This is based on my understanding of how it works:
What is this "Milestone" stuff?
As of the time of this post, openHAB2 has 3 main branches under which the distribution is made available to all:
1) The Stable Release = 2.3.0. Published on 28/May/2018. Cycle: ~6M
2) The Milestone Build = 2.4.0 M6. Published on 20/Nov/2018. Cycle: ~1M
3) The Snapshot Build = 2.4.0 S1434. Published on 21/Nov/2018. Cycle: ~1d
The Milestone build is a testing (semi-stable) build of the OH2 distribution and includes all new enhancements, features and bug fixes.
The Snapshot build is a bleeding-edge (considered unstable) build of the OH2 distribution and includes all the latest enhancements, features and bug fixes.
Get 2.3.0 Stable from here: Main Web Site (or the stable repo)
Get 2.4.0 Milestone 6 from here: JFrog.io (or the testing repo)
Get 2.4.0 Snapshot from here: Jenkins (or the unstable repo)
How do I report issues that I have identified with Milestone build?
Use the community forum to start with. Maybe your issue is due to a miss-configuration
and not due to a bug.
If the results of the troubleshooting in the forum point to a bug,
you can open up a github issue to be tracked and reviewed by the developers.
When you post problems (either in the forum or in github) add as much
info as you can (relevant to the problem) in order to help with identification and
possible reproduction of the issue.
Is 2.4.0 M6 going to become 2.4.0 Stable if all is OK with it?
The development team is planning to make available more Milestones (M7/M8) before the final Release of 2.4.0 Stable.
Can I run 2.4.0.M6 with Java VM 11?
No! The recommended JVM is: Zulu 8. See more here: Prerequisites
Services configuration: just selected Expert at the initial startup
Logs: TBD
Good news ! I cannot reproduce https://github.com/openhab/openhab-distro/issues/729 using openhab-addons-2.4.0-SNAPSHOT.kar from OH 2.4.0 Snapshot Build # 1433. I will try to dig deeper to see how this was fixed.
Second test result:
Next system working fine so far: the production one
23 secs to a full OH2 startup… that’s fast !
Platform information:
Hardware: Laptop with Intel CPU i5-6200U, 8GB RAM, 1TB HDD
I’m using OpenWeatherMap binding. After updating to M6 I can’t get it to work.
I have installed it from the IoT market, but as soon as it gets installed it first goes to initializing and after to OFFLINE.
What is the package name for these IoT bindings? I couldn’t get it change the logging level…
Yes, that’s what I have installed. However the binding slightly changed, that’s why it didn’t work. (Now there is no seperate thing for Current and Forecast… I didn’t knew that change.)
I like that notation! Since there is regular confusion on which apt/yum version (which uses a timestamp) relates to which build number (which uses an incremental counter), I’d like to start naming the snapshot versions like this. Not sure how it would be done just yet though.
2.4.0~S1434-1 would be the first linuxpkg build from CI build #1434. If there ever needed a second build of the same snapshot (i.e. for a apt/yum specific bugfix), then it would be released as 2.4.0~S1434-2.
Upgraded from 2.3 stable this time yesterday and so far so good.
That being said I did do the usual cache clearing before starting 2.4M6 but it still took two reboots before the logs were clear of messages about transformations not being installed.
I experience the same with all upgrades. I believe that it has something to do with the clearing of cache+tmp (a step in the upgrade script). I am not sure if I reliably reproduce this for every restart following a cache+tmp clear.
I haven’t tested the system to see if it is stable even with these warnings about transformations not being loaded since I just perform a second restart of the OH2 service immediately and the warn goes away. I usually let the service down for 10 seconds to let it “cool down” before I start it up again for the second time (otherwise I get these strange HK2 errors)
I think that there is an issue tracking this (xformations not loading after clearing cache+tmp) somewhere.
I tried to update from Milestone 5, but even after restarting openHAB several time I still get some exceptions during startup I don_t know the reason of:
2018-11-22 20:28:03.137 [ERROR] [org.apache.felix.scr ] - bundle org.apache.felix.scr:2.1.2 (39)Circular reference detected trying to get service {org.eclipse.smarthome.automation.module.script.ScriptExtensionProvider}={service.id=342, service.bundleid=217, service.scope=bundle, component.name=org.eclipse.smarthome.automation.module.media.internal.MediaScriptScopeProvider, component.id=200}
stack of references: ServiceReference: {org.eclipse.smarthome.automation.module.script.ScriptExtensionProvider}={service.id=342, service.bundleid=217, service.scope=bundle, component.name=org.eclipse.smarthome.automation.module.media.internal.MediaScriptScopeProvider, component.id=200}
Dependency: DependencyManager: Component [Component: org.eclipse.smarthome.automation.module.script.internal.ScriptExtensionManager (202)] reference [ScriptExtensionProvider]
ServiceReference: {org.eclipse.smarthome.automation.module.script.ScriptEngineManager}={service.id=344, service.bundleid=218, service.scope=bundle, component.name=org.eclipse.smarthome.automation.module.script.internal.ScriptEngineManagerImpl, component.id=201}
ServiceReference: {org.eclipse.smarthome.automation.module.script.internal.ScriptExtensionManager}={service.id=343, service.bundleid=218, service.scope=bundle, component.name=org.eclipse.smarthome.automation.module.script.internal.ScriptExtensionManager, component.id=202}
java.lang.Exception: stack trace
at org.apache.felix.scr.impl.ComponentRegistry.enterCreate(ComponentRegistry.java:481) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.BundleComponentActivator.enterCreate(BundleComponentActivator.java:735) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:845) [39:org.apache.felix.scr:2.1.2]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212) [?:?]
at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:508) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:624) [?:?]
at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:73) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.inject.BindParameters.getServiceObject(BindParameters.java:47) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.inject.methods.BindMethod.getServiceObject(BindMethod.java:662) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.DependencyManager.getServiceObject(DependencyManager.java:2304) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.prebind(DependencyManager.java:419) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.DependencyManager.prebind(DependencyManager.java:1576) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.collectDependencies(AbstractComponentManager.java:1014) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:899) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:863) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.prebind(DependencyManager.java:1162) [39:org.apache.felix.scr:2.1.2]
at com.eclipsesource.jaxrs.publisher.internal.ResourceTracker.addingService(ResourceTracker.java:39) [20:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941) [?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870) [?:?]
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) [?:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229) [?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:901) [?:?]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:920) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:469) [?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:891) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:877) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:128) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:944) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:727) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:1053) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:1007) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1216) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1137) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:944) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:880) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1168) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:125) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:661) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:427) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:665) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:339) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:381) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:49) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:263) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49) [39:org.apache.felix.scr:2.1.2]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) [?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) [?:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) [?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168) [?:?]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) [?:?]
at org.eclipse.osgi.container.Module.start(Module.java:467) [?:?]
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:468) [?:?]
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:103) [?:?]
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:529) [?:?]
at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:328) [?:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:368) [?:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:446) [?:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:395) [?:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:387) [?:?]
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:150) [?:?]
at java.lang.ClassLoader.loadClass(ClassLoader.java:357) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.loadClass(EquinoxBundle.java:564) [?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.initDependencyManagers(AbstractComponentManager.java:984) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.collectDependencies(AbstractComponentManager.java:1011) [39:org.apache.felix.scr:2.1.2]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1634) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1614) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1585) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1528) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]
and
2018-11-22 20:28:03.161 [WARN ] [se.smarthome.automation.module.media] - FrameworkEvent WARNING - org.eclipse.smarthome.automation.module.media
org.osgi.framework.ServiceException: org.apache.felix.scr.impl.manager.SingleComponentManager.getService() returned a null service object
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:232) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:508) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:624) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:73) ~[?:?]
at org.apache.felix.scr.impl.inject.BindParameters.getServiceObject(BindParameters.java:47) ~[?:?]
at org.apache.felix.scr.impl.inject.methods.BindMethod.getServiceObject(BindMethod.java:662) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager.getServiceObject(DependencyManager.java:2304) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.prebind(DependencyManager.java:419) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager.prebind(DependencyManager.java:1576) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.collectDependencies(AbstractComponentManager.java:1014) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:899) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:863) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.prebind(DependencyManager.java:1162) ~[?:?]
at com.eclipsesource.jaxrs.publisher.internal.ResourceTracker.addingService(ResourceTracker.java:39) ~[?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941) ~[?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870) ~[?:?]
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) ~[?:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229) ~[?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:901) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:920) ~[?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) ~[?:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:469) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:891) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:877) ~[?:?]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:128) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:944) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:727) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:1053) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:1007) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1216) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1137) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:944) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:880) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1168) ~[?:?]
at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:125) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:661) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:427) ~[?:?]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:665) ~[?:?]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:339) ~[?:?]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:381) ~[?:?]
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:49) ~[?:?]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:263) ~[?:?]
at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) ~[?:?]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) ~[?:?]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49) ~[?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) ~[?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) ~[?:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) ~[?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168) ~[?:?]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) ~[?:?]
at org.eclipse.osgi.container.Module.start(Module.java:467) ~[?:?]
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:468) ~[?:?]
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:103) ~[?:?]
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:529) ~[?:?]
at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:328) ~[?:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:368) ~[?:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:446) ~[?:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:395) ~[?:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:387) ~[?:?]
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:150) ~[?:?]
at java.lang.ClassLoader.loadClass(ClassLoader.java:357) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.loadClass(EquinoxBundle.java:564) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.initDependencyManagers(AbstractComponentManager.java:984) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.collectDependencies(AbstractComponentManager.java:1011) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1634) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1614) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1585) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1528) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) ~[?:?]
there seems to be some kind of issue (just a warning though) with my item definition. I have 2 or 3 channels linked to a single item. Is this use case deprecated?
2018-11-22 19:51:01.838 [WARN ] [ore.common.registry.AbstractRegistry] - Cannot add "Metadata" with key "channel:aLivingCeilingBulb". It exists already from provider "GenericMetadataProvider"! Failed to add a second with the same UID from provider "GenericMetadataProvider"!
2018-11-22 19:51:01.839 [WARN ] [ore.common.registry.AbstractRegistry] - Cannot add "Metadata" with key "channel:aLivingCeilingBulb". It exists already from provider "GenericMetadataProvider"! Failed to add a second with the same UID from provider "GenericMetadataProvider"!
2018-11-22 19:51:01.844 [WARN ] [ore.common.registry.AbstractRegistry] - Cannot add "Metadata" with key "channel:aLivingFloorRightBulbs". It exists already from provider "GenericMetadataProvider"! Failed to add a second with the same UID from provider "GenericMetadataProvider"!
2018-11-22 19:51:01.845 [WARN ] [ore.common.registry.AbstractRegistry] - Cannot add "Metadata" with key "channel:aLivingFloorRightBulbs_switch". It exists already from provider "GenericMetadataProvider"! Failed to add a second with the same UID from provider "GenericMetadataProvider"!
2018-11-22 19:51:01.846 [WARN ] [ore.common.registry.AbstractRegistry] - Cannot add "Metadata" with key "channel:aLivingFloorLeftBulbs". It exists already from provider "GenericMetadataProvider"! Failed to add a second with the same UID from provider "GenericMetadataProvider"!
2018-11-22 19:51:01.847 [WARN ] [ore.common.registry.AbstractRegistry] - Cannot add "Metadata" with key "channel:aLivingFloorLeftBulbs_switch". It exists already from provider "GenericMetadataProvider"! Failed to add a second with the same UID from provider "GenericMetadataProvider"!
I’m running 2.4 SNAPSHOT Build 1436 (just upgraded from 2.3.0 from Synology DSM) that is very slow (was already slow in 2.3 since I started 1 month ago). No upgrade issue faced but I now started investigating why it is so slow and wanted to share 2 first strange behaviours I observed.
Here is my configuration:
openhab> info
Karaf
Karaf version 4.2.1
OSGi Framework org.eclipse.osgi-3.12.100.v20180210-1608
JVM
Java Virtual Machine Java HotSpot™ 64-Bit Server VM version 25.191-b12
Version 1.8.0_191
Vendor Oracle Corporation
Uptime 1 hour 6 minutes
Process CPU time 25 minutes
Process CPU load 0.06
System CPU load 0.11
Open file descriptors 259
Max file descriptors 4,096
Total compile time 47 minutes
Threads
Live threads 232
Daemon threads 101
Peak 251
Total started 4381
Memory
Current heap size 125,028 kbytes
Maximum heap size 160,384 kbytes
Committed heap size 160,384 kbytes
Pending objects 0
Garbage collector Name = ‘Copy’, Collections = 394, Time = 1 minute
Garbage collector Name = ‘MarkSweepCompact’, Collections = 34, Time = 24 minutes
Classes
Current classes loaded 20,931
Total classes loaded 22,800
Total classes unloaded 1,869
Operating system
Name Linux version 4.4.59+
Architecture aarch64
Processors 4
Quite rapidly after startup (and even after a while), it is hanging and facing timeouts left and right like:
[ERROR] [.smarthome.model.script.actions.HTTP] - Fatal transport error: java.util.concurrent.TimeoutException: Total timeout 5000 ms elapsed
for HTTP Clients typically foriCloud and CalDav bindings:
[DEBUG] [rg.eclipse.jetty.client.HttpExchange] - Failed HttpExchange@5385495f req=COMPLETED/java.util.concurrent.TimeoutException: Total timeout 10000 ms
for myOpenhab Cloud reconnections:
[WARN ] [l.handler.ICloudAccountBridgeHandler] - Unable to refresh device data
java.io.IOException: java.util.concurrent.TimeoutException: Total timeout 10000 ms elapsed
[INFO ] [io.openhabcloud.internal.CloudClient] - Disconnected from the openHAB Cloud service (UUID = 93001014-b2ca-43d5-b3e0-c2abdee9cfac, base URL = http://localhost:8080)
for pools (MariaDB with JDBC?):
[WARN ] [com.zaxxer.hikari.pool.HikariPool ] - 2m15s967ms724μs102ns - Thread starvation or clock leap detected (housekeeper delta=yank-default).
for events ti the LOGGER: [WARN ] [me.core.internal.events.EventHandler] - Dispatching event to subscriber ‘org.eclipse.smarthome.io.monitor.internal.EventLogger@6668705f’ takes more than 5000ms.
But I don’t really know the origin of these problems. If someone has some insights on where to start the investigation, he is welcome. The only 2 strange behaviours I could really identify are as follow:
1/ OH tries endlessly to fetch maven-metadata.xml which does not exist (rather the maven-metadata**-local**.xml @ https://openhab.jfrog.io:443/openhab/online-repo-snapshot/2.4/org/openhab/distro/openhab-addons-legacy/2.4.0-SNAPSHOT/)
This thread is the most CPU consuming one. Here is the stack trace of features-3-thread-1 :
openhab> threads 174
Thread 174 features-3-thread-1 WAITING
Stacktrace:
java.lang.Object.wait line: -2
java.lang.Object.wait line: 502
org.apache.karaf.features.internal.download.impl.MavenDownloadManager$MavenDownloader.await line: 101
org.apache.karaf.features.internal.region.Subsystem.downloadBundles line: 537
org.apache.karaf.features.internal.region.Subsystem.downloadBundles line: 452
org.apache.karaf.features.internal.region.SubsystemResolver.resolve line: 224
org.apache.karaf.features.internal.service.Deployer.deploy line: 388
org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision line: 1025
org.apache.karaf.features.internal.service.FeaturesServiceImpl.lambda$doProvisionInThread$13 line: 964
org.apache.karaf.features.internal.service.FeaturesServiceImpl$$Lambda$379/1169167538.call line: -1
java.util.concurrent.FutureTask.run line: 266
java.util.concurrent.ThreadPoolExecutor.runWorker line: 1149
java.util.concurrent.ThreadPoolExecutor$Worker.run line: 624
java.lang.Thread.run line: 748
–> Only visible with DEBUG log level: 404 File Not found.
2/ There are regular entries in the log about a nma binding I don’t know anything about.
[DEBUG] [core.karaf.internal.FeatureInstaller] - Installed ‘openhab-action-nma’
Does it reinstall the binding all the time? Why?
This is my first post so my apologies if I am not at the right place, and/or if the post is not very well formatted
I hope these 2 points raised would help improving the next deliveries.
You’re doing a great job, I love it
This is related to the performance improvements in https://github.com/eclipse/smarthome/pull/6438 I think this needs some more research in how this use case can be supported. Nice find.
Would definitely need to be fixed for the 2.4.0 release (actually already for ESH 0.10.0, which is planned for Dec 7). Hope you can come up with a fix!
I’ve get a try to the M6 milestones. Good work from the team as always
Here are some findings after the lauch of openHAB (or simply I miss a steop??)
17:46:08.433 [WARN ] [.internal.service.FeaturesServiceImpl] - Can’t load features repository mvn:org.openhab.distro/distro/2.4.0-SNAPSHOT/xml/features
java.lang.RuntimeException: Error resolving artifact org.openhab.distro:distro:xml:features:2.4.0-SNAPSHOT: [Could not find artifact org.openhab.distro:distro:xml:features:2.4.0-SNAPSHOT in openhab (https://openhab.jfrog.io/openhab/online-repo-snapshot/2.4/)] : mvn:org.openhab.distro/distro/2.4.0-SNAPSHOT/xml/features
at org.apache.karaf.features.internal.service.RepositoryImpl.load(RepositoryImpl.java:116) ~[?:?]
at org.apache.karaf.features.internal.service.RepositoryImpl.(RepositoryImpl.java:50) ~[?:?]
at org.apache.karaf.features.internal.service.RepositoryCacheImpl.create(RepositoryCacheImpl.java:51) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.getFeatureCache(FeaturesServiceImpl.java:593) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.listInstalledFeatures(FeaturesServiceImpl.java:643) ~[?:?]
at org.openhab.core.karaf.internal.FeatureInstaller.installFeature(FeatureInstaller.java:450) ~[?:?]
at org.openhab.core.karaf.internal.FeatureInstaller.installPackage(FeatureInstaller.java:491) ~[?:?]
at org.openhab.core.karaf.internal.FeatureInstaller.lambda$2(FeatureInstaller.java:163) ~[?:?]
Caused by: java.io.IOException: Error resolving artifact org.openhab.distro:distro:xml:features:2.4.0-SNAPSHOT: [Could not find artifact org.openhab.distro:distro:xml:features:2.4.0-SNAPSHOT in openhab (https://openhab.jfrog.io/openhab/online-repo-snapshot/2.4/)]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:720) ~[?:?]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:659) ~[?:?]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:600) ~[?:?]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:567) ~[?:?]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:557) ~[?:?]
at org.ops4j.pax.url.mvn.internal.Connection.getInputStream(Connection.java:123) ~[?:?]
at java.net.URL.openStream(URL.java:1045) ~[?:?]
at org.apache.karaf.features.internal.service.RepositoryImpl.load(RepositoryImpl.java:113) ~[?:?]
… 10 more
Suppressed: shaded.org.eclipse.aether.transfer.ArtifactNotFoundException: Could not find artifact org.openhab.distro:distro:xml:features:2.4.0-SNAPSHOT in openhab (https://openhab.jfrog.io/openhab/online-repo-snapshot/2.4/)
at shaded.org.eclipse.aether.connector.basic.ArtifactTransportListener.transferFailed(ArtifactTransportListener.java:39) ~[?:?]
at shaded.org.eclipse.aether.connector.basic.BasicRepositoryConnector$TaskRunner.run(BasicRepositoryConnector.java:355) ~[?:?]
at shaded.org.eclipse.aether.util.concurrency.RunnableErrorForwarder$1.run(RunnableErrorForwarder.java:67) ~[?:?]
at shaded.org.eclipse.aether.connector.basic.BasicRepositoryConnector$DirectExecutor.execute(BasicRepositoryConnector.java:581) ~[?:?]
at shaded.org.eclipse.aether.connector.basic.BasicRepositoryConnector.get(BasicRepositoryConnector.java:249) ~[?:?]
at shaded.org.eclipse.aether.internal.impl.DefaultArtifactResolver.performDownloads(DefaultArtifactResolver.java:520) ~[?:?]
at shaded.org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolve(DefaultArtifactResolver.java:421) ~[?:?]
at shaded.org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolveArtifacts(DefaultArtifactResolver.java:246) ~[?:?]
at shaded.org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolveArtifact(DefaultArtifactResolver.java:223) ~[?:?]
at shaded.org.eclipse.aether.internal.impl.DefaultRepositorySystem.resolveArtifact(DefaultRepositorySystem.java:294) ~[?:?]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:705) ~[?:?]
Caused by: shaded.org.eclipse.aether.resolution.ArtifactResolutionException: Error resolving artifact org.openhab.distro:distro:xml:features:2.4.0-SNAPSHOT
at shaded.org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolve(DefaultArtifactResolver.java:444) ~[?:?]
… 10 more
17:46:08.537 [ERROR] [.core.karaf.internal.FeatureInstaller] - Failed installing ‘openhab-package-expert’: No matching features for openhab-package-expert/0
and also
17:46:21.221 [ERROR] [.core.karaf.internal.FeatureInstaller] - Failed installing ‘openhab-misc-restdocs’: Unable to resolve root: missing requirement [root] osgi.identity; osgi.identity=openhab-runtime-base; type=karaf.feature; version="[2.4.0.SNAPSHOT,2.4.0.SNAPSHOT]"; filter:="(&(osgi.identity=openhab-runtime-base)(type=karaf.feature)(version>=2.4.0.SNAPSHOT)(version<=2.4.0.SNAPSHOT))"
17:46:22.808 [WARN ] [ome.core.internal.events.EventHandler] - Dispatching event to subscriber ‘org.eclipse.smarthome.io.monitor.internal.EventLogger@231e47de’ takes more than 5000ms.
my system info:
openhab> info
Karaf
Karaf version 4.2.1
Karaf home /volume1/@appstore/openHAB/runtime
Karaf base /volume1/public/openHAB/userdata
JVM
Java Virtual Machine Java HotSpot(TM) 64-Bit Server VM version 25.191-b12
Version 1.8.0_191
Pid 11016
Uptime 22 minutes
Process CPU time 7 minutes
Process CPU load 0.04
System CPU load 0.31
Open file descriptors 268
Total compile time 4 minutes
Threads
Live threads 181
Daemon threads 91
Peak 232
Total started 1851
Memory
Current heap size 88,614 kbytes
Maximum heap size 2,023,424 kbytes
Committed heap size 126,976 kbytes
Pending objects 0
Garbage collector Name = 'G1 Young Generation', Collections = 222, Time = 5.294 seconds
Garbage collector Name = 'G1 Old Generation', Collections = 0, Time = 0.000 seconds
Classes
Current classes loaded 18,354
Total classes loaded 18,405
Total classes unloaded 51
Operating system
Name Linux version 3.10.105
Architecture amd64
Processors 4
