [85:org.eclipse.jetty.servlet:9.3.21.v20170918]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1112) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [183:org.ops4j.pax.web.pax-web-jetty:6.0.9]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.Server.handle(Server.java:534) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:333) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:251) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:283) [77:org.eclipse.jetty.io:9.3.21.v20170918]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:108) [77:org.eclipse.jetty.io:9.3.21.v20170918]
at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93) [77:org.eclipse.jetty.io:9.3.21.v20170918]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.executeProduceConsume(ExecuteProduceConsume.java:303) [88:org.eclipse.jetty.util:9.3.21.v20170918]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceConsume(ExecuteProduceConsume.java:148) [88:org.eclipse.jetty.util:9.3.21.v20170918]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:136) [88:org.eclipse.jetty.util:9.3.21.v20170918]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:671) [88:org.eclipse.jetty.util:9.3.21.v20170918]
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:589) [88:org.eclipse.jetty.util:9.3.21.v20170918]
Caused by: org.eclipse.jetty.io.EofException
at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:199) ~[77:org.eclipse.jetty.io:9.3.21.v20170918]
at org.eclipse.jetty.io.WriteFlusher.flush(WriteFlusher.java:420) ~[77:org.eclipse.jetty.io:9.3.21.v20170918]
at org.eclipse.jetty.io.WriteFlusher.write(WriteFlusher.java:313) ~[77:org.eclipse.jetty.io:9.3.21.v20170918]
at org.eclipse.jetty.io.AbstractEndPoint.write(AbstractEndPoint.java:147) ~[77:org.eclipse.jetty.io:9.3.21.v20170918]
at org.eclipse.jetty.server.HttpConnection$SendCallback.process(HttpConnection.java:739) ~[84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.util.IteratingCallback.processing(IteratingCallback.java:241) ~[88:org.eclipse.jetty.util:9.3.21.v20170918]
at org.eclipse.jetty.util.IteratingCallback.iterate(IteratingCallback.java:224) ~[88:org.eclipse.jetty.util:9.3.21.v20170918]
at org.eclipse.jetty.server.HttpConnection.send(HttpConnection.java:519) ~[84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.HttpChannel.sendResponse(HttpChannel.java:750) ~[84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.HttpChannel.write(HttpChannel.java:801) ~[84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:235) ~[84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:219) ~[84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:470) ~[84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.glassfish.jersey.servlet.internal.ResponseWriter$NonCloseableOutputStreamWrapper.write(ResponseWriter.java:325) ~[?:?]
at org.glassfish.jersey.message.internal.CommittingOutputStream.write(CommittingOutputStream.java:229) ~[?:?]
at org.glassfish.jersey.message.internal.WriterInterceptorExecutor$UnCloseableOutputStream.write(WriterInterceptorExecutor.java:299) ~[?:?]
at org.glassfish.jersey.message.internal.ReaderWriter.writeTo(ReaderWriter.java:116) ~[?:?]
at org.glassfish.jersey.message.internal.AbstractMessageReaderWriterProvider.writeTo(AbstractMessageReaderWriterProvider.java:79) ~[?:?]
at org.glassfish.jersey.message.internal.InputStreamProvider.writeTo(InputStreamProvider.java:105) ~[?:?]
at org.glassfish.jersey.message.internal.InputStreamProvider.writeTo(InputStreamProvider.java:60) ~[?:?]
at org.glassfish.jersey.message.internal.WriterInterceptorExecutor$TerminalWriterInterceptor.invokeWriteTo(WriterInterceptorExecutor.java:265) ~[?:?]
at org.glassfish.jersey.message.internal.WriterInterceptorExecutor$TerminalWriterInterceptor.aroundWriteTo(WriterInterceptorExecutor.java:250) ~[?:?]
at org.glassfish.jersey.message.internal.WriterInterceptorExecutor.proceed(WriterInterceptorExecutor.java:162) ~[?:?]
at org.glassfish.jersey.server.internal.JsonWithPaddingInterceptor.aroundWriteTo(JsonWithPaddingInterceptor.java:106) ~[?:?]
at org.glassfish.jersey.server.internal.MappableExceptionWrapperInterceptor.aroundWriteTo(MappableExceptionWrapperInterceptor.java:86) ~[?:?]
... 46 more
Caused by: java.io.IOException: Broken pipe
at sun.nio.ch.FileDispatcherImpl.writev0(Native Method) ~[?:?]
at sun.nio.ch.SocketDispatcher.writev(SocketDispatcher.java:51) ~[?:?]
at sun.nio.ch.IOUtil.write(IOUtil.java:148) ~[?:?]
at sun.nio.ch.SocketChannelImpl.write(SocketChannelImpl.java:504) ~[?:?]
at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:179) ~[77:org.eclipse.jetty.io:9.3.21.v20170918]
... 46 more
Having thought about this, I implemented a “network based” approach by identifying the active echo device based on the network traffic it causes when the key word “Alexa” is triggered.
I set everything up using PaperUI and gave a light item the name ‘Office light’ in PaperUI. In the control panel I only have ‘Office light’ and ‘Echo’.
The problem is Alexa sees my Office light as a device called ‘switch’ and responds if I voice command turn on/off a device called ‘switch’ and doesnt work if I use device name ‘Office light’!
The name Alexa is using appears to be the channel name from the binding. I am using BTicino OpenWenNet binding for OpenHab2.
How do I change the name so Alexa sees my Office light as ‘Office light’ ?
Thx Mark.
edit…
Update…Fixed it myself after an evening of reading useless information and then an inspired guess… The trick was to select expose item in OpenHab cloud service and select item. Remove devices from Alexa and rediscover.
I got the same error, while seaching for new devices in the alexa app. New devices not found and the old devices are shown as offline in the app, but the old devices works? Very strange
here is the log:
2018-05-24 17:13:02.991 [ERROR] [ersey.server.ServerRuntime$Responder] - An I/O error has occurred while writing a response message entity to the container output stream.
... 46 more
... 46 more
What I found was this:
Does anyone have the same problem?
How did you solve the problem?
just found out about another value add of this solution:
Scenarios where you just want to switch on e.g. lights dependent on the room you are in are also possible.
E.g.
Alexa, light on
can switch on the lights in your living room, when you are talking to your echo device in the living room and can switch on your lights in your bedroom when you talk to your echo device in your bedroom.
As far as I know, there is currently no other option to control something dependent on your location in the house with always the same voice command (despite beacon based solutions …).
“Groups” in the Alexa App can be defined, never the the less they must be linked to different voice commands.
Prespectively it would be great to have this information provided by the Alexa Smart Home Skill. That would make things much easier …
Hi All, Australia went live this morning, we also will support French when Amazon enables smart home skills for that region. The current list of supported languages and regions are:
English (UK)
English (US)
English (CA)
English (AU)
English (IN)
French (FR)
German
You can verify if tags are there by using the REST interface http://yourhost:8080/doc/index.html#!/items/getItems , click “try it out” and verify there are tags under the item you want to expose. Note that metadata, which is in the new version of OH, will be supported in the next version of the skill, today it only supports tags.
Thanks for the feedback! I have setup the new skill on aws, did the same with the old one. It connects to my openhab cloud instance but does not discover any new items. With the old tagging way i could see the Tags when navigating to: /rest/items it and there is a field “Tags” where the information would sit.
Placing the new metadata tagging stuff into {…} will not make anything show there…
I did not realize you were trying out the new v3 version, I would caution that this will change significantly in the next few weeks, so beware its not even alpha quality at this point.
To see metadata, you need to specify this in the rest call, add “alexa” to the metadata field in the rest UI
Thanks! The metadata information does not seem to be retrievable in openHAB 2.4.0 Build #1292, but it does show up in 2.3.0 Release Build. I will try to downgrade my system
So updating my Raspi from Openhabian 2.3.0 to 2.4.0 gives me an error of my alexa echo control binding.
Anyone familiar with this?
All my Alexa devices show as UNINITIALIZED.
Where can I initiliase them?
So this is not an Alexa issue, if your things are not online, then the addon (hue, z-wave, etc…) that controls those is not configured properly. Without knowing a whole lot more about your system, its hard to say why.
