This may deserve a github issue… is anyone else seeing the same?
- Platform information:
- Hardware: Laptop with Intel CPU i5-6200U, 8GB RAM, 1TB HDD
- OS: Linux Debian Jessie x64
- Java Runtime Environment: Oracle JVM x64 build 1.8.0_191-b12
- openHAB version: 2.4.0 Snapshot Build #1413
- Issue of the topic: Upon service shutdown (systemctl stop openhab2), I get the following logged:
==> openhab.log <==
2018-11-06 09:34:15.562 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'Runnable.run()' on 'org.eclipse.smarthome.core.thing.internal.ThingManagerImpl$$Lambda$447/533216619@1f2134e9': null
at org.eclipse.smarthome.core.thing.internal.ThingManagerImpl.lambda$5(ThingManagerImpl.java:828) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) [101:org.eclipse.smarthome.core:0.10.0.201811051614]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) [101:org.eclipse.smarthome.core:0.10.0.201811051614]
2018-11-06 09:34:15.571 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'Runnable.run()' on 'org.eclipse.smarthome.core.thing.internal.ThingManagerImpl$$Lambda$447/533216619@272ac84d': null
alot of ERRORs
2018-11-06 09:34:19.016 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'Runnable.run()' on 'org.eclipse.smarthome.core.thing.internal.ThingManagerImpl$$Lambda$447/533216619@7b9393ee': null
at sun.reflect.GeneratedMethodAccessor95.invoke(Unknown Source) ~[?:?]
2018-11-06 09:34:19.065 [INFO ] [ternal.scheduler.WeatherJobScheduler] - Deleting weatherJob-HomeR
2018-11-06 09:34:19.075 [INFO ] [penhab.io.transport.mqtt.MqttService] - Stopping broker connection 'homer'
2018-11-06 09:34:19.082 [WARN ] [ence.internal.PersistenceManagerImpl] - Failed to delete cron job for persistence service 'influxdb'
2018-11-06 09:34:19.170 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Stopped HABmin servlet
2018-11-06 09:34:19.340 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Stopped Paper UI
2018-11-06 09:34:19.349 [INFO ] [panel.internal.HABPanelDashboardTile] - Stopped HABPanel
2018-11-06 09:34:19.356 [INFO ] [.dashboard.internal.DashboardService] - Stopped Dashboard
