I tried to only log the info from the shellyem3 with
log:set DEBUG org.openhab.binding.shelly.device.shellyem3
but didn’t work. Then I set debug for the whole Shelly binding and extracted only the relevant lines (see below)
2024-08-20 19:55:45.295 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyem3-32a72b3d5f: Status update triggered thing initialization
2024-08-20 19:55:45.296 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyem3-32a72b3d5f: Start initializing for thing Shelly warmtepomp, type shellyem3, IP address 192.168.100.49, Gen2: true, CoIoT: true
2024-08-20 19:55:45.296 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler ShellyRelayHandler tried updating the thing status although the handler was already disposed.
2024-08-20 19:56:18.499 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyem3-32a72b3d5f: Stopping Thing
2024-08-20 19:56:18.500 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyem3-32a72b3d5f: Shutting down
2024-08-20 19:56:18.500 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyem3-32a72b3d5f: Shelly statusJob stopped
2024-08-20 19:56:18.501 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyem3-32a72b3d5f: Shutting down
2024-08-20 19:56:24.785 [DEBUG] [shelly.internal.ShellyHandlerFactory] - Shelly warmtepomp: Create new thing of type shelly:shellyem3 using ShellyRelayHandler
2024-08-20 19:56:24.800 [DEBUG] [shelly.internal.ShellyHandlerFactory] - Thing handler for uid shelly:shellyem3:32a72b3d5f added, total things = 36
2024-08-20 19:56:26.806 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyem3-32a72b3d5f: Using default userId admin from binding config2024-08-20 19:56:26.807 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyem3-32a72b3d5f: Using default password from bindingConfig (userId=admin)
2024-08-20 19:56:26.826 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyem3-32a72b3d5f: Config: Device address=192.168.100.49, HTTP user/password=admin/***, update interval=60
Events: Button: false, Switch (on/off): false, Push: false, Roller: trueSensor: true, CoIoT: true
Blu Gateway=false, Range Extender: true
2024-08-20 19:56:26.826 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyem3-32a72b3d5f: Start initializing for thing Shelly warmtepomp, type shellyem3, IP address 192.168.100.49, Gen2: true, CoIoT: true
2024-08-20 19:56:29.903 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyem3-32a72b3d5f: Update status job started, interval=20*3=60sec.
2024-08-20 19:56:48.376 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyem3-32a72b3d5f: Start initializing for thing Shelly warmtepomp, type shellyem3, IP address 192.168.100.49, Gen2: true, CoIoT: true
2024-08-20 19:56:48.376 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler ShellyRelayHandler tried updating the thing status although the handler was already disposed.2024-08-20 19:57:28.907 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyem3-32a72b3d5f: Status update triggered thing initialization
2024-08-20 19:57:28.907 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyem3-32a72b3d5f: Start initializing for thing Shelly warmtepomp, type shellyem3, IP address 192.168.100.49, Gen2: true, CoIoT: true
2024-08-20 19:57:31.983 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyem3-32a72b3d5f: Enabling channel cache (20 updates / 60s)
2024-08-20 19:57:32.309 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shelly1pm-98cdac1f42a5: Channel device#heartBeat updated with 2024-08-20T19:57:32.000+0200 (type class org.openhab.core.library.types.D
2024-08-20 19:58:31.987 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyem3-32a72b3d5f: Start initializing for thing Shelly warmtepomp, type shellyem3, IP address 192.168.100.49, Gen2: true, CoIoT: true
2024-08-20 19:59:57.778 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyem3-32a72b3d5f: Status update triggered thing initialization
2024-08-20 19:59:57.778 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyem3-32a72b3d5f: Start initializing for thing Shelly warmtepomp, type shellyem3, IP address 192.168.100.49, Gen2: true, CoIoT: true
2024-08-20 19:59:57.779 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler ShellyRelayHandler tried updating the thing status although the handler was already disposed.
2024-08-20 19:59:57.779 [DEBUG] [g.shelly.internal.api2.Shelly2ApiRpc] - Shelly warmtepomp: Disconnect Rpc Socket on initialize
I hope this helps.
