not really.
I never do. I use the online repo to pull whatever binding I need (it’s automatically downloaded for you when you install the addon from PaperUI or place it in addons.cfg)
Just make sure that you have: PaperUI->Configuration->System->Add-on Management->Access Remote Repository enabled (it’s on by default)
Note to @Benjy : can you please take a look when you can at the openhab2-addons_2.4.0~M7-1_all.deb package? it seems that we are missing it from the repo metadata. I only checked amd64 & arm64
Nice thank you. I’ll remove it then. Remote Access is enabled, that’s actually why I’m running M6 addons despite the fact that I have openhab2-addons M5 installed (I see both versions in PaperUI, now I understand why). Thank you again.
Hey,
right now testing the M7 and all in all it works like a charm. There is just one error message, which I dont know where it comes from. Not sure if its an issue with the M7? Maybe it`s helpful posting it here .
2018-12-04 16:12:43.848 [INFO ] [control.internal.WebSocketConnection] - Web Socket error {}
org.eclipse.jetty.io.EofException: null
at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:286) ~[75:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.flush(SslConnection.java:1005) ~[75:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.io.WriteFlusher.flush(WriteFlusher.java:429) [75:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.io.WriteFlusher.write(WriteFlusher.java:323) [75:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.io.AbstractEndPoint.write(AbstractEndPoint.java:380) [75:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.websocket.common.io.FrameFlusher.flush(FrameFlusher.java:218) [92:org.eclipse.jetty.websocket.common:9.4.11.v20180605]
at org.eclipse.jetty.websocket.common.io.FrameFlusher.process(FrameFlusher.java:157) [92:org.eclipse.jetty.websocket.common:9.4.11.v20180605]
at org.eclipse.jetty.util.IteratingCallback.processing(IteratingCallback.java:241) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.IteratingCallback.iterate(IteratingCallback.java:224) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.websocket.common.io.FrameFlusher.enqueue(FrameFlusher.java:90) [92:org.eclipse.jetty.websocket.common:9.4.11.v20180605]
at org.eclipse.jetty.websocket.common.io.AbstractWebSocketConnection.outgoingFrame(AbstractWebSocketConnection.java:495) [92:org.eclipse.jetty.websocket.common:9.4.11.v20180605]
at org.eclipse.jetty.websocket.client.io.WebSocketClientConnection.outgoingFrame(WebSocketClientConnection.java:72) [91:org.eclipse.jetty.websocket.client:9.4.11.v20180605]
at org.eclipse.jetty.websocket.common.WebSocketSession.close(WebSocketSession.java:223) [92:org.eclipse.jetty.websocket.common:9.4.11.v20180605]
at org.eclipse.jetty.websocket.common.WebSocketSession.close(WebSocketSession.java:202) [92:org.eclipse.jetty.websocket.common:9.4.11.v20180605]
at org.eclipse.jetty.websocket.common.io.AbstractWebSocketConnection.onConnectionStateChange(AbstractWebSocketConnection.java:353) [92:org.eclipse.jetty.websocket.common:9.4.11.v20180605]
at org.eclipse.jetty.websocket.common.io.IOState.notifyStateListeners(IOState.java:184) [92:org.eclipse.jetty.websocket.common:9.4.11.v20180605]
at org.eclipse.jetty.websocket.common.io.IOState.onReadFailure(IOState.java:498) [92:org.eclipse.jetty.websocket.common:9.4.11.v20180605]
at org.eclipse.jetty.websocket.common.io.AbstractWebSocketConnection.readParse(AbstractWebSocketConnection.java:547) [92:org.eclipse.jetty.websocket.common:9.4.11.v20180605]
at org.eclipse.jetty.websocket.common.io.AbstractWebSocketConnection.onFillable(AbstractWebSocketConnection.java:391) [92:org.eclipse.jetty.websocket.common:9.4.11.v20180605]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:281) [75:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:102) [75:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:291) [75:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.io.ssl.SslConnection$3.succeeded(SslConnection.java:151) [75:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:118) [75:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:762) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:680) [87:org.eclipse.jetty.util:9.4.11.v20180605]
Caused by: java.io.IOException: Broken pipe
at sun.nio.ch.FileDispatcherImpl.write0(Native Method) ~[?:?]
at sun.nio.ch.SocketDispatcher.write(SocketDispatcher.java:47) ~[?:?]
at sun.nio.ch.IOUtil.writeFromNativeBuffer(IOUtil.java:93) ~[?:?]
at sun.nio.ch.IOUtil.write(IOUtil.java:51) ~[?:?]
at sun.nio.ch.SocketChannelImpl.write(SocketChannelImpl.java:471) ~[?:?]
at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:264) ~[?:?]
... 27 more
2018-12-04 16:12:43.885 [INFO ] [control.internal.WebSocketConnection] - Web Socket close 1006. Reason: WebSocket Read EOF
It doesn’t appear to be a general issue.
Can you think of any context?
when does it happen? e.g. when you connect a browser to a OH2 UI? when you connect a mobile app?
How often does it happen?
Which bindings do you have installed? (that are using websockets?)
Looks like some https connection is failing.
You’re already one step further, right now I would just like someone to check and confirm or not confirm the issue. I have installed the update on the day it came out and heard about that today the first time, so it might stay unnoticed for quite a while. If someone says that he/she doesn’t have the issue on the build I will do a complete bug report with all the details and do some investigations myself to see what might be going on here, if someone else has the issue aswell it’s most likely an issue in the code. If you have a group using rrd4j for persistence a simple check would be to use the URL I wrote in the github issue, insert the groups name and see how that looks like.
@Kim_Andersen have meet following tricky problem with M7 release. Problem have not seen with earlier versions.
IHC Binding doesn’t get all channelLinked “events” from OH/SmartHome core during OH full start, but if binding is restarted after OH start, the binding get all channelLinked events.
Most of the bindings are not interested by the channelLinked events, but IHC binding is.
IHC binding have couple of static channels (introduced by the thing defination)
and rest of the channels are generated on the fly (there can be hundreds of channels at the end).
It seems that only those static channels receive the channelLinked events on startup, but not others.
I can’t reproduce this problem on my development environment (Macbook pro). So this problem might be related to timing as Kim is testing this in Raspberry Pi.
@Kaihave there been recently any changes on OH/SmartHome core which could have impact to thing channelLinked events?
I run Rpi 3B+ with apt-get openhabian hasslefree.
I started off with a clean openhab 2.3 install, upgraded to #1445 and then #1447, and latest the Milestone M7.
I think the problem Pauli speak of could have been represented in #1447 and maybe even #1445. I just didnt pay enough attention due to some testing where I used the disable/enable button alot. (I can try downgrade and test if necessary??).
The IHC binding is the only extra binding installed, since my main purpose with this test setup was to test the new IHC binding only.
I can reproduce the problem even by restarting openhab, (I dont have to reboot).
The issue with the charts is that it defaults to mapdb for some reason, even though it doesn’t make sense at all as the mapdb doesn’t store historical values. This solution was provided by someone in the github issue.
If the binding expects this, I would consider it a bug in the binding. The channelLinked() method is only meant for dynamic updates during runtime. It is absolutely ok that it is never called for channels, which are already linked at startup while the handler isn’t yet initialised.
PR was merged 4 hours ago
We wait now for the new OH 2.4.0 Snapshot that will include the new ESH build
Maybe another Milestone #8 before 2.4.0 Stable also?
