Used apt install installation method , all appears to work as expected following docs
Yet the docs refer to items and sitemap conf subfolders being in /opt/
Where they are actually installed in /etc/opt/
am I confused or is this an error
The correct locations are given here: https://docs.openhab.org/installation/linux.html#file-locations
Could you please point us to the location of that /opt/
reference?
on the same page
its /etc
and /etc/opt
“/etc/opt” does not appear anywhere on that page. Can you quote the line/lines you are seeing that reference /etc/opt?
On my Install ( repository) openhab2 has no files in /opt just /etc/opt
And the correct files in /etc/openhab2
I can try a fresh install . To confirm or deny this
This is as it should be.
The path “/etc/opt” does not appear anywhere in the docs that Thomas or I can find. All the paths are pointing to the correct locations for an installed openHAB which is /etc/openhab2.
I will take a fresh look later , thank you guys for your time
newbie error on my part & being ish used to how the old openhab rendered bad items and sitemaps, where as new openhab (2) evaluates before rendering
