System:
Pi 4, 4 GB RAM
Openhabian, upgraded via openhabian-config.
I have basic auth enabled in the REST API settings.
At the same time my visual studio code is no longer giving me item states, when I hover over them in the editor. Don’t know if that can be affiliated with this.
Ok-thanks for that
Does anyone know if the some user settings have changed in connection with the upgrade? (Haven’t changed anything, and it worked prior).
Yes, the API now requires authentication. You enabled it in OH but did not configure VSCode to authenticate.
This is all documented in the Release notes which should be required reading before upgrading. This forum is not a replacement for reading the documentation
I did read the release notes before upgrading.
I was not fully aware what the error meant - it seems I am still not, because my VS Code is know working (token authentication) and updating item states correctly, but the error still remains in the openhab.log.
