I’m running OH 2.2.0 on a windows 7 and have my nikobus connected by USB to serial (connected on com8).
Now I want to add some zwave devices to my installation, my zwave controller (usb-stick) is connected to com7.
When I try to configure the zwave-stick in paperui it is recognized but I can only select com8 from the dropdown list.
When I disconnect my nikobus then I’m able to pick com7, and my zwave devices are found without any problem. However when I reconnect my nikobus com7 seams to be dissappeared from paperui and my controller is no longer recognized.
I tried already changing some files according to docs I found on google regarding similar issues on RPi, but no luck so far.
Anyone who can point me in the right direction?
Thx
I added
EXTRA_JAVA_OPTS=-Dgnu.io.rxtx.SerialPorts=“com7:com8”
to the start.sh and the start.debug.sh
I also added
wrapper.java.additional.18=-Dgnu.io.rxtx.SerialPorts=com7:com8
to the openHAB2-wrapper.conf
Hi Duvelke
Did you fix the error? I have the same error as you. I also use USB to connect openhab to the device. The openhab can not find the USB in Inbox. I also use win 7. Can you help me? Thank you very much
