Here are the error messages captured with debugging turned on for the JDBC persistence MariaDB binding:
Two examples for failing updates at startup of Location
items:
2021-04-08 13:21:28.442 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::query: item is locationJR
2021-04-08 13:21:28.443 [DEBUG] [persistence.jdbc.internal.JdbcMapper] - JDBC::getHistItemFilterQuery filter='true' numberDecimalcount='3' table='Item372' item='locationJR (Type=LocationItem, State=NULL, Label=JR Location, Category=null)' itemName='locationJR'
2021-04-08 13:21:28.444 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::getHistItemFilterQueryProvider filter = org.openhab.core.persistence.FilterCriteria@17ac9388, numberDecimalcount = 3, table = Item372, simpleName = locationJR
2021-04-08 13:21:28.444 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::query queryString = SELECT time, value FROM Item372 ORDER BY time DESC LIMIT 0,1
2021-04-08 13:21:28.445 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::doGetHistItemFilterQuery sql=SELECT time, value FROM Item372 ORDER BY time DESC LIMIT 0,1
2021-04-08 13:21:28.448 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '49.9725155,8.3393236', unit = 'null', getClass = 'class java.lang.String', clazz = 'String'
2021-04-08 13:21:28.449 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::query: query for locationJR returned 1 rows in 6 ms
2021-04-08 13:21:28.450 [ERROR] [org.openhab.core.items.GenericItem ] - Tried to set invalid state 51.5085,-0.1257 (StringType) on item locationJR of type LocationItem, ignoring it
2021-04-08 13:21:28.491 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::query: item is localStationLocation
2021-04-08 13:21:28.492 [DEBUG] [persistence.jdbc.internal.JdbcMapper] - JDBC::getHistItemFilterQuery filter='true' numberDecimalcount='3' table='Item40' item='localStationLocation (Type=LocationItem, State=NULL, Label=Location, Category=location)' itemName='localStationLocation'
2021-04-08 13:21:28.493 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::getHistItemFilterQueryProvider filter = org.openhab.core.persistence.FilterCriteria@7ac8c3b8, numberDecimalcount = 3, table = Item40, simpleName = localStationLocation
2021-04-08 13:21:28.494 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::query queryString = SELECT time, value FROM Item40 ORDER BY time DESC LIMIT 0,1
2021-04-08 13:21:28.495 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::doGetHistItemFilterQuery sql=SELECT time, value FROM Item40 ORDER BY time DESC LIMIT 0,1
2021-04-08 13:21:28.497 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '49.9725,8.3393', unit = 'null', getClass = 'class java.lang.String', clazz = 'String'
2021-04-08 13:21:28.498 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::query: query for localStationLocation returned 1 rows in 6 ms
2021-04-08 13:21:28.499 [ERROR] [org.openhab.core.items.GenericItem ] - Tried to set invalid state 51.5085,-0.1257 (StringType) on item localStationLocation of type LocationItem, ignoring it
Two examples for failing updates at startup of Image
items:
2021-04-08 13:21:28.292 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::query: item is MyCityCurrentConditionIcon
2021-04-08 13:21:28.292 [DEBUG] [persistence.jdbc.internal.JdbcMapper] - JDBC::getHistItemFilterQuery filter='true' numberDecimalcount='3' table='Item25' item='MyCityCurrentConditionIcon (Type=ImageItem, State=NULL, Label=Icon, Category=null)' itemName='MyCityCurrentConditionIcon'
2021-04-08 13:21:28.293 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::getHistItemFilterQueryProvider filter = org.openhab.core.persistence.FilterCriteria@1b63a0fa, numberDecimalcount = 3, table = Item25, simpleName = MyCityCurrentConditionIcon
2021-04-08 13:21:28.294 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::query queryString = SELECT time, value FROM Item25 ORDER BY time DESC LIMIT 0,1
2021-04-08 13:21:28.295 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::doGetHistItemFilterQuery sql=SELECT time, value FROM Item25 ORDER BY time DESC LIMIT 0,1
2021-04-08 13:21:28.298 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '[114, 97, 119, 32, 116, 121, 112, 101, 32, 40, 105, 109, 97, 103, 101, 47, 112, 110, 103, 41, 58, 32, 50, 55, 55, 51, 32, 98, 121, 116, 101, 115]', unit = 'null', getClass = 'class [B', clazz = 'byte[]'
2021-04-08 13:21:28.299 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'QueryablePersistenceService.query()' on 'org.openhab.persistence.jdbc.internal.JdbcPersistenceService@6bfdcace': class [B cannot be cast to class java.lang.String ([B and java.lang.String are in module java.base of loader 'bootstrap')
2021-04-08 13:21:28.317 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::getName: returning name 'jdbc' for queryable persistence service.
2021-04-08 13:21:28.317 [ERROR] [ence.internal.PersistenceManagerImpl] - Exception occurred while querying persistence service 'jdbc': class [B cannot be cast to class java.lang.String ([B and java.lang.String are in module java.base of loader 'bootstrap')
2021-04-08 13:21:28.583 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::query: item is MyCityHourlyForecast03ConditionIcon
2021-04-08 13:21:28.584 [DEBUG] [persistence.jdbc.internal.JdbcMapper] - JDBC::getHistItemFilterQuery filter='true' numberDecimalcount='3' table='Item45' item='MyCityHourlyForecast03ConditionIcon (Type=ImageItem, State=NULL, Label=Icon, Category=null)' itemName='MyCityHourlyForecast03ConditionIcon'
2021-04-08 13:21:28.584 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::getHistItemFilterQueryProvider filter = org.openhab.core.persistence.FilterCriteria@515081eb, numberDecimalcount = 3, table = Item45, simpleName = MyCityHourlyForecast03ConditionIcon
2021-04-08 13:21:28.585 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::query queryString = SELECT time, value FROM Item45 ORDER BY time DESC LIMIT 0,1
2021-04-08 13:21:28.586 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::doGetHistItemFilterQuery sql=SELECT time, value FROM Item45 ORDER BY time DESC LIMIT 0,1
2021-04-08 13:21:28.588 [DEBUG] [nhab.persistence.jdbc.db.JdbcBaseDAO] - JDBC::ItemResultHandler::handleResult getState value = '[114, 97, 119, 32, 116, 121, 112, 101, 32, 40, 105, 109, 97, 103, 101, 47, 112, 110, 103, 41, 58, 32, 50, 55, 55, 51, 32, 98, 121, 116, 101, 115]', unit = 'null', getClass = 'class [B', clazz = 'byte[]'
2021-04-08 13:21:28.589 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'QueryablePersistenceService.query()' on 'org.openhab.persistence.jdbc.internal.JdbcPersistenceService@6bfdcace': class [B cannot be cast to class java.lang.String ([B and java.lang.String are in module java.base of loader 'bootstrap')
2021-04-08 13:21:28.594 [DEBUG] [jdbc.internal.JdbcPersistenceService] - JDBC::getName: returning name 'jdbc' for queryable persistence service.
2021-04-08 13:21:28.595 [ERROR] [ence.internal.PersistenceManagerImpl] - Exception occurred while querying persistence service 'jdbc': class [B cannot be cast to class java.lang.String ([B and java.lang.String are in module java.base of loader 'bootstrap')
