jwiseman
(Mr. Wiseman (OH 4.3.0 Snapshot on Pi4))
1
I’ve been struggling with this rule for over 2 months now. It only runs in the morning with the alarm, so I wait 24 hours to see my results of the change.
This rule looks at an Alexa alarm then turns lights on gradually based on being within X minutes of the alarm.
Here’s where I’m at rewriting the logic from OH 2.x to OH 3.x based on the date/time conversion issues with OH3. I’ve pieced meal the rule below to keep it simple.
var String alarmtime = 'NULL'
var String alarmdate = 'NULL'
var CurrentDT = new DateTimeType(now().plusDays(0))
alarmtime = transform("JSONPATH", "$.notifications[" + i + "].originalTime", json)
alarmdate = transform("JSONPATH", "$.notifications[" + i + "].originalDate", json)
var setAlarmTime = new DateTimeType(alarmdate + "T" + alarmtime)
Here’s the variable values after the logic above:
CurrentDT is 2021-12-29T05:00:49.454941-0600
Alexa alarm is 2021-12-29T07:15:00.000-0600
Here’s the problem line:
if (CurrentDT.isBefore(setAlarmTime) && CurrentDT.plusMinutes(20).isAfter(setAlarmTime))
Here’s the error I’m getting:
'isBefore' is not a member of 'org.openhab.core.library.types.DateTimeType'; line 11576, column 10, length 32 in default
You will have noticed that the most powerful type of object to use to represent a date-time in rules is the Java ZonedDateTime
This has methods for offsets, before/after tests, etc.
The system variable now for example is a ZonedDateTime object in OH3
DateTime type Items have a state holding the less-useful DateTimeType. That’s because of history, but it is easy enough to get that info converted to the ZonedDateTime when required.
In the bit of code that you have shown us here - who cares about that anyway? There are no Item states involved at all.
So as now is already ZonedDateTime, let’s just use it as it is.
var CurrentZDT = now().plusDays(0)
// but really that's just
So the test becomes
if (CurrentZDT.isBefore(setAlarmTime) && ...
and the ZonedDateTime object has isBefore/isAfter methods.
But, of course, you need that setAlarmTime variable to be ZDT as well.
I think this should do that from your string fragments -
var setAlarmTime = ZonedDateTime.parse(alarmdate + "T" + alarmtime)
jwiseman
3
Hi rossko57,
We are closer, here’s the error we have now.
Script execution of rule with UID ‘default-95’ failed: Text ‘2021-12-30T07:15:00.000’ could not be parsed at index 23 in default
My guess the error is tied to this line:
var setAlarmTime = ZonedDateTime.parse(alarmdate + “T” + alarmtime)
Here’s the value of “now” which includes the time zone.
CurrentDT is 2021-12-30T05:30:49.060368-06:00[America/Chicago]
Any ideas?
Best, Jay
jwiseman
4
May I should just append this to the time side of the string so they match?
