However, I have (had?) the issue, that I needed to start almost all the bindings
(including PaperUI) manually in the karaf console. All bindings I used previously are mentioned in addons.cfg and seemed to be installed.
All my things seem to be there as well.
Even after a whole night there are still some parts in “Resolved” Mode and they cannot be started manually:
169 | Resolved | 80 | 2.1.0 | openHAB Sound Support, Hosts: 111
207 | Resolved | 75 | 2.1.0 | openHAB Basic UI Fragment, Hosts: 187
210 | Resolved | 75 | 2.1.0 | openHAB Paper UI Theme Fragment, Hosts: 188
Now my questions:
Why didn’t the bindings start?
What happens after a reboot? Do I need to do the manual stuff again?
I, too, had those issues (not on openHABian but Raspian Jessie).
Exactly those 3 bindings are still in Resolved state in my installation, too, but they have been so since I moved to 2.1 (snapshots) months ago, and most important: they do work, at least I don’t see any impact.
Still I, too, would like to have someone competent to explain that state. I’d suggest to open a GitHub issue.
Regarding manual installation, I encountered this once or twice .
For me, it helped to delete he ESH cache (/var/lib/openhab2/cache).
But still had some other issues after that (bindings started but suddenly ignored items) and ended doing a purge and (re)install of the OH packages.
openhab> list -s 197
START LEVEL 100 , List Threshold: 50
ID | State | Lvl | Version | Name | Symbolic name
197 | Active | 80 | 0.9.0.201706270841 | Eclipse SmartHome Basic UI, Fragments: 211 | org.eclipse.smarthome.ui.basic
openHAB Paper UI Theme Fragment, Hosts: 198
openhab> list -s 198
198 | Active | 80 | 0.9.0.201706270841 | Eclipse SmartHome Paper UI, Fragments: 214 | org.eclipse.smarthome.ui.paper
I think that this is related to OSGi hosts and fragments
the 3 that you mentioned (openHAB Sound Support, openHAB Basic UI Fragment & openHAB Paper UI Theme Fragment) are fine the way they are (Resolved). I don’t think that you need to do something with these 3.
