OH 3.2.0 M1 + Influx 1.8.7 not storing data
This week I updated influxdb to 1.8.7 and OpenHAB from 3.1.0 to 3.2.0 M1. The problem with version 1.8.7 is solved by me and now influx is running itself, but I see that now OpenHAB does not store data in database. Firstly I had following error in log
2021-08-05 13:26:39.471 [ERROR] [org.influxdb.impl.BatchProcessor    ] - Batch could not be sent. Data will be lost
org.influxdb.InfluxDBException: [shard 189] open /var/lib/influxdb/data/openhab_db/autogen/189/fields.idx.1.tmp: permission denied
	at org.influxdb.InfluxDBException.buildExceptionFromErrorMessage(InfluxDBException.java:161) ~[bundleFile:?]
	at org.influxdb.InfluxDBException.buildExceptionForErrorState(InfluxDBException.java:173) ~[bundleFile:?]
	at org.influxdb.impl.InfluxDBImpl.execute(InfluxDBImpl.java:827) ~[bundleFile:?]
	at org.influxdb.impl.InfluxDBImpl.write(InfluxDBImpl.java:460) ~[bundleFile:?]
	at org.influxdb.impl.OneShotBatchWriter.write(OneShotBatchWriter.java:22) ~[bundleFile:?]
	at org.influxdb.impl.BatchProcessor.write(BatchProcessor.java:340) [bundleFile:?]
	at org.influxdb.impl.BatchProcessor$1.run(BatchProcessor.java:287) [bundleFile:?]
	at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source) [?:?]
	at java.util.concurrent.FutureTask.run(Unknown Source) [?:?]
	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source) [?:?]
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) [?:?]
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) [?:?]
	at java.lang.Thread.run(Unknown Source) [?:?]
But now I see following entries:
2021-08-05 15:02:58.216 [ERROR] [org.influxdb.impl.BatchProcessor    ] - Batch could not be sent. Data will be lost
org.influxdb.InfluxDBException: engine: error rolling WAL segment: error opening new segment file for wal (2): open /var/lib/influxdb/wal/openhab_db/autogen/189/_06264.wal: permission denied
I see there is a difference in first line and accessing fields.idx.1.tmp previously and now _06264.wal.
Status of influxdb shows following output, also something with this wal file.
â—Ź influxdb.service - InfluxDB is an open-source, distributed, time series database
   Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
   Active: active (running) since Thu 2021-08-05 14:33:28 CEST; 31min ago
     Docs: https://docs.influxdata.com/influxdb/
  Process: 20426 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (code=exited, status=0/SUCCESS)
 Main PID: 20427 (influxd)
    Tasks: 14 (limit: 4411)
   CGroup: /system.slice/influxdb.service
           └─20427 /usr/bin/influxd -config /etc/influxdb/influxdb.conf
Aug 05 15:04:45 openhab influxd-systemd-start.sh[20426]: [httpd] 127.0.0.1 - openhab [05/Aug/2021:15:04:45 +0200] "POST /write?db=openhab_db&rp=autogen&precision=n&consistency=one HTTP/1.1 " 500 171 "-" "okhttp/3.14.4" b4c3b323-f5ed-11eb
Aug 05 15:04:45 openhab influxd-systemd-start.sh[20426]: ts=2021-08-05T13:04:45.371486Z lvl=error msg="[500] - \"engine: error rolling WAL segment: error opening new segment file for wal (2): open /var/lib/influxdb/wal/openhab_db/autogen
Aug 05 15:04:45 openhab influxd-systemd-start.sh[20426]: ts=2021-08-05T13:04:45.835128Z lvl=info msg="Executing query" log_id=0Vm_h~q0000 service=query query="SELECT value::field, item::tag FROM openhab_db.autogen.FF_Corridor_Temperature
Aug 05 15:04:45 openhab influxd-systemd-start.sh[20426]: [httpd] 127.0.0.1 - openhab [05/Aug/2021:15:04:45 +0200] "GET /query?db=openhab_db&epoch=ms&q=SELECT+%22value%22%3A%3Afield%2C%22item%22%3A%3Atag+FROM+autogen.FF_Corridor_Temperatu
Aug 05 15:04:45 openhab influxd-systemd-start.sh[20426]: [httpd] 127.0.0.1 - openhab [05/Aug/2021:15:04:45 +0200] "POST /write?db=openhab_db&rp=autogen&precision=n&consistency=one HTTP/1.1 " 500 171 "-" "okhttp/3.14.4" b510929a-f5ed-11eb
Aug 05 15:04:45 openhab influxd-systemd-start.sh[20426]: ts=2021-08-05T13:04:45.875417Z lvl=error msg="[500] - \"engine: error rolling WAL segment: error opening new segment file for wal (2): open /var/lib/influxdb/wal/openhab_db/autogen
Aug 05 15:04:46 openhab influxd-systemd-start.sh[20426]: [httpd] 127.0.0.1 - openhab [05/Aug/2021:15:04:46 +0200] "POST /write?db=openhab_db&rp=autogen&precision=n&consistency=one HTTP/1.1 " 500 171 "-" "okhttp/3.14.4" b52f9c8d-f5ed-11eb
Aug 05 15:04:46 openhab influxd-systemd-start.sh[20426]: ts=2021-08-05T13:04:46.078737Z lvl=error msg="[500] - \"engine: error rolling WAL segment: error opening new segment file for wal (2): open /var/lib/influxdb/wal/openhab_db/autogen
Aug 05 15:04:46 openhab influxd-systemd-start.sh[20426]: [httpd] 127.0.0.1 - openhab [05/Aug/2021:15:04:46 +0200] "POST /write?db=openhab_db&rp=autogen&precision=n&consistency=one HTTP/1.1 " 500 171 "-" "okhttp/3.14.4" b59b08dd-f5ed-11eb
Aug 05 15:04:46 openhab influxd-systemd-start.sh[20426]: ts=2021-08-05T13:04:46.782916Z lvl=error msg="[500] - \"engine: error rolling WAL segment: error opening new segment file for wal (2): open /var/lib/influxdb/wal/openhab_db/autogen
l
Any idea what is happening? I was trying to search on google and openhab forum, but no luck so far.
The errors point to file permission problems. Does what ever user InfluxDB is running under have permission to write to /var/lib/influxdb/data/openhab_db/autogen/189/fields.idx.1.tmp and /var/lib/influxdb/wal/openhab_db/autogen/189/_06264.wal? In particular that user needs permission to read/write and for the directories execute all the files under /var/lib/influxdb. The execute permissions on a directory is what allows a user to cd to it.
Database servers tend to have very strict permissions on their folders and files and if that got messed up it breaks things.
This one ( Error writing snapshot ... Permission denied - InfluxData Community Forums ) shows up by googling and is about permissions like @rlkoshak already suggested.
Thanks both @rlkoshak @Wolfgang_S for answers. Morning update of influx solved problems. Maybe I forgot to add the info, that yesterday dyrung day I checked permissions and ownership and all belonged to influxdb except /var/lib/influxdb/data/openhab_db/autogen/189, so I changed it to influxdb, therefore error was changed from
to
I did not make to check the _06264.wal file itself (before morning update), but folder 189 belonged to influxdb after my change. Now, after update of influx, this file is gone in this folder. Anyway, updating helped.
