I there I am trying to convert or migrate the following rule into OH 3 from OH 2 for my water heater.
Please help there
rule “Thermostat”
Item TEMP changed or
Item Temperature_Setpoint_Mode changed
// also triggers when mode changes for immediate action
// else nothing would happen until temp changed, if it ever did
// first we check if the temp reading is valid
if ( TEMP.state != NULL &&
TEMP.state != UNDEF &&
TEMP.state > 0) {
// that != means “not equal” in an if(condition)
// while the && means “and”
// temp sensor is valid, so
// let's set up a target temperature
var Number tempMax = 55
if (Temperature_Setpoint_Mode.state == 2) {
// shower mode
tempMax = 55
} else if (Temperature_Setpoint_Mode.state == 1) {
// normal mode
tempMax = Temperature_Setpoint.state
} else if (Temperature_Setpoint_Mode.state == 3) {
// normal mode
tempMax = 0
// if the mode is anything else, the target stays 0 i.e. off
// now let's check against upper limit
if (TEMP.state < (tempMax - 5)) {
// we allow 1 degree hysteresis
// It's colder than target
// so turn heater on if it isn't already
if (Geyser.state != ON) {
Geyser.sendCommand(ON)
// else lets check if we're at the target
} else if (TEMP.state > tempMax) {
// reached target temp
// (our target could be 0 if mode is off)
// so turn heater off if it isn't already
if (Geyser.state != OFF) {
Geyser.sendCommand(OFF)
} // else we do nothing here
// temp could be within 1 degree of target
// and the heater will continue doing what it is doing
// That's the hysteresis
} else { // this else belongs to the valid temp reading check
// temp sensor broken, turn off heater for safety
rule “Thermostat”
TEMP.state > 0) {
// shower mode
tempMax = 55
// normal mode
// normal mode
tempMax = 0
ule "Thermostat"
TEMP.state > 0) {
// that != means "not equal" in an if(condition)
// while the && means "and"
// shower mode
tempMax = 55
// normal mode
// normal mode
tempMax = 0
OK, the rule is easier to read now but still there is nothing about this rule that should not work in OH 3. So please explain exactly how it’s not working and provide any relevant logs.
It will work exactly the same as it does in OH 2. If you want to move it to the UI see the Getting Started Tutorial to get started. Rules - Introduction | openHAB
