There is a good deal of overlap here with Thing Status Reporting [4.0.0.0;5.9.9.9] but I won’t contest it unless it starts causing problems. See About the Add-on Marketplace category
- Your contribution must be significantly different from other submissions (no copycats with minor changes). You are encouraged to work together as a community instead of proliferating multiple confusingly similar versions of the same thing.
I would be happy to work to modify my rule to address this use case. I already have it on my to list to make that rule template semantic model aware. Thus, if one adds a status Item to an Equipment the rule template will detect and set it based on the Thing’s status. I already do this other ways already.
One big improvement I can see for this template is to use the generic event trigger (see the trigger on my template) rather than an every second poll.
