I’ve been using Netatmo radiator valves for 4+ years, and my only big complaint is that they cannot be controlled when the Internet connection goes down.
Does anyone have experience with valves that work offline (locally)?
I’m wondering which ones and what other problems they have.
So far, I’ve only found these related threads, but they are old or don’t fully address what I’m looking for:
I installed on my radiators Shelly TRV version 1 but I see they’re now discontinued. They used to be with very good pricing when I ordered them but it’s going to be my first year and I’ll collect experience hopefully soon. The integration to the network and the software of the Shelly itself is quite good and you have all the required settings through their IP web interface if you don’t want to use the cloud app. The binding had one bug which I had to fix but so far the integration looks smooth.
I use the COIOT for callbacks from shelly to OH which seems to be implemented in the binding.
The Bluetooth gateway for the TRVs seems to support MQTT.
Next step could be to expose the TRVs to Alexa using Matter and the Matter bridge. I have successfully done this for my 12 years old RWE/Innogy/Livisi thermostats.
Since you already have the new Shelly TRVs, I’d try the MQTT route before swapping them — the Bluetooth gateway exposes the valves over MQTT, and the MQTT binding works completely locally with no cloud account needed. You’d set up a generic MQTT thing pointing at the gateway’s topics and get full temperature and valve control. If that proves too fiddly, Zigbee TRVs such as the Sonoff TRVZB paired via the Zigbee binding are cheap and fully offline, though you’d need a Zigbee coordinator stick.
I’ve always dreaded MQTT, but I’ll take a look, find a way to implement it, and test. How reliable is it? Any package drop issues, or anything like that?
