Ok, I have now done the following:
- updated to the latest snapshot
3.1.0-SNAPSHOT - Build #2111
- checked Zwave version in console:
3.1.0.202101020442
- Updated the bundle manually in the console
3.1.0.202101021321
First thing I notice is that some devices are not recognized anymore:
2021-01-02 18:38:50.017 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2021-01-02 18:38:50.019 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2021-01-02 18:38:56.329 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 49: Device discovery could not resolve to a thingType! 0258:0003:1087::3.94
2021-01-02 18:38:56.346 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 28: Device discovery could not resolve to a thingType! 0258:0003:1087::3.94
2021-01-02 18:38:56.351 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 78: Device discovery could not resolve to a thingType! 0258:0003:1087::3.94
āExclude Devicesā seems to work now, the controller stays online:
2021-01-02 18:48:40.065 [DEBUG] [zwave.handler.ZWaveControllerHandler] - Controller Configuration update received
2021-01-02 18:48:40.085 [DEBUG] [zwave.handler.ZWaveControllerHandler] - Controller Configuration update ignored controller_softreset to false (Boolean)
2021-01-02 18:48:40.087 [DEBUG] [zwave.handler.ZWaveControllerHandler] - Controller Configuration update ignored security_networkkey to 28 36 AB 0E 32 08 4A C7 98 2C 75 54 12 0D 54 E1 (String)
2021-01-02 18:48:40.089 [DEBUG] [zwave.handler.ZWaveControllerHandler] - Controller Configuration update ignored security_inclusionmode to 0 (BigDecimal)
2021-01-02 18:48:40.091 [DEBUG] [zwave.handler.ZWaveControllerHandler] - Controller Configuration update ignored controller_sisnode to 1 (BigDecimal)
2021-01-02 18:48:40.093 [DEBUG] [zwave.handler.ZWaveControllerHandler] - Controller Configuration update ignored controller_sync to false (Boolean)
2021-01-02 18:48:40.095 [DEBUG] [zwave.handler.ZWaveControllerHandler] - Controller Configuration update ignored port to /dev/ttyACM0 (String)
2021-01-02 18:48:40.096 [DEBUG] [zwave.handler.ZWaveControllerHandler] - Controller Configuration update ignored controller_master to true (Boolean)
2021-01-02 18:48:40.098 [DEBUG] [zwave.handler.ZWaveControllerHandler] - Controller Configuration update ignored inclusion_mode to 2 (BigDecimal)
2021-01-02 18:48:40.100 [DEBUG] [zwave.handler.ZWaveControllerHandler] - Controller Configuration update ignored controller_wakeupperiod to 3600 (BigDecimal)
2021-01-02 18:48:40.102 [DEBUG] [zwave.handler.ZWaveControllerHandler] - Controller Configuration update ignored heal_time to 2 (BigDecimal)
2021-01-02 18:48:40.104 [DEBUG] [zwave.handler.ZWaveControllerHandler] - Controller Configuration update controller_exclude to true
2021-01-02 18:48:40.108 [DEBUG] [ve.internal.protocol.ZWaveController] - Event listener added.
2021-01-02 18:48:40.109 [DEBUG] [al.protocol.ZWaveInclusionController] - ZWave controller start exclusion
2021-01-02 18:48:40.113 [DEBUG] [serialmessage.RemoveNodeMessageClass] - Setting controller into EXCLUSION mode.
2021-01-02 18:48:40.115 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Added 173 to queue - size 1
2021-01-02 18:48:40.117 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
I get this message on every reload of the Thing-page:
2021-01-02 18:55:44.802 [DEBUG] [g.zwave.internal.ZWaveConfigProvider] - No bridgeUID found in getConfigDescription thing:zwave:serial_zstick:512
However, switching from āCodeā to the other tabs is still NOT working:
2021-01-02 18:57:49.674 [DEBUG] [g.zwave.internal.ZWaveConfigProvider] - No bridgeUID found in getConfigDescription thing:zwave:serial_zstick:512
2021-01-02 18:57:49.705 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Disposing receive thread
2021-01-02 18:57:49.739 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Stopped ZWave thread: Receive
021-01-02 18:57:49.750 [DEBUG] [zwave.handler.ZWaveControllerHandler] - Stopping ZWave network
2021-01-02 18:57:49.754 [DEBUG] [ve.internal.protocol.ZWaveController] - Shutting down ZWave controller
2021-01-02 18:57:49.757 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Shutting down transaction manager
2021-01-02 18:57:49.763 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Exiting ZWave Receive Thread
2021-01-02 18:57:54.789 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWave Transaction manager failed to terminate properly, forcing shutdown
2021-01-02 18:57:54.795 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 18: sendTransaction exception
java.util.concurrent.ExecutionException: java.lang.InterruptedException
at java.util.concurrent.FutureTask.report(FutureTask.java:122) ~[?:?]
at java.util.concurrent.FutureTask.get(FutureTask.java:191) ~[?:?]
at org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager.sendTransaction(ZWaveTransactionManager.java:1205) [bundleFile:?]
at org.openhab.binding.zwave.internal.protocol.ZWaveController.sendTransaction(ZWaveController.java:532) [bundleFile:?]
at org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer.processTransaction(ZWaveNodeInitStageAdvancer.java:291) [bundleFile:?]
at org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer.processTransaction(ZWaveNodeInitStageAdvancer.java:264) [bundleFile:?]
at org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer.doInitialStages(ZWaveNodeInitStageAdvancer.java:442) [bundleFile:?]
at org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer$1.run(ZWaveNodeInitStageAdvancer.java:188) [bundleFile:?]
Caused by: java.lang.InterruptedException
at java.lang.Object.wait(Native Method) ~[?:?]
at java.lang.Object.wait(Object.java:328) ~[?:?]
at org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager$1TransactionWaiter.call(ZWaveTransactionManager.java:1134) ~[?:?]
at org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager$1TransactionWaiter.call(ZWaveTransactionManager.java:1) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628) ~[?:?]
at java.lang.Thread.run(Thread.java:834) ~[?:?]
2021-01-02 18:57:54.812 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 18: Node Init response (0) null
2021-01-02 18:57:54.813 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction manager shutdown
2021-01-02 18:57:54.794 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: sendTransaction exception
2021-01-02 18:57:54.795 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 17: sendTransaction exception
2021-01-02 18:57:54.794 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: sendTransaction exception
2021-01-02 18:57:54.834 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 17: Node Init response (0) null
2021-01-02 18:57:54.835 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 82: Node Init response (0) null
2021-01-02 18:57:54.793 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 26: sendTransaction exception
2021-01-02 18:57:54.793 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 57: sendTransaction exception
2021-01-02 18:57:54.837 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 57: Node Init response (0) null
2021-01-02 18:57:54.838 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 26: Node Init response (0) null
2021-01-02 18:57:54.806 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 20: sendTransaction exception
2021-01-02 18:57:54.842 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 20: Node Init response (0) null
2021-01-02 18:57:54.793 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 19: sendTransaction exception
2021-01-02 18:57:54.844 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 19: Node Init response (0) null
2021-01-02 18:57:54.838 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 27: Node Init response (0) null
2021-01-02 18:57:54.809 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 60: sendTransaction exception
2021-01-02 18:57:54.794 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 65: sendTransaction exception
2021-01-02 18:57:54.853 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 65: Node Init response (0) null
2021-01-02 18:57:54.820 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 61: sendTransaction exception
2021-01-02 18:57:54.852 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 60: Node Init response (0) null
2021-01-02 18:57:54.854 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 61: Node Init response (0) null
2021-01-02 18:57:54.820 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 58: sendTransaction exception
2021-01-02 18:57:54.857 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 58: Node Init response (0) null
2021-01-02 18:57:54.793 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 59: sendTransaction exception
2021-01-02 18:57:54.859 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 59: Node Init response (0) null
2021-01-02 18:57:54.793 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: sendTransaction exception
2021-01-02 18:57:54.863 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 24: Node Init response (0) null
2021-01-02 18:57:54.806 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 25: sendTransaction exception
2021-01-02 18:57:54.819 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 45: sendTransaction exception
2021-01-02 18:57:54.865 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 25: Node Init response (0) null
2021-01-02 18:57:54.865 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 45: Node Init response (0) null
2021-01-02 18:57:54.793 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 16: sendTransaction exception
2021-01-02 18:57:54.868 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 16: Node Init response (0) null
2021-01-02 18:57:54.794 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 6: sendTransaction exception
2021-01-02 18:57:54.809 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 64: sendTransaction exception
2021-01-02 18:57:54.900 [DEBUG] [ve.internal.protocol.ZWaveController] - ZWave controller shutdown
2021-01-02 18:57:54.901 [DEBUG] [zwave.handler.ZWaveControllerHandler] - ZWave network stopped
2021-01-02 18:57:54.901 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Disposing receive thread
2021-01-02 18:57:54.902 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Receive thread dispose
2021-01-02 18:57:54.902 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Disposing serial connection
2021-01-02 18:57:54.937 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Serial connection disposed
2021-01-02 18:57:54.938 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Receive thread dispose
2021-01-02 18:57:54.939 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Disposing serial connection
2021-01-02 18:57:54.939 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Serial connection disposed
2021-01-02 18:57:54.940 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Stopped ZWave serial handler
