I am using OH 3.0.1 in docker and can’t get my icalendar binding to connect to caldav.
The URL, user and password is 100% is correct. Calling the URL from a PC asks for user and password. Then the ics file is downloaded.
In the log file I get the following error
2021-02-05 17:01:24.176 [WARN ] [g.icalendar.internal.handler.PullJob] - Response status for getting “http://correctIP/baikal/html/cal.php/calendars/correctuser/openhabEG/?export” was 401 instead of 200. Ignoring it.
What am I doing wrong? Does the docker not allow http to go out?
I have seen other posts and there the issue was the missing ?export at the end of the URL. So I have run out of ideas…
Solved it. I had to change the caldav authorization to basic. Not really sure what I am doing here but as the calendar is only accessible locally I think I will survivie #define(“BAIKAL_DAV_AUTH_TYPE”, ‘Digest’);
define(“BAIKAL_DAV_AUTH_TYPE”, ‘Basic’);
Where did you put this line? I notice you mention using Docker, but that doesn’t look like anything from a docker-compose file.
I’m in the same boat as you were: saw this thread noting the ?export, I can successfully download from the correct URL with the correct credentials using a browser, but I can’t from openHAB:
Bridge icalendar:calendar:mycalendar "My Calendar"[
url="http://192.168.1.166/dav.php/calendars/me/default?export",
username="myusername",
password="mypassword",
refreshTime=60
Response status for getting "http://192.168.1.166/dav.php/calendars/me/default?export" was 401 instead of 200. Ignoring it.
Well I have a frustrating problem with Baikal. Either I can synchronize with IOS and use digest authentication or can synchronize with Openhab and use basic authentication. Does anyone know how to solve it ? Thx
