I re-installed openhab 2.2 (clean) with apt-get install
At the screen “Welcome to openHAB 2 – Initial Setup"
I selected the option “Skip the package selection…”
In etc/openhab2/services/addons.cfg
I enabled ui = paper
From paper-UI > Add-ons > USER INTERFACES is installed:
- Basic UI
- HABmin
- HABPanel
- Home Builder
After a restart of openhab 2.2 they disappear
2018-01-21 16:01:29.187 [INFO ] [er.internal.HomeBuilderDashboardTile] - Started Home Builder at /homebuilder
2018-01-21 16:01:29.313 [WARN ] [.core.internal.i18n.I18nProviderImpl] - Could not set new location, keeping old one:
2018-01-21 16:01:30.480 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at http://192.168.1.25:8080
2018-01-21 16:01:30.485 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at https://192.168.1.25:8443
2018-01-21 16:01:30.553 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = db64f5b0-4255-4d36-8bc9-3f5b5ea2076c, base URL = http://localhost:8080)
2018-01-21 16:01:30.946 [WARN ] [ig.xml.osgi.XmlDocumentBundleTracker] - The XML document '/ESH-INF/binding/binding.xml' in module 'org.eclipse.smarthome.binding.astro' could not be parsed: The XmlConfigDescriptionProvider must not be null!
java.lang.IllegalArgumentException: The XmlConfigDescriptionProvider must not be null!
at org.eclipse.smarthome.core.binding.xml.internal.BindingInfoXmlProvider.<init>(BindingInfoXmlProvider.java:60) [112:org.eclipse.smarthome.core.binding.xml:0.10.0.b1]
at org.eclipse.smarthome.core.binding.xml.internal.XmlBindingInfoProvider.createDocumentProvider(XmlBindingInfoProvider.java:141) [112:org.eclipse.smarthome.core.binding.xml:0.10.0.b1]
at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker.acquireXmlDocumentProvider(XmlDocumentBundleTracker.java:181) [108:org.eclipse.smarthome.config.xml:0.10.0.b1]
at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker.addingObject(XmlDocumentBundleTracker.java:206) [108:org.eclipse.smarthome.config.xml:0.10.0.b1]
at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker.parseDocuments(XmlDocumentBundleTracker.java:350) [108:org.eclipse.smarthome.config.xml:0.10.0.b1]
at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker.processBundle(XmlDocumentBundleTracker.java:336) [108:org.eclipse.smarthome.config.xml:0.10.0.b1]
at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker.access$3(XmlDocumentBundleTracker.java:331) [108:org.eclipse.smarthome.config.xml:0.10.0.b1]
at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker$2.run(XmlDocumentBundleTracker.java:307) [108:org.eclipse.smarthome.config.xml:0.10.0.b1]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
2018-01-21 16:01:36.166 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'sonos.items'
2018-01-21 16:01:36.214 [INFO ] [er.internal.HomeBuilderDashboardTile] - Stopped Home Builder
2018-01-21 16:01:36.507 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'lights.items'
2018-01-21 16:01:36.636 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'groups.items'
2018-01-21 16:01:36.686 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'sensors.items'
2018-01-21 16:01:36.707 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'miscellaneous.items'
2018-01-21 16:01:39.298 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2018-01-21 16:01:39.442 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
2018-01-21 16:01:41.453 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'home.rules'
2018-01-21 16:01:41.567 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'kodi.rules' has errors, therefore ignoring it: [19,2]: no viable alternative at input 'Itemtem'
2018-01-21 16:01:41.706 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2018-01-21 16:01:41.802 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2018-01-21 16:01:42.245 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'frond.sitemap', using it anyway:
Linkable widget should contain either only frames or none at all
2018-01-21 16:01:42.247 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'frond.sitemap'
2018-01-21 16:01:42.503 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2018-01-21 16:01:42.534 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'rfxtrx.things'
2018-01-21 16:01:42.957 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'home.things'
2018-01-21 16:01:43.363 [INFO ] [thome.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:sun:home
2018-01-21 16:01:43.379 [INFO ] [g.rfxcom.handler.RFXComBridgeHandler] - RFXCOM transceiver/receiver type: _433_92MHZ_TRANSCEIVER, hw version: 3.1, fw version: 12
2018-01-21 16:01:43.482 [INFO ] [thome.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:moon:home
2018-01-21 16:01:44.852 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Connecting to serial port '/dev/ttyACM0'
2018-01-21 16:01:44.869 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Serial port is initialized
2018-01-21 16:01:44.879 [INFO ] [mmandclass.ZWaveSecurityCommandClass] - Update networkKey
2018-01-21 16:01:44.893 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2018-01-21 16:01:44.900 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2018-01-21 16:01:44.924 [INFO ] [core.karaf.internal.FeatureInstaller] - Uninstalled 'openhab-ui-homebuilder'
2018-01-21 16:01:46.854 [INFO ] [basic.internal.servlet.WebAppServlet] - Stopped Basic UI
2018-01-21 16:01:46.892 [INFO ] [core.karaf.internal.FeatureInstaller] - Uninstalled 'openhab-ui-basic'
2018-01-21 16:01:48.066 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 1: Node found
2018-01-21 16:01:48.072 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller using Controller API
2018-01-21 16:01:48.072 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller is Primary Controller
2018-01-21 16:01:48.072 [INFO ] [age.SerialApiGetInitDataMessageClass] - ------------Number of Nodes Found Registered to ZWave Controller------------
2018-01-21 16:01:48.073 [INFO ] [age.SerialApiGetInitDataMessageClass] - # Nodes = 14
2018-01-21 16:01:48.078 [INFO ] [age.SerialApiGetInitDataMessageClass] - ----------------------------------------------------------------------------
2018-01-21 16:01:48.470 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Stopped HABmin servlet
2018-01-21 16:01:48.611 [INFO ] [core.karaf.internal.FeatureInstaller] - Uninstalled 'openhab-ui-habmin'
2018-01-21 16:01:48.858 [WARN ] [rialmessage.IsFailedNodeMessageClass] - NODE 2: Is currently marked as failed by the controller!
2018-01-21 16:01:50.240 [INFO ] [panel.internal.HABPanelDashboardTile] - Stopped HABPanel
2018-01-21 16:01:50.266 [INFO ] [core.karaf.internal.FeatureInstaller] - Uninstalled 'openhab-ui-habpanel'
2018-01-21 16:01:58.365 [WARN ] [l.serialmessage.SendDataMessageClass] - NODE 7: Already processed another send data request for this callback Id, ignoring.
Do i need to add them some way in “etc/openhab2/services/addons.cfg” ??
if yes, how ?, what de correct name?
