I started using OH3. I do own meanwhile some Shellies, a Hue Bridge, some Hue Motion Sensors (indoor and outdoor) and some other things.
I also run Zigbee2MQTT, due to the fact, that the Hue Brdige is, if you connect a motion sensor with a light, too slow. MQTT is much faster.
Now, I “activated” a secod Hue motion sensor and that is causing issues. My first motion sensor (bathroom) works perfect until the second motion sensor receives detects motion. It seems that this mess up the occupance of the frist hue motion sensor.
One motion sensor allown works perfect, the 2 in combination (different rooms) causes issues. Any clue what this could be?
If I look into MQTT.fx, I can see, that hue motion sensor 1 does not send occupancy update BUT ONLY if hue motion sensor 2 has detected a motion.
EDIT 14:10: I have seen that this issues appears as well as if the Aqara door sensor (also via MQTT) sends a comand.
Any idea?
cheers
-J
