2021-09-15 21:18:17.090 [ERROR] [Events.Framework ] - FrameworkEvent ERROR
java.lang.IllegalStateException: Configuration Admin service has been unregistered
at org.apache.felix.cm.impl.ConfigurationAdminImpl.getConfigurationManager(ConfigurationAdminImpl.java:325) ~[?:?]
at org.apache.felix.cm.impl.ConfigurationAdminImpl.getConfiguration(ConfigurationAdminImpl.java:156) ~[?:?]
at org.apache.karaf.log.core.internal.LogServiceImpl.getConfiguration(LogServiceImpl.java:121) ~[?:?]
at org.apache.karaf.log.core.internal.LogServiceImpl.setLevel(LogServiceImpl.java:103) ~[?:?]
at org.apache.karaf.log.command.LogTail$LogServiceTracker.removedService(LogTail.java:103) ~[?:?]
at org.apache.karaf.log.command.LogTail$LogServiceTracker.removedService(LogTail.java:76) ~[?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerRemoved(ServiceTracker.java:969) ~[osgi.core-7.0.0.jar:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerRemoved(ServiceTracker.java:871) ~[osgi.core-7.0.0.jar:?]
at org.osgi.util.tracker.AbstractTracked.untrack(AbstractTracked.java:341) ~[osgi.core-7.0.0.jar:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:911) ~[osgi.core-7.0.0.jar:?]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:120) ~[org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:957) ~[org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234) ~[org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:151) ~[org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:936) ~[org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:873) ~[org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.unregister(ServiceRegistrationImpl.java:241) ~[org.eclipse.osgi-3.16.200.jar:?]
at org.apache.karaf.util.tracker.BaseActivator.doStop(BaseActivator.java:146) ~[?:?]
at org.apache.karaf.util.tracker.BaseActivator.stop(BaseActivator.java:108) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:871) ~[org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1) ~[org.eclipse.osgi-3.16.200.jar:?]
at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.stop(BundleContextImpl.java:863) ~[org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.stopWorker0(EquinoxBundle.java:1026) ~[org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.stopWorker(EquinoxBundle.java:371) ~[org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.container.Module.doStop(Module.java:660) ~[org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.container.Module.stop(Module.java:521) ~[org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.decStartLevel(ModuleContainer.java:1886) ~[org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1761) ~[org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.container.SystemModule.stopWorker(SystemModule.java:275) ~[org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule.stopWorker(EquinoxBundle.java:203) ~[org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.container.SystemModule.stop(SystemModule.java:207) ~[org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule$1.run(EquinoxBundle.java:221) ~[org.eclipse.osgi-3.16.200.jar:?]
at java.lang.Thread.run(Thread.java:834) ~[?:?]
2021-09-15 21:18:17.112 [ERROR] [Events.Framework ] - FrameworkEvent ERROR
Is that the full content of openhab.log or just the first error. It might be useful to see how far along in the boot openHAB got before crashing if there is more in the logs than that.
Have you tried to run it manually? Maybe that will give a more reasonable error.
