Hi!
I found some topics regarding “autostart doesn’ work” but I didn’t find one matching my issue…
Everytime I reboot the system I’ve to start it manually:
sudo /etc/init.d/openhab start
maybe here are some helpful information due to my installation, it was setup by the following lines
echo "deb http://dl.bintray.com/openhab/apt-repo stable main" | sudo tee /etc/apt/sources.list.d/openhab.list
sudo apt-get update
sudo apt-get install openhab-runtime
sudo /etc/init.d/openhab status
top u openhab
To autostart the OH service, it told me to confirm the following lines:
cd /etc/default
sudo update-rc.d openhab defaults
But after a reboot, I still have to start the service manually and control the status:
pi@RASPI:~ $ sudo /etc/init.d/openhab status
● openhab.service - Starts and stops the openHAB Home Automation Bus
Loaded: loaded (/usr/lib/systemd/system/openhab.service; disabled; vendor preset: enabled)
Active: active (running) since Sun 2018-03-11 10:20:40 CET; 4h 43min ago
Docs: http://www.openhab.org
Process: 784 ExecStartPre=/usr/share/openhab/bin/setpermissions.sh (code=exited, status=0/SUCCESS)
Main PID: 1002 (openhab.sh)
CGroup: /system.slice/openhab.service
├─1002 /bin/sh /usr/share/openhab/bin/openhab.sh -o
└─1030 /usr/bin/java -Dlogback.configurationFile=/etc/openhab/logback.xml -Dosgi.clean=true -Declipse.ignoreApp=true -Dosgi.noShutdown=true -Djetty.port=8080 -Dopenhab.configfile=/et…55
I’m running OH 1.8.x on a RASPI 2.0 with JESSIE light.
And the file locations are like this:
OpenHab Files for… | Path |
service configuration | /etc/default/openhab |
site configuration | /etc/openhab |
log files | /var/log/openhab |
userdata like rrd4j databases | /var/lib/openhab |
openHAB engine | /usr/share/openhab |
addons and bindings | /usr/share/openhab |
webapps folder | /usr/share/openhab |
I just own some basics of Linux. So I need some detailed instructions for help!!
Thx in advance!
Bernd
