Hi I have a migrated system from 2.5.12 to 3.0.1-2
Ruuning on netboot RPI 3b+ Jessie
I has been working fpor a couple of days but yesterday it started with ssh login didn’t work first tried from remotedesktop to LAN pc and putty from ther, used puuty to sign in to rpi andd use ssh from command line nothing worked but web interface and app still worked, but today after a restart not even web if worked. My only change in configuration is addong and removing semantec models in web if.
output of dpkg -l ‘openhab*’
|/ Fel?Inget(=)/Ominstallera®/Båda(X) (Status,Fel: versaler=illa)
||/ Namn Version Arkitektur Beskrivning
ii openhab 3.0.1-2 all openhab
un openhab-runtime (beskrivning saknas)
un openhab2 (beskrivning saknas)
un openhab2-offline (beskrivning saknas)
un openhab2-online (beskrivning saknas)
ouput from journalctl
– Logs begin at Sat 2021-02-20 16:10:25 CET, end at Sat 2021-02-20 16:21:12 CET. –
feb 20 16:14:39 raspberrypi systemd[1]: Started openHAB - empowering the smart home.
service status
● openhab.service - openHAB - empowering the smart home
Loaded: loaded (/usr/lib/systemd/system/openhab.service; enabled; vendor preset: enabled)
Active: active (running) since Sat 2021-02-20 16:14:39 CET; 7min ago
Docs: Introduction | openHAB
https://community.openhab.org
Main PID: 417 (java)
Tasks: 16 (limit: 4915)
CGroup: /system.slice/openhab.service
└─417 /usr/bin/java -XX:-UsePerfData -Dopenhab.home=/usr/share/openhab -Dopenhab.conf=/etc/openhab -Dopenhab.runtime=/usr/share/openhab/runtime -Dopenhab.userdata=/var/lib/openhab -Dopenhab.logdir=/var/log/openhab -Dfelix.cm.d
