I have that item configured as Number:Temperature, so it knows commands are of that type. The main issues (IMO and at least in DSL) in working with Number:Temperature is to ensure var
are defined with the quantity or else they get referenced to absolute zero (Kelvin or Rankin).
Does this mean that the freedom to define an Item Type basically disappeared completely with OH4? Iām not sure I fully understand the consequences her
Again, quite the opposite.
What you define the Item to be in OH 4 is now and forever will be what that item is. If you define it as a Number, it will never suddenly become a Number: Temperature because some binding sent it a value with units.
You now have full control over your Items. Thatās what changed in OH 4. In OH 3 youāre Item type could change out from under you. No longer is that possible.
added |°C in the if-part, but how can I make tempBa2 a QuantityType in the Command-part?
Adding a unit that way only works for constants. When getting the state of the Item you need to use
(MyItem.state as QuantityType<Temperature>)
That tells Rules DSL the role of the state.
addition I would have to redefine my items to Number:Temperature.
This is true.
var
Most of that youāre if stuff has been fixed IIRC. if you do nothing to change it, the values and units you get from the state of the Item will be in the unit of the Item. If youāve not set the unit metadata you should get the system default with is C or F based on whether you are using SI or Imperial units in the regional settings.
Some calculations will convert the operands to K before the operation and then convert back to the unit, but that should be transparent to the user.
Temperature is weird because unlike all the other units, 0 isnāt 0 in all the different units so some calculations are more complicated.
A great deal of work had been done on this since OH 4.0 release.
Thanks for a very interesting an enlightening discussion.
I feel, however, that the bottom line question is still open:
How do I now modify the Setpoint Command to send tempBa2 as a QuantityType?
Nothing will work until I can properly execute a command.
All your hard coded temperatures (i.e. everything in arrayBa2) needs to be defined as a temperature.
val arrayBa2 = newArrayList(20.1|°C, 31.1|°C, 30.1|°C, 29.1|°C, 28.1|°C, 25.1|°C)
Then tempBa2 weāll have units for the comparison as well as sending the command.
Or you can send the command as a String with the unit.
MyItem.sendCommand("66 °C")
Or, if your item has the unit
metadata, any command sent to it without units will have that unit appended. So if youāve set the unit
metadata to ā°Cā and if you command with a plane number, that number will automatically have |°C appended to it.
Thanks !!! Now weāre talking.
I know Iāve stretched your patience a fair bit already, but could you please check if my updated code looks good.
var temp = MS6_Ga_temperature.state as QuantyType<Temperature>
var newCase = 0
// Temp windows Vaca <-10 -10-0 0-10 10-20 >+20
// newCase 0 1 2 3 4 5
if( vacation ) { ... }
else {
if((temp <= -10.0|°C) && (newCase != 1)) { newCase = 1 }
else if((temp > -10.0|°C) && (temp <= 0.0|°C) && (newCase != 2)) { newCase = 2 }
else if((temp > 0.0|°C) && (temp <= 10.0|°C) && (newCase != 3)) { newCase = 3 }
else if((temp > 10.0|°C) && (temp <= 20.0|°C) && (newCase != 4)) { newCase = 4 }
else if(temp > 20.0|°C && (newCase != 5)) { newCase = 5 }
var tempBa2 = arrayBa2.get(newCase)
if(SF_Bath_Setpoint.state as QuantityType<Temperature> != tempBa2) { SF_Bath_Setpoint.sendCommand(tempBa2) }
Again, thanks a million for your patience. Iāve learned a lot.
If it works itās good code. I donāt see anything out of place.
Iām surprised this isnāt causing a problem as it should be Quantity, not Quanty, but whatever. I agree working is good.
Good thing: You are absolutely right.
Sad thing:
Ambiguous feature call.
The extension methods
sendCommand(Item, Number) in BusEvent and
sendCommand(Item, Command) in BusEvent
both match.; line 50, column 1497, length 11
and I have no clue what this means.
Youāve encountered one of the main reasons I recommend against the use of Rules DSL for new rules development. Rules DSL has a half broken typeing system. It punishes you if you try to overspecify the types and then it breaks when you fail to specify the type in other places. Rules DSL no longer has any advantages over the other rules languages and has a lot of significant limitations.
In this case, QuantityType
is both a Number
and a Command
. The Number Item has two sendCommand
methods, one that takes a Number
and one that takes a Command
. Because QuantityType
is both, Rules DSL canāt figure out which sendCommand
method to use. So you have to tell it. You have three options:
SF_Bath_Setpoint.sendCommand(tempBa2 as Number)
SF_Bath_Setpoint.sendCommand(tempBa2 as Command)
SF_Bath_Setpoint.sendCommand(tempBa2.toString)
Iāve spent an insane number of hours trying to just send a value to a thermostat in OH4. Right now it feels impossible, so I give up.
Given all of this, the Zwave binding is in error here and should have an issue filled. When it receives a DecimalType, it should convert it to a QuantityType assuming the system default unit.
Yes yes yes, I think you should absolutely file an issue. PLEASE.DO SO.
Hi all,
I finally have my OH4.2.3 thermostats going. Thanks.
But, with OH4 Iāve now lost the ability to āAdd Items from Textual Definitionā by hitting the + sign.
So how can I now define Items not related to Things?
Iām using quite a few as replacement for OH2 Global Variables and Values.
Thanks.
No, it has moved to the developer tools sectionā¦
Thanks. I found it.
You donāt have to use Items for this. You can use the sharedCache
if that makes more sense.
Thanks Rich,
Iāll look into that.
I have just started OH4.3 64bit on an RPi5B using openhabian 1.9.3 + latest OH4.2.3 Backup. It loaded OK (I guess), but how do I gain access to the new log viewer. Port 9001 is dead.
The release notes just says āopenHAB 4.3 introduces a new log viewer that is integrated into the Main UI:ā but how and where?
Thanks.
In MainUI go to Developer Tools ā Log Viewer.
