from the google assisstant ifttt triggers page
Thanks, I had already figured it out. Once I realised I could do this to an item of string type is was simple.
Same here. If I add the thermostat correctly (with âhomekit:HeatingCoolingModeâ tag), the thermostat is always offline.
I tried with âhomekit:TargetHeatingCoolingModeâ tag, without tag and without mode, always with the same result: thermostat online but mode offers âheatingâ and âoffâ. It seems that the three are the same as removing the mode.
@MARZIMA, any chance you could look into it, please?
Thanks!
I believe something has to be changed around the thermostat, beside what you mention, there are other problems as wellâŚ
Using Google Home app my thermostats works just fine. But on my Google Nest Hub, it reports that the current mode isn´t supported. I have no idea if this is a Google issue og a mix of Google and openhab. It´s pretty strange it works fine using the Google Home app, but not the Google Nest Hub.
Also Humidity seems to have vanished somehow.
Ok guys, just saw the thermostat issue.
I will dedicate time on weekend and check to fix it.
Sorry for my absenenceâŚ
BR Mehmet
Ahhh cool thank you
Can anyone please help me to understand the point of openhab2 integration to Google assistant? Isnât it redundant? Please excuse my disconnect in this matter and thank you in advance for your help.
Furthermore I am extremely impressed with openhab! Such an amazing, gifted, creative group of people. Yours truly with much much appreciation Thank you All.
You bet. Many of us have devices that lack direct integration with Google Assistant. For example, Belkin chose not to enable my Wemo Maker in GA, so the only way I can control it is via openHABâs integration. The same can be said for Z-Wave, Zigbee, and other devices that are only connected to the machine running openHAB.
Thx
As my new car does have Android Auto I am now able to control my garage door through the carâs voice control function.
openHAB is getting more and more amazing with every day one is using it.
I can confirm -changing from the âhomekit:HeatingCoolingModeâ to âhomekit:TargetHeatingCoolingModeâ
brings thermostat settings back to google home app. We can read temperature, humidity. However we cannot change heating mode with this NEW tag (using google home app, mode is constantly set to heating).
BTW1: from page https://www.openhab.org/addons/integrations/homekit/ quote" Please note: TargetTemperature
has been renamed to homekit:TargetTemperature
and homekit:HeatingCoolingMode
has been renamed to homekit:TargetHeatingCoolingMode
BTW2: I can change led stripes color using openhab, voice but unable with google home app, (it was possible earlier)
As I understandf, this only applies if you´re using Homekit.
I dont use Homekit. Temperatures are working just the way the description says (with the tag TargetTemperature). All my thermostats are set for âheatingâ. And they´re working fine in the Google home app.
Whats not working for me is:
- Google Nest Hub: When I choose a thermostat, the screen shows âthe mode isn´t supportedâ.
The mode works fine in the Google Home App. I have no idea if this is a Openhab issue or a Google issue. But it´s an issue which I believe should have some concern. - Humidity seems to have dissapeared. It has never been visual value in Google Home app. But it has been working asking Google about the Humidity, and then the Assistant would return the actual Humidity value by voice. This doesnt work anymore, and have not been working for quite a few months now.
I really wish someone could confirm these issues. And second, someone take a notice of it. I have mentioned it quite a few times nowâŚ
I´ll try to rise a issue in github, whenever I get the hand onto how to do that.
As already written in the issue: Removing âhomekit:â is working for me too. I think it does not matter if you just remove âhomekit:â or change it to âhomekit:TargetHeatingCoolingModeâ or even use something completely different. You are able to change the temperature again without GA complaining. But using the thermostat mode will not be possible anymore.
I can confirm that the humidity does not work for me either. I tried different configurations (e.g. using a plain Number
item or a Number:Dimensionless
item) in combination with the âCurrentHumidityâ tag. GA always answered: âCurrent humidity is zero.â - which obviously is wrong.
Thanks for confirmation, ChristophâŚ
humidity work with google home here :
Group Sdb_Thermostat âThermostat sdbâ [âThermostatâ]
String Sdb_ThermostatMode âMode Thermostatâ (Sdb_Thermostat) [âHeatingCoolingModeâ]
Number Sdb_ThermostatTarget âTemp Target [%.1f %unit%]â (Sdb_Thermostat)[âTargetTemperatureâ]
Number Sdb_ThermostatAmbientTemp âTemp actuel. [%.1f %unit%]â (Sdb_Thermostat) [âCurrentTemperatureâ] {channel=âmihome:sensor_weather_v1:158d00036b57f8:temperatureâ}
Number Sdb_ThermostatAmbientHumidity âHumiditĂŠâ (Sdb_Thermostat) [âCurrentHumidityâ] {channel=âmihome:sensor_weather_v1:158d00036b57f8:humidityâ}
And for some reason I cant explain as I havn´t changed anything, Humidity is working for me again.
