Hello!
I found a note in the download section that says arm is supported. Is someone already using oh3 on an arm mac? I am thinking about upgrading from my 2012 mac mini server to a newer machine. If so - which jre are you using and do you face any issues?
Thank you!
The Raspberry Pi hardware is ARM based & supported.
If Zulu has a Java 11 JDK for the new Mac Mini I expect it should work. Otherwise a Docker installation should work,.
EDIT: Azul does not list a Java 11 JDK for the new mac mini.
