I have the impression that when reloading rules, sometimes the rule context is not yet initialized when using timers, as in:
2019-06-24 11:50:23.554 [ERROR] [org.quartz.core.JobRunShell ] - Job DEFAULT.2019-06-24T11:50:23.543+02:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
<XMemberFeatureCallImplCustom>.forEach(<XClosureImplCustom>)
<null>.timer_startup = <XNullLiteralImplCustom>
} ] threw an unhandled Exception:
at org.eclipse.smarthome.model.script.engine.ScriptError.<init>(ScriptError.java:66) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:140) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:902) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:865) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:224) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:226) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:204) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:768) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:220) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:447) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:228) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:190) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.ClosureInvocationHandler.doInvoke(ClosureInvocationHandler.java:46) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.AbstractClosureInvocationHandler.invoke(AbstractClosureInvocationHandler.java:29) ~[?:?]
at com.sun.proxy.$Proxy334.apply(Unknown Source) ~[?:?]
at org.eclipse.smarthome.model.script.internal.actions.TimerExecutionJob.execute(TimerExecutionJob.java:49) ~[?:?]
at org.quartz.core.JobRunShell.run(JobRunShell.java:202) [185:org.openhab.core.scheduler:2.5.0.201906240304]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573) [185:org.openhab.core.scheduler:2.5.0.201906240304]
2019-06-24 11:50:23.696 [ERROR] [org.quartz.core.ErrorLogger ] - Job (DEFAULT.2019-06-24T11:50:23.543+02:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
} ] threw an exception.
org.quartz.SchedulerException: Job threw an unhandled exception.
at org.quartz.core.JobRunShell.run(JobRunShell.java:213) [185:org.openhab.core.scheduler:2.5.0.201906240304]
Caused by: java.lang.NullPointerException
at org.quartz.core.JobRunShell.run(JobRunShell.java:202) ~[?:?]
... 1 more
The rule reads as follows:
rule "System startup - shutters"
System started
val String ruleTitle = "Roller Shutters: OpenHAB STARTUP"
logInfo(ruleTitle, "Initializing timers")
val int STARTUP_DELAY_SECONDS = 5 // 30
STARTED_UP = false;
if (timer_startup === null) {
// Wait 30 seconds before resetting all timers
timer_startup = createTimer(now.plusSeconds(STARTUP_DELAY_SECONDS), [ |
gShutter.allMembers.forEach[ s |
if (timers.get(s.name) !== null) {
timers.put(s.name, null)
STARTED_UP = true;
logInfo(ruleTitle, "Rules and timers have been initialized")
timer_startup = null;
} else {
logWarn(ruleTitle, "Double startup trigger? rescheduling the stattup timer")
timer_startup.reschedule(now.plusSeconds(STARTUP_DELAY_SECONDS))
