i’m in process of setting up openHAB to control parts of the floor heating system.
I have been able to set up the bindings for my thermal sensors to show the measured value in the panel so far.
But i ran into issues trying to compensate for a readout error on one of the sensors using the “offset” profile. While adding the offset-profile with offset value to the binding doesn’t create any error in the log files, the reported value stays the same and no offset is applied to the value.
I use the following item configuration:
Number Corridor_Temperature "Temperatur" <temperature> (Corridor, gTemperature) ["Temperature"] { serial="/dev/ttyS0@9600,REGEX(aTHTMPA([0-9]{1,3}\\.[0-9]{1,3}))"[profile="offset", offset="10.0"]}
Am i missing something there or do i have to use the old way and create a proxy device and use a rule to calculate the corrected value for the proxy?
- Platform information:
- Hardware: Raspberry 4B, 2GB
- OS: Raspbian 10 / Buster
- Java Runtime Environment: openjdk version “1.8.0_212”
- openHAB version: 2.4.0
- Binding: binding-serial1 - 1.13.0
