I’ve adapted my selfmade CAN based home automation over a selfmade ethernet-can gateway with own software to OH 1.8.3. After some basic starting problems the most works fine at the moment.
I report the actual states from the actuators per one large XML file to OH.
I can switch my switches, dim my lamps and move my rollershutter from oenhab.This all works fine.
If i switch my relays or my rolloshutter from outside openhab, the state ist updated in OH as expected.
But the dimmer state is not updated in OH if I change the state from the local switches.
I’ve added an additional Number item with the same bindig to the item file for testing…
The Number is updated, but the Dimmer/Slider not:
item-File
Dimmer Di_17_01 "Dimmer 1 [%d %%]" <slider> (gTest) { http=">[*:GET:http://192.168.0.133/dyn.cgx?dimmer17-01=%2$s] <[CanCache:1000:REGEX(.*?<dimmer17-01>(.*?)</dimmer17-01>.*)]" }
Number Test_17_01 "Dimmer 1 [%d]" <slider> (gTest) { http="<[CanCache:1000:REGEX(.*?<dimmer17-01>(.*?)</dimmer17-01>.*)]" }
sidemap:
Group item=gTest label="Modul Bürotisch" icon="camera"
The XML reports the state like this:
<dimmer17_01>65</dimmer17_01>
I don’t know, why this works for the rolloshutter, but not for the dimmer/slider.
Is it not possible to update the dimmer/slider by http binding, so I must read it back to a number and update the dimmer/slider by a rule?
Can anybody help me?
Dirk
