Hello, thanks for the hint re. Android App v 18. I just downgraded from v 22 and the connection to the openhab server works again. Question: Will this issue be address in future versions of the app?
My Android app had worked no problem for a long time, than stopped a sometime earlier this year. Now I finally got around to look into it. The only fix that worked was this one to downgrade.
My setup: OpenHab 3.3.0 running as Docker container on Pi4b, local network managed by FritzBox 7590.
Attached are the log files from connction attempts using Android App v22:
Device information
Model: SM-G981B
Manufacturer: samsung
Brand: samsung
Device: x1s
Product: x1sxeea
OS: 12
Display: 1440x2904, 4.0 density
Data usage policy: DataUsagePolicy(canDoLargeTransfers=true, loadIconsWithState=true, autoPlayVideos=true, canDoRefreshes=true), data saver: 1, battery saver: false
--------- beginning of main
10-08 13:33:08.716 7512 7512 I ViewRootImpl@b1fa63d[LogActivity]: ViewPostIme pointer 0
10-08 13:33:08.716 7512 7512 I MSHandlerLifeCycle: isMultiSplitHandlerRequested: windowingMode=1 isFullscreen=true isPopOver=false isHidden=false skipActivityType=false isHandlerType=true this: DecorView@50be3dc[LogActivity]
10-08 13:33:08.749 7512 7512 I MSHandlerLifeCycle: isMultiSplitHandlerRequested: windowingMode=1 isFullscreen=true isPopOver=false isHidden=false skipActivityType=false isHandlerType=true this: DecorView@50be3dc[LogActivity]
10-08 13:33:08.766 7512 7512 I MSHandlerLifeCycle: isMultiSplitHandlerRequested: windowingMode=1 isFullscreen=true isPopOver=false isHidden=false skipActivityType=false isHandlerType=true this: DecorView@50be3dc[LogActivity]
10-08 13:33:08.782 7512 7512 I MSHandlerLifeCycle: isMultiSplitHandlerRequested: windowingMode=1 isFullscreen=true isPopOver=false isHidden=false skipActivityType=false isHandlerType=true this: DecorView@50be3dc[LogActivity]
10-08 13:33:08.793 7512 7512 I MSHandlerLifeCycle: isMultiSplitHandlerRequested: windowingMode=1 isFullscreen=true isPopOver=false isHidden=false skipActivityType=false isHandlerType=true this: DecorView@50be3dc[LogActivity]
10-08 13:33:08.793 7512 7512 I ViewRootImpl@b1fa63d[LogActivity]: ViewPostIme pointer 1
10-08 13:33:08.801 7512 7512 D LogActivity: onOptionsItemSelected()
--------- beginning of events
10-08 13:33:08.810 7512 7512 I wm_on_top_resumed_lost_called: [117785472,org.openhab.habdroid.ui.LogActivity,topStateChangedWhenResumed]
10-08 13:33:08.811 7512 7512 I wm_on_paused_called: [117785472,org.openhab.habdroid.ui.LogActivity,performPause]
10-08 13:33:08.835 7512 7512 I ViewRootImpl@db44903[PreferencesActivity]: handleAppVisibility mAppVisible=false visible=true
10-08 13:33:08.835 7512 7512 I ViewRootImpl@db44903[PreferencesActivity]: stopped(false) old=true
10-08 13:33:08.838 7512 7512 I wm_on_restart_called: [131871975,org.openhab.habdroid.ui.PreferencesActivity,performRestartActivity]
10-08 13:33:08.839 7512 7512 D ServerConfiguration: load: ServerConfiguration(id=2, name=BauschPi4b-lan, localPath=ServerPath(url=http://:8080/, userName=, password=), remotePath=null, sslClientCert=null, defaultSitemap=DefaultSitemap(name=uicomponents_page_1f81eac9cd, label=Landing page), wifiSsids=[BauschPi4b-lan], restrictToWifiSsids=false)
10-08 13:33:08.840 7512 7512 D ServerConfiguration: load: ServerConfiguration(id=3, name=openHAB 3, localPath=ServerPath(url=http://:8080/, userName=, password=), remotePath=null, sslClientCert=null, defaultSitemap=null, wifiSsids=[], restrictToWifiSsids=false)
10-08 13:33:08.841 7512 7512 I wm_on_start_called: [131871975,org.openhab.habdroid.ui.PreferencesActivity,handleStartActivity]
10-08 13:33:08.841 7512 7512 I MSHandlerLifeCycle: isMultiSplitHandlerRequested: windowingMode=1 isFullscreen=true isPopOver=false isHidden=false skipActivityType=false isHandlerType=true this: DecorView@8635d8f[PreferencesActivity]
10-08 13:33:08.841 7512 7512 I MSHandlerLifeCycle: removeMultiSplitHandler: no exist. decor=DecorView@8635d8f[PreferencesActivity]
10-08 13:33:08.841 7512 7512 I ViewRootImpl@db44903[PreferencesActivity]: stopped(false) old=false
10-08 13:33:08.841 7512 7512 I wm_on_resume_called: [131871975,org.openhab.habdroid.ui.PreferencesActivity,RESUME_ACTIVITY]
10-08 13:33:08.841 7512 7512 I wm_on_top_resumed_gained_called: [131871975,org.openhab.habdroid.ui.PreferencesActivity,topWhenResuming]
10-08 13:33:08.850 7512 7561 D OpenGLRenderer: setSurface called with nullptr
10-08 13:33:08.860 7512 7512 I ViewRootImpl@db44903[PreferencesActivity]: Relayout returned: old=(0,0,1440,3200) new=(0,0,1440,3200) req=(1440,3200)0 dur=8 res=0x7 s={true 518949969072} ch=true fn=-1
10-08 13:33:08.861 7512 7561 D OpenGLRenderer: eglCreateWindowSurface
10-08 13:33:08.861 7512 7512 I ViewRootImpl@db44903[PreferencesActivity]: [DP] dp(1) 1 android.view.ViewRootImpl.reportNextDraw:11387 android.view.ViewRootImpl.performTraversals:4185 android.view.ViewRootImpl.doTraversal:2911
10-08 13:33:08.861 7512 7512 D ViewRootImpl@db44903[PreferencesActivity]: Creating frameDrawingCallback nextDrawUseBlastSync=false reportNextDraw=true hasBlurUpdates=false
10-08 13:33:08.861 7512 7512 D ViewRootImpl@db44903[PreferencesActivity]: Creating frameCompleteCallback
10-08 13:33:08.864 7512 7583 D ViewRootImpl@db44903[PreferencesActivity]: Received frameDrawingCallback frameNum=1. Creating transactionCompleteCallback=false
10-08 13:33:08.872 7512 7561 D ViewRootImpl@db44903[PreferencesActivity]: Received frameCompleteCallback lastAcquiredFrameNum=1 lastAttemptedDrawFrameNum=1
10-08 13:33:08.873 7512 7512 I ViewRootImpl@db44903[PreferencesActivity]: [DP] pdf(0) 1 android.view.ViewRootImpl.lambda$addFrameCompleteCallbackIfNeeded$3$ViewRootImpl:4987 android.view.ViewRootImpl$$ExternalSyntheticLambda16.run:6 android.os.Handler.handleCallback:938
10-08 13:33:08.873 7512 7512 I ViewRootImpl@db44903[PreferencesActivity]: [DP] rdf()
10-08 13:33:08.873 7512 7512 D ViewRootImpl@db44903[PreferencesActivity]: reportDrawFinished (fn: -1)
10-08 13:33:08.887 7512 7512 D InsetsSourceConsumer: ensureControlAlpha: for ITYPE_NAVIGATION_BAR on org.openhab.habdroid/org.openhab.habdroid.ui.PreferencesActivity
10-08 13:33:08.888 7512 7512 D InsetsSourceConsumer: ensureControlAlpha: for ITYPE_STATUS_BAR on org.openhab.habdroid/org.openhab.habdroid.ui.PreferencesActivity
10-08 13:33:08.889 7512 7512 I ViewRootImpl@b1fa63d[LogActivity]: MSG_WINDOW_FOCUS_CHANGED 0 1
10-08 13:33:08.903 7512 7512 I ViewRootImpl@db44903[PreferencesActivity]: MSG_WINDOW_FOCUS_CHANGED 1 1
10-08 13:33:08.903 7512 7512 D InputMethodManager: startInputInner - Id : 0
10-08 13:33:08.903 7512 7512 I InputMethodManager: startInputInner - mService.startInputOrWindowGainedFocus
10-08 13:33:08.916 7512 7512 I wm_on_idle_called: {org.openhab.habdroid/org.openhab.habdroid.ui.PreferencesActivity}
10-08 13:33:09.183 7512 7512 I ViewRootImpl@b1fa63d[LogActivity]: handleAppVisibility mAppVisible=true visible=false
10-08 13:33:09.200 7512 7561 D OpenGLRenderer: setSurface called with nullptr
10-08 13:33:09.200 7512 7561 D OpenGLRenderer: setSurface() destroyed EGLSurface
10-08 13:33:09.200 7512 7561 D OpenGLRenderer: destroyEglSurface
10-08 13:33:09.202 7512 7561 D OpenGLRenderer: endAllActiveAnimators on 0x7863e1b9d0 (RippleDrawable) with handle 0x7773dcbec0
10-08 13:33:09.211 7512 7512 I ViewRootImpl@b1fa63d[LogActivity]: Relayout returned: old=(0,0,1440,3200) new=(0,0,1440,3200) req=(1440,3200)8 dur=8 res=0x5 s={false 0} ch=true fn=1649
10-08 13:33:09.212 7512 7512 I ViewRootImpl@b1fa63d[LogActivity]: stopped(true) old=false
10-08 13:33:09.213 7512 7512 I wm_on_stop_called: [117785472,org.openhab.habdroid.ui.LogActivity,LIFECYCLER_STOP_ACTIVITY]
10-08 13:33:09.214 7512 7512 I MSHandlerLifeCycle: isMultiSplitHandlerRequested: windowingMode=1 isFullscreen=true isPopOver=false isHidden=false skipActivityType=false isHandlerType=true this: DecorView@50be3dc[LogActivity]
10-08 13:33:09.215 7512 7512 I MSHandlerLifeCycle: removeMultiSplitHandler: no exist. decor=DecorView@50be3dc[LogActivity]
10-08 13:33:09.216 7512 7512 I wm_on_destroy_called: [117785472,org.openhab.habdroid.ui.LogActivity,performDestroy]
10-08 13:33:09.216 7512 7512 I MSHandlerLifeCycle: removeMultiSplitHandler: no exist. decor=DecorView@50be3dc[LogActivity]
10-08 13:33:09.217 7512 7561 D OpenGLRenderer: setSurface called with nullptr
10-08 13:33:09.217 7512 7512 I ViewRootImpl@b1fa63d[LogActivity]: dispatchDetachedFromWindow
10-08 13:33:09.223 7512 7512 D InputTransport: Input channel destroyed: 'cee15f ', fd=154
10-08 13:33:10.622 7512 7512 I ViewRootImpl@db44903[PreferencesActivity]: ViewPostIme pointer 0
10-08 13:33:10.622 7512 7512 I MSHandlerLifeCycle: isMultiSplitHandlerRequested: windowingMode=1 isFullscreen=true isPopOver=false isHidden=false skipActivityType=false isHandlerType=true this: DecorView@8635d8f[PreferencesActivity]
10-08 13:33:10.649 7512 7512 I MSHandlerLifeCycle: isMultiSplitHandlerRequested: windowingMode=1 isFullscreen=true isPopOver=false isHidden=false skipActivityType=false isHandlerType=true this: DecorView@8635d8f[PreferencesActivity]
10-08 13:33:10.664 7512 7512 I MSHandlerLifeCycle: isMultiSplitHandlerRequested: windowingMode=1 isFullscreen=true isPopOver=false isHidden=false skipActivityType=false isHandlerType=true this: DecorView@8635d8f[PreferencesActivity]
10-08 13:33:10.672 7512 7512 I MSHandlerLifeCycle: isMultiSplitHandlerRequested: windowingMode=1 isFullscreen=true isPopOver=false isHidden=false skipActivityType=false isHandlerType=true this: DecorView@8635d8f[PreferencesActivity]
10-08 13:33:10.673 7512 7512 I ViewRootImpl@db44903[PreferencesActivity]: ViewPostIme pointer 1
10-08 13:33:10.673 7512 7512 I MSHandlerLifeCycle: isMultiSplitHandlerRequested: windowingMode=1 isFullscreen=true isPopOver=false isHidden=false skipActivityType=false isHandlerType=true this: DecorView@8635d8f[PreferencesActivity]
10-08 13:33:10.692 7512 7512 I wm_on_top_resumed_lost_called: [131871975,org.openhab.habdroid.ui.PreferencesActivity,topStateChangedWhenResumed]
10-08 13:33:10.693 7512 7512 I wm_on_paused_called: [131871975,org.openhab.habdroid.ui.PreferencesActivity,performPause]
10-08 13:33:10.714 7512 7512 I ViewRootImpl@5bf7f7e[MainActivity]: handleAppVisibility mAppVisible=false visible=true
10-08 13:33:10.714 7512 7512 I wm_on_activity_result_called: [234863096,org.openhab.habdroid.ui.MainActivity,ACTIVITY_RESULT]
10-08 13:33:10.714 7512 7512 I ViewRootImpl@5bf7f7e[MainActivity]: stopped(false) old=true
10-08 13:33:10.714 7512 7512 I wm_on_restart_called: [234863096,org.openhab.habdroid.ui.MainActivity,performRestartActivity]
10-08 13:33:10.714 7512 7512 D MainActivity: onStart()
10-08 13:33:10.714 7512 7512 D PageConnectionHolderFragment: onStart(), started false
10-08 13:33:10.715 7512 7512 D ServerConfiguration: load: ServerConfiguration(id=2, name=BauschPi4b-lan, localPath=ServerPath(url=http://:8080/, userName=, password=), remotePath=null, sslClientCert=null, defaultSitemap=DefaultSitemap(name=uicomponents_page_1f81eac9cd, label=Landing page), wifiSsids=[BauschPi4b-lan], restrictToWifiSsids=false)
10-08 13:33:10.715 7512 7512 D ServerConfiguration: load: ServerConfiguration(id=3, name=openHAB 3, localPath=ServerPath(url=http://:8080/, userName=, password=), remotePath=null, sslClientCert=null, defaultSitemap=null, wifiSsids=[], restrictToWifiSsids=false)
10-08 13:33:10.716 7512 7512 D MainActivity: onActiveConnectionChanged()
10-08 13:33:10.721 7512 7512 D ContentController: Update to connection null (message Versuche openHAB-Server-Instanz zu finden…)
10-08 13:33:10.723 7512 7512 D PageConnectionHolderFragment: updateActiveConnections: URL list [], connection null
10-08 13:33:10.725 7512 7512 D ScrollView: initGoToTop
10-08 13:33:10.735 7512 7512 D ServerConfiguration: load: ServerConfiguration(id=2, name=BauschPi4b-lan, localPath=ServerPath(url=http://:8080/, userName=, password=), remotePath=null, sslClientCert=null, defaultSitemap=DefaultSitemap(name=uicomponents_page_1f81eac9cd, label=Landing page), wifiSsids=[BauschPi4b-lan], restrictToWifiSsids=false)
10-08 13:33:10.735 7512 7512 D ServerConfiguration: load: ServerConfiguration(id=3, name=openHAB 3, localPath=ServerPath(url=http://:8080/, userName=, password=), remotePath=null, sslClientCert=null, defaultSitemap=null, wifiSsids=[], restrictToWifiSsids=false)
10-08 13:33:10.738 7512 7512 D ServerConfiguration: load: ServerConfiguration(id=2, name=BauschPi4b-lan, localPath=ServerPath(url=http://:8080/, userName=, password=), remotePath=null, sslClientCert=null, defaultSitemap=DefaultSitemap(name=uicomponents_page_1f81eac9cd, label=Landing page), wifiSsids=[BauschPi4b-lan], restrictToWifiSsids=false)
10-08 13:33:10.739 7512 7512 D ServerConfiguration: load: ServerConfiguration(id=3, name=openHAB 3, localPath=ServerPath(url=http://:8080/, userName=, password=), remotePath=null, sslClientCert=null, defaultSitemap=null, wifiSsids=[], restrictToWifiSsids=false)
10-08 13:33:10.739 7512 7512 D MainActivity: Cannot auto select server: SSID didn't change since the last check
10-08 13:33:10.739 7512 7512 I wm_on_start_called: [234863096,org.openhab.habdroid.ui.MainActivity,handleStartActivity]
10-08 13:33:10.739 7512 7512 D MainActivity: preferenceActivityCallback: ActivityResult{resultCode=RESULT_OK, data=Intent { }}
10-08 13:33:10.739 7512 7512 I MSHandlerLifeCycle: isMultiSplitHandlerRequested: windowingMode=1 isFullscreen=true isPopOver=false isHidden=false skipActivityType=false isHandlerType=true this: DecorView@899fb6[MainActivity]
10-08 13:33:10.739 7512 7512 I MSHandlerLifeCycle: removeMultiSplitHandler: no exist. decor=DecorView@899fb6[MainActivity]
10-08 13:33:10.739 7512 7512 I ViewRootImpl@5bf7f7e[MainActivity]: stopped(false) old=false
10-08 13:33:10.739 7512 7512 D MainActivity: onResume()
10-08 13:33:10.746 7512 7512 D AbstractBaseActivity: Hide snackbar with tag bgTasksMissingPermissionLocation
10-08 13:33:10.746 7512 7512 D AbstractBaseActivity: Queue snackbar with tag bgTasksMissingPermissionLocation
10-08 13:33:10.747 7512 7512 I wm_on_resume_called: [234863096,org.openhab.habdroid.ui.MainActivity,RESUME_ACTIVITY]
10-08 13:33:10.747 7512 7512 I wm_on_top_resumed_gained_called: [234863096,org.openhab.habdroid.ui.MainActivity,topWhenResuming]
10-08 13:33:10.747 7512 7512 I MSHandlerLifeCycle: isMultiSplitHandlerRequested: windowingMode=1 isFullscreen=true isPopOver=false isHidden=false skipActivityType=false isHandlerType=true this: DecorView@899fb6[MainActivity]
10-08 13:33:10.747 7512 7512 I MSHandlerLifeCycle: removeMultiSplitHandler: no exist. decor=DecorView@899fb6[MainActivity]
10-08 13:33:10.747 7512 7512 D MainActivity: onCreateOptionsMenu()
10-08 13:33:10.748 7512 7512 D MainActivity: onPrepareOptionsMenu()
10-08 13:33:10.751 7512 7561 D OpenGLRenderer: setSurface called with nullptr
10-08 13:33:10.761 7512 7512 I ViewRootImpl@5bf7f7e[MainActivity]: Relayout returned: old=(0,0,1440,3200) new=(0,0,1440,3200) req=(1440,3200)0 dur=9 res=0x7 s={true 518949951632} ch=true fn=-1
10-08 13:33:10.761 7512 7561 D OpenGLRenderer: eglCreateWindowSurface
10-08 13:33:10.761 7512 7512 D ScrollView: onsize change changed
10-08 13:33:10.763 7512 7512 I ViewRootImpl@5bf7f7e[MainActivity]: [DP] dp(1) 1 android.view.ViewRootImpl.reportNextDraw:11387 android.view.ViewRootImpl.performTraversals:4185 android.view.ViewRootImpl.doTraversal:2911
10-08 13:33:10.763 7512 7512 D ViewRootImpl@5bf7f7e[MainActivity]: Creating frameDrawingCallback nextDrawUseBlastSync=false reportNextDraw=true hasBlurUpdates=false
10-08 13:33:10.763 7512 7512 D ViewRootImpl@5bf7f7e[MainActivity]: Creating frameCompleteCallback
10-08 13:33:10.764 7512 7582 D ViewRootImpl@5bf7f7e[MainActivity]: Received frameDrawingCallback frameNum=1. Creating transactionCompleteCallback=false
10-08 13:33:10.770 7512 7561 D ViewRootImpl@5bf7f7e[MainActivity]: Received frameCompleteCallback lastAcquiredFrameNum=1 lastAttemptedDrawFrameNum=1
10-08 13:33:10.770 7512 7512 I ViewRootImpl@5bf7f7e[MainActivity]: [DP] pdf(0) 1 android.view.ViewRootImpl.lambda$addFrameCompleteCallbackIfNeeded$3$ViewRootImpl:4987 android.view.ViewRootImpl$$ExternalSyntheticLambda16.run:6 android.os.Handler.handleCallback:938
10-08 13:33:10.770 7512 7512 I ViewRootImpl@5bf7f7e[MainActivity]: [DP] rdf()
10-08 13:33:10.770 7512 7512 D ViewRootImpl@5bf7f7e[MainActivity]: reportDrawFinished (fn: -1)
10-08 13:33:10.771 7512 7512 I AsyncServiceResolver: Discovering service _openhab-server-ssl._tcp.local.
10-08 13:33:10.772 7512 7512 I ViewRootImpl@db44903[PreferencesActivity]: MSG_WINDOW_FOCUS_CHANGED 0 1
10-08 13:33:10.772 7512 7587 I AsyncServiceResolver: IP: fe80::c034:c1ff:fe21:23ab%wlan0
10-08 13:33:10.772 7512 7587 I AsyncServiceResolver: IP: 2001:9e8:2c20:7900:c034:c1ff:fe21:23ab
10-08 13:33:10.772 7512 7587 I AsyncServiceResolver: IP: 2001:9e8:2c20:7900:9d14:d5c7:256d:d30
10-08 13:33:10.772 7512 7587 I AsyncServiceResolver: IP: 192.168.11.31
10-08 13:33:10.772 7512 7587 I AsyncServiceResolver: Selected 192.168.11.31
10-08 13:33:10.772 7512 7512 D BackgroundTasksManager: onReceive() with intent android.net.wifi.STATE_CHANGE
10-08 13:33:10.772 7512 7512 D BackgroundTasksManager: Wifi state changed
10-08 13:33:10.774 7512 7512 D BackgroundTasksManager: Both periodic workers are running
10-08 13:33:10.776 7512 7512 D BackgroundTasksManager: Got value 'ValueWithInfo(value=NO_PERMISSION, mappedValue=null, type=Raw, debugInfo=null)' for send_wifi_ssid
10-08 13:33:10.776 7512 7512 D BackgroundTasksManager: Scheduling work for tag send_wifi_ssid
10-08 13:33:10.785 7512 7512 D InsetsSourceConsumer: ensureControlAlpha: for ITYPE_NAVIGATION_BAR on org.openhab.habdroid/org.openhab.habdroid.ui.MainActivity
10-08 13:33:10.785 7512 7512 D InsetsSourceConsumer: ensureControlAlpha: for ITYPE_STATUS_BAR on org.openhab.habdroid/org.openhab.habdroid.ui.MainActivity
10-08 13:33:10.851 7512 7512 I ViewRootImpl@5bf7f7e[MainActivity]: MSG_WINDOW_FOCUS_CHANGED 1 1
10-08 13:33:10.852 7512 7512 D InputMethodManager: startInputInner - Id : 0
10-08 13:33:10.852 7512 7512 I InputMethodManager: startInputInner - mService.startInputOrWindowGainedFocus
10-08 13:33:10.863 7512 7512 I wm_on_idle_called: {org.openhab.habdroid/org.openhab.habdroid.ui.MainActivity}
10-08 13:33:10.864 7512 7587 D ItemUpdateWorker: Trying to get connection
10-08 13:33:10.865 7512 7563 I WM-Processor: Moving WorkSpec (eb3362ea-8e2d-4d1c-926c-bd42801ef48a) to the foreground
10-08 13:33:10.866 7512 22447 I okhttp.OkHttpClient: --> GET http://:8080/rest/items/Joerg
10-08 13:33:10.866 7512 22447 I okhttp.OkHttpClient: User-Agent: Mozilla/5.0 (Linux; Android 4.0.4; Galaxy Nexus Build/IMM76B) AppleWebKit/535.19 (KHTML, like Gecko) Chrome/18.0.1025.133 Mobile Safari/535.19
10-08 13:33:10.866 7512 22447 I okhttp.OkHttpClient: Cache-Control: no-cache
10-08 13:33:10.866 7512 22447 I okhttp.OkHttpClient: --> END GET
10-08 13:33:10.874 7512 7512 I WM-SystemFgDispatcher: Started foreground service Intent { act=ACTION_START_FOREGROUND cmp=org.openhab.habdroid/androidx.work.impl.foreground.SystemForegroundService (has extras) }
10-08 13:33:10.944 7512 7512 D AbstractBaseActivity: Show snackbar with tag bgTasksMissingPermissionLocation
10-08 13:33:10.978 7512 22447 I okhttp.OkHttpClient: :8080/rest/items/Joerg (112ms)
10-08 13:33:10.978 7512 22447 I okhttp.OkHttpClient: Content-Type: application/json
10-08 13:33:10.978 7512 22447 I okhttp.OkHttpClient: Date: Sat, 08 Oct 2022 11:33:10 GMT
10-08 13:33:10.979 7512 22447 I okhttp.OkHttpClient: Transfer-Encoding: chunked
10-08 13:33:10.979 7512 22447 I okhttp.OkHttpClient: Server: Jetty(9.4.46.v20220331)
10-08 13:33:10.979 7512 22447 I okhttp.OkHttpClient: 10-08 13:33:10.980 7512 7587 E ItemUpdateWorker: Error updating item 'Joerg' to 'ValueWithInfo(value=NO_PERMISSION, mappedValue=null, type=Raw, debugInfo=null)'. Got HTTP error 404
10-08 13:33:10.980 7512 7587 E ItemUpdateWorker: org.openhab.habdroid.util.HttpClient$HttpException: Not Found
10-08 13:33:10.980 7512 7587 E ItemUpdateWorker: at org.openhab.habdroid.util.HttpClient$method$2$2.onResponse(HttpClient.kt:179)
10-08 13:33:10.980 7512 7587 E ItemUpdateWorker: at okhttp3.internal.connection.RealCall$AsyncCall.run(RealCall.kt:519)
10-08 13:33:10.980 7512 7587 E ItemUpdateWorker: at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1137)
10-08 13:33:10.980 7512 7587 E ItemUpdateWorker: at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:637)
10-08 13:33:10.980 7512 7587 E ItemUpdateWorker: at java.lang.Thread.run(Thread.java:1012)
10-08 13:33:10.981 7512 7557 I WM-WorkerWrapper: Worker result FAILURE for Work [ id=eb3362ea-8e2d-4d1c-926c-bd42801ef48a, tags={ itemUploads, server-id-2, org.openhab.habdroid.background.ItemUpdateWorker, send_wifi_ssid } ]
10-08 13:33:10.988 7512 7512 I WM-SystemFgDispatcher: Stopping foreground service
10-08 13:33:11.073 7512 22453 D AsyncServiceResolver: Service added openhab-ssl (5)
10-08 13:33:11.095 7512 7512 I ViewRootImpl@db44903[PreferencesActivity]: handleAppVisibility mAppVisible=true visible=false
10-08 13:33:11.111 7512 7561 D OpenGLRenderer: setSurface called with nullptr
10-08 13:33:11.111 7512 7561 D OpenGLRenderer: setSurface() destroyed EGLSurface
10-08 13:33:11.111 7512 7561 D OpenGLRenderer: destroyEglSurface
10-08 13:33:11.123 7512 7512 I ViewRootImpl@db44903[PreferencesActivity]: Relayout returned: old=(0,0,1440,3200) new=(0,0,1440,3200) req=(1440,3200)8 dur=9 res=0x5 s={false 0} ch=true fn=44
10-08 13:33:11.123 7512 7512 I ViewRootImpl@db44903[PreferencesActivity]: stopped(true) old=false
10-08 13:33:11.124 7512 7512 I wm_on_stop_called: [131871975,org.openhab.habdroid.ui.PreferencesActivity,LIFECYCLER_STOP_ACTIVITY]
10-08 13:33:11.124 7512 7512 I MSHandlerLifeCycle: isMultiSplitHandlerRequested: windowingMode=1 isFullscreen=true isPopOver=false isHidden=false skipActivityType=false isHandlerType=true this: DecorView@8635d8f[PreferencesActivity]
10-08 13:33:11.124 7512 7512 I MSHandlerLifeCycle: removeMultiSplitHandler: no exist. decor=DecorView@8635d8f[PreferencesActivity]
10-08 13:33:11.125 7512 7512 I wm_on_destroy_called: [131871975,org.openhab.habdroid.ui.PreferencesActivity,performDestroy]
10-08 13:33:11.125 7512 7512 I MSHandlerLifeCycle: removeMultiSplitHandler: no exist. decor=DecorView@8635d8f[PreferencesActivity]
10-08 13:33:11.126 7512 7561 D OpenGLRenderer: setSurface called with nullptr
10-08 13:33:11.126 7512 7512 I ViewRootImpl@db44903[PreferencesActivity]: dispatchDetachedFromWindow
10-08 13:33:11.131 7512 7512 D InputTransport: Input channel destroyed: '8cd1239', fd=134
10-08 13:33:13.081 7512 7512 D MainActivity: Failed to discover openHAB server
10-08 13:33:13.082 7512 7512 D ContentController: Indicate missing configuration (resolveAttempted true)
10-08 13:33:13.082 7512 7512 D PageConnectionHolderFragment: updateActiveConnections: URL list [], connection null
10-08 13:33:13.088 7512 7512 D ScrollView: initGoToTop
10-08 13:33:13.105 7512 7512 D ScrollView: onsize change changed
10-08 13:33:13.789 7512 7512 D AbstractBaseActivity: No next snackbar to show
10-08 13:33:16.256 7512 7512 I ViewRootImpl@5bf7f7e[MainActivity]: ViewPostIme pointer 0
10-08 13:33:16.256 7512 7512 I MSHandlerLifeCycle: isMultiSplitHandlerRequested: windowingMode=1 isFullscreen=true isPopOver=false isHidden=false skipActivityType=false isHandlerType=true this: DecorView@899fb6[MainActivity]
10-08 13:33:16.283 7512 7512 I MSHandlerLifeCycle: isMultiSplitHandlerRequested: windowingMode=1 isFullscreen=true isPopOver=false isHidden=false skipActivityType=false isHandlerType=true this: DecorView@899fb6[MainActivity]
10-08 13:33:16.300 7512 7512 I MSHandlerLifeCycle: isMultiSplitHandlerRequested: windowingMode=1 isFullscreen=true isPopOver=false isHidden=false skipActivityType=false isHandlerType=true this: DecorView@899fb6[MainActivity]
10-08 13:33:16.316 7512 7512 I MSHandlerLifeCycle: isMultiSplitHandlerRequested: windowingMode=1 isFullscreen=true isPopOver=false isHidden=false skipActivityType=false isHandlerType=true this: DecorView@899fb6[MainActivity]
10-08 13:33:16.333 7512 7512 I MSHandlerLifeCycle: isMultiSplitHandlerRequested: windowingMode=1 isFullscreen=true isPopOver=false isHidden=false skipActivityType=false isHandlerType=true this: DecorView@899fb6[MainActivity]
10-08 13:33:16.350 7512 7512 I MSHandlerLifeCycle: isMultiSplitHandlerRequested: windowingMode=1 isFullscreen=true isPopOver=false isHidden=false skipActivityType=false isHandlerType=true this: DecorView@899fb6[MainActivity]
10-08 13:33:16.367 7512 7512 I MSHandlerLifeCycle: isMultiSplitHandlerRequested: windowingMode=1 isFullscreen=true isPopOver=false isHidden=false skipActivityType=false isHandlerType=true this: DecorView@899fb6[MainActivity]
10-08 13:33:16.383 7512 7512 I MSHandlerLifeCycle: isMultiSplitHandlerRequested: windowingMode=1 isFullscreen=true isPopOver=false isHidden=false skipActivityType=false isHandlerType=true this: DecorView@899fb6[MainActivity]
10-08 13:33:16.386 7512 7512 I ViewRootImpl@5bf7f7e[MainActivity]: ViewPostIme pointer 1
10-08 13:33:16.386 7512 7512 I MSHandlerLifeCycle: isMultiSplitHandlerRequested: windowingMode=1 isFullscreen=true isPopOver=false isHidden=false skipActivityType=false isHandlerType=true this: DecorView@899fb6[MainActivity]
10-08 13:33:16.395 7512 7512 I wm_on_top_resumed_lost_called: [234863096,org.openhab.habdroid.ui.MainActivity,topStateChangedWhenResumed]
10-08 13:33:16.397 7512 7512 D MainActivity: onPause()
10-08 13:33:16.398 7512 7512 I wm_on_paused_called: [234863096,org.openhab.habdroid.ui.MainActivity,performPause]
10-08 13:33:16.414 7512 7512 I DecorView: [INFO] isPopOver=false, config=true
10-08 13:33:16.414 7512 7512 I DecorView: updateCaptionType >> DecorView@74d17bc[], isFloating=false, isApplication=true, hasWindowControllerCallback=true, hasWindowDecorCaption=false
10-08 13:33:16.414 7512 7512 D DecorView: setCaptionType = 0, this = DecorView@74d17bc[]
10-08 13:33:16.415 7512 7512 I DecorView: getCurrentDensityDpi: from real metrics. densityDpi=640 msg=resources_loaded
10-08 13:33:16.417 7512 7512 I wm_on_create_called: [77731175,org.openhab.habdroid.ui.PreferencesActivity,performCreate]
10-08 13:33:16.420 7512 7512 D RingtoneManager: getActualDefaultRingtoneUri type :2
10-08 13:33:16.420 7512 7512 I RingtoneManager: Ringtone value : content://media/internal/audio/media/25?title=Owl&canonical=1
10-08 13:33:16.420 7512 7512 D Ringtone: highlight offset is : null
10-08 13:33:16.420 7512 7512 V MediaPlayer-JNI: native_setup
10-08 13:33:16.420 7512 7512 V MediaPlayerNative: constructor
10-08 13:33:16.420 7512 7512 V MediaPlayerNative: setListener
10-08 13:33:16.421 7512 7512 D RingtoneManager: getActualDefaultRingtoneUri type :2
10-08 13:33:16.421 7512 7512 I RingtoneManager: Ringtone value : content://media/internal/audio/media/25?title=Owl&canonical=1
10-08 13:33:16.424 7512 7512 V MediaPlayer-JNI: setDataSourceFD: fd 131
10-08 13:33:16.424 7512 7512 V MediaPlayerNative: setDataSource(131, 0, 576460752303423487)
10-08 13:33:16.429 7512 7512 V MediaPlayer-JNI: setParameter: key 1400
10-08 13:33:16.429 7512 7512 V MediaPlayerNative: MediaPlayer::setParameter(1400)
10-08 13:33:16.430 7512 7512 V MediaPlayer-JNI: setVolume: left 1.000000 right 1.000000
10-08 13:33:16.430 7512 7512 V MediaPlayerNative: MediaPlayer::setVolume(1.000000, 1.000000)
10-08 13:33:16.430 7512 7512 V MediaPlayer-JNI: setLooping: 0
10-08 13:33:16.430 7512 7512 V MediaPlayerNative: MediaPlayer::setLooping
10-08 13:33:16.430 7512 7512 V MediaPlayerNative: setVideoSurfaceTexture
10-08 13:33:16.430 7512 7512 V MediaPlayerNative: prepare
10-08 13:33:16.439 7512 7642 V MediaPlayerNative: message received msg=200, ext1=10973, ext2=0
10-08 13:33:16.439 7512 7642 W MediaPlayerNative: info/warning (10973, 0)
10-08 13:33:16.440 7512 7642 V MediaPlayerNative: message received msg=1, ext1=0, ext2=0
10-08 13:33:16.440 7512 7642 V MediaPlayerNative: MediaPlayer::notify() prepared
10-08 13:33:16.440 7512 7642 V MediaPlayerNative: signal application thread
10-08 13:33:16.440 7512 7512 V MediaPlayerNative: prepare complete - status=0
10-08 13:33:16.440 7512 7512 V MediaPlayerNative: invoke 76
10-08 13:33:16.441 7512 7512 D Ringtone: Successfully created local player
10-08 13:33:16.441 7512 7512 D RingtoneManager: getActualDefaultRingtoneUri type :2
10-08 13:33:16.441 7512 7512 I RingtoneManager: Ringtone value : content://media/internal/audio/media/25?title=Owl&canonical=1
10-08 13:33:16.446 7512 7512 D PreferencesActivity: Removing notification prefs for < 25
10-08 13:33:16.450 7512 7512 D ServerConfiguration: load: ServerConfiguration(id=2, name=BauschPi4b-lan, localPath=ServerPath(url=http://:8080/, userName=, password=), remotePath=null, sslClientCert=null, defaultSitemap=DefaultSitemap(name=uicomponents_page_1f81eac9cd, label=Landing page), wifiSsids=[BauschPi4b-lan], restrictToWifiSsids=false)
10-08 13:33:16.451 7512 7512 D ServerConfiguration: load: ServerConfiguration(id=3, name=openHAB 3, localPath=ServerPath(url=http://:8080/, userName=, password=), remotePath=null, sslClientCert=null, defaultSitemap=null, wifiSsids=[], restrictToWifiSsids=false)
10-08 13:33:16.451 7512 7512 I wm_on_start_called: [77731175,org.openhab.habdroid.ui.PreferencesActivity,handleStartActivity]
10-08 13:33:16.451 7512 7512 I wm_on_resume_called: [77731175,org.openhab.habdroid.ui.PreferencesActivity,RESUME_ACTIVITY]
10-08 13:33:16.451 7512 7512 I MSHandlerLifeCycle: isMultiSplitHandlerRequested: ignored. pkg=org.openhab.habdroid parent=null callers=com.android.internal.policy.DecorView.setVisibility:4295 android.app.ActivityThread.handleResumeActivity:5301 android.app.servertransaction.ResumeActivityItem.execute:54 android.app.servertransaction.ActivityTransactionItem.execute:45 android.app.servertransaction.TransactionExecutor.executeLifecycleState:176
10-08 13:33:16.451 7512 7512 I MSHandlerLifeCycle: removeMultiSplitHandler: no exist. decor=DecorView@74d17bc[]
10-08 13:33:16.458 7512 7512 I ViewRootImpl@3bbf923[PreferencesActivity]: setView = com.android.internal.policy.DecorView@74d17bc TM=true
10-08 13:33:16.458 7512 7512 I MSHandlerLifeCycle: isMultiSplitHandlerRequested: windowingMode=1 isFullscreen=true isPopOver=false isHidden=false skipActivityType=false isHandlerType=true this: DecorView@74d17bc[PreferencesActivity]
10-08 13:33:16.458 7512 7512 I MSHandlerLifeCycle: removeMultiSplitHandler: no exist. decor=DecorView@74d17bc[PreferencesActivity]
10-08 13:33:16.458 7512 7512 I wm_on_top_resumed_gained_called: [77731175,org.openhab.habdroid.ui.PreferencesActivity,topStateChangedWhenResumed]
10-08 13:33:16.468 7512 7512 I ViewRootImpl@3bbf923[PreferencesActivity]: Relayout returned: old=(0,0,1440,3200) new=(0,0,1440,3200) req=(1440,3200)0 dur=4 res=0x7 s={true 518949969072} ch=true fn=-1
10-08 13:33:16.468 7512 7561 D OpenGLRenderer: eglCreateWindowSurface
10-08 13:33:16.497 7512 7512 I ViewRootImpl@3bbf923[PreferencesActivity]: [DP] dp(1) 1 android.view.ViewRootImpl.reportNextDraw:11387 android.view.ViewRootImpl.performTraversals:4185 android.view.ViewRootImpl.doTraversal:2911
10-08 13:33:16.497 7512 7512 D ViewRootImpl@3bbf923[PreferencesActivity]: Creating frameDrawingCallback nextDrawUseBlastSync=false reportNextDraw=true hasBlurUpdates=false
10-08 13:33:16.497 7512 7512 D ViewRootImpl@3bbf923[PreferencesActivity]: Creating frameCompleteCallback
10-08 13:33:16.498 7512 7582 D ViewRootImpl@3bbf923[PreferencesActivity]: Received frameDrawingCallback frameNum=1. Creating transactionCompleteCallback=false
10-08 13:33:16.502 7512 7561 D ViewRootImpl@3bbf923[PreferencesActivity]: Received frameCompleteCallback lastAcquiredFrameNum=1 lastAttemptedDrawFrameNum=1
10-08 13:33:16.504 7512 7512 I ViewRootImpl@3bbf923[PreferencesActivity]: [DP] pdf(0) 1 android.view.ViewRootImpl.lambda$addFrameCompleteCallbackIfNeeded$3$ViewRootImpl:4987 android.view.ViewRootImpl$$ExternalSyntheticLambda16.run:6 android.os.Handler.handleCallback:938
10-08 13:33:16.504 7512 7512 I ViewRootImpl@3bbf923[PreferencesActivity]: [DP] rdf()
10-08 13:33:16.504 7512 7512 D ViewRootImpl@3bbf923[PreferencesActivity]: reportDrawFinished (fn: -1)
10-08 13:33:16.504 7512 7512 V MediaPlayerNative: invoke 76
10-08 13:33:16.506 7512 7512 I ViewRootImpl@5bf7f7e[MainActivity]: MSG_WINDOW_FOCUS_CHANGED 0 1
10-08 13:33:16.513 7512 7512 D InsetsSourceConsumer: ensureControlAlpha: for ITYPE_NAVIGATION_BAR on org.openhab.habdroid/org.openhab.habdroid.ui.PreferencesActivity
10-08 13:33:16.514 7512 7512 D InsetsSourceConsumer: ensureControlAlpha: for ITYPE_STATUS_BAR on org.openhab.habdroid/org.openhab.habdroid.ui.PreferencesActivity
10-08 13:33:16.521 7512 7512 I wm_on_idle_called: {org.openhab.habdroid/org.openhab.habdroid.ui.PreferencesActivity}
10-08 13:33:16.535 7512 7512 I ViewRootImpl@3bbf923[PreferencesActivity]: MSG_WINDOW_FOCUS_CHANGED 1 1
10-08 13:33:16.536 7512 7512 D InputMethodManager: startInputInner - Id : 0
10-08 13:33:16.536 7512 7512 I InputMethodManager: startInputInner - mService.startInputOrWindowGainedFocus
10-08 13:33:16.937 7512 7512 I ViewRootImpl@5bf7f7e[MainActivity]: handleAppVisibility mAppVisible=true visible=false
10-08 13:33:16.952 7512 7561 D OpenGLRenderer: setSurface called with nullptr
10-08 13:33:16.952 7512 7561 D OpenGLRenderer: setSurface() destroyed EGLSurface
10-08 13:33:16.952 7512 7561 D OpenGLRenderer: destroyEglSurface
10-08 13:33:16.963 7512 7512 I ViewRootImpl@5bf7f7e[MainActivity]: Relayout returned: old=(0,0,1440,3200) new=(0,0,1440,3200) req=(1440,3200)8 dur=7 res=0x5 s={false 0} ch=true fn=173
10-08 13:33:16.966 7512 7512 I ViewRootImpl@5bf7f7e[MainActivity]: stopped(true) old=false
10-08 13:33:16.976 7512 7512 D MainActivity: onStop()
10-08 13:33:16.977 7512 7512 D PageConnectionHolderFragment: onStop()
10-08 13:33:16.978 7512 7512 I wm_on_stop_called: [234863096,org.openhab.habdroid.ui.MainActivity,STOP_ACTIVITY_ITEM]
10-08 13:33:16.978 7512 7512 D MainActivity: onSaveInstanceState()
10-08 13:33:16.978 7512 7512 D ContentController: onSaveInstanceState()
10-08 13:33:16.979 7512 7512 I MSHandlerLifeCycle: isMultiSplitHandlerRequested: windowingMode=1 isFullscreen=true isPopOver=false isHidden=false skipActivityType=false isHandlerType=true this: DecorView@899fb6[MainActivity]
10-08 13:33:16.979 7512 7512 I MSHandlerLifeCycle: removeMultiSplitHandler: no exist. decor=DecorView@899fb6[MainActivity]
10-08 13:33:16.988 7512 7512 I ViewRootImpl@5bf7f7e[MainActivity]: Relayout returned: old=(0,0,1440,3200) new=(0,0,1440,3200) req=(1440,3200)8 dur=8 res=0x5 s={false 0} ch=false fn=-1
10-08 13:33:17.512 7512 7512 I ViewRootImpl@3bbf923[PreferencesActivity]: ViewPostIme pointer 0
10-08 13:33:17.512 7512 7512 I MSHandlerLifeCycle: isMultiSplitHandlerRequested: windowingMode=1 isFullscreen=true isPopOver=false isHidden=false skipActivityType=false isHandlerType=true this: DecorView@74d17bc[PreferencesActivity]
10-08 13:33:17.530 7512 7512 I MSHandlerLifeCycle: isMultiSplitHandlerRequested: windowingMode=1 isFullscreen=true isPopOver=false isHidden=false skipActivityType=false isHandlerType=true this: DecorView@74d17bc[PreferencesActivity]
10-08 13:33:17.546 7512 7512 I MSHandlerLifeCycle: isMultiSplitHandlerRequested: windowingMode=1 isFullscreen=true isPopOver=false isHidden=false skipActivityType=false isHandlerType=true this: DecorView@74d17bc[PreferencesActivity]
10-08 13:33:17.563 7512 7512 I MSHandlerLifeCycle: isMultiSplitHandlerRequested: windowingMode=1 isFullscreen=true isPopOver=false isHidden=false skipActivityType=false isHandlerType=true this: DecorView@74d17bc[PreferencesActivity]
10-08 13:33:17.580 7512 7512 I MSHandlerLifeCycle: isMultiSplitHandlerRequested: windowingMode=1 isFullscreen=true isPopOver=false isHidden=false skipActivityType=false isHandlerType=true this: DecorView@74d17bc[PreferencesActivity]
10-08 13:33:17.597 7512 7512 I MSHandlerLifeCycle: isMultiSplitHandlerRequested: windowingMode=1 isFullscreen=true isPopOver=false isHidden=false skipActivityType=false isHandlerType=true this: DecorView@74d17bc[PreferencesActivity]
10-08 13:33:17.613 7512 7512 I MSHandlerLifeCycle: isMultiSplitHandlerRequested: windowingMode=1 isFullscreen=true isPopOver=false isHidden=false skipActivityType=false isHandlerType=true this: DecorView@74d17bc[PreferencesActivity]
10-08 13:33:17.624 7512 7512 I MSHandlerLifeCycle: isMultiSplitHandlerRequested: windowingMode=1 isFullscreen=true isPopOver=false isHidden=false skipActivityType=false isHandlerType=true this: DecorView@74d17bc[PreferencesActivity]
10-08 13:33:17.626 7512 7512 I ViewRootImpl@3bbf923[PreferencesActivity]: ViewPostIme pointer 1
10-08 13:33:17.628 7512 7512 I MSHandlerLifeCycle: isMultiSplitHandlerRequested: windowingMode=1 isFullscreen=true isPopOver=false isHidden=false skipActivityType=false isHandlerType=true this: DecorView@74d17bc[PreferencesActivity]
10-08 13:33:17.672 7512 7512 W ListPreference: Setting a summary with a String formatting marker is no longer supported. You should use a SummaryProvider instead.
10-08 13:33:17.721 7512 7512 W ListPreference: Setting a summary with a String formatting marker is no longer supported. You should use a SummaryProvider instead.
10-08 13:33:18.383 7512 7512 I ViewRootImpl@3bbf923[PreferencesActivity]: ViewPostIme pointer 0
10-08 13:33:18.383 7512 7512 I MSHandlerLifeCycle: isMultiSplitHandlerRequested: windowingMode=1 isFullscreen=true isPopOver=false isHidden=false skipActivityType=false isHandlerType=true this: DecorView@74d17bc[PreferencesActivity]
10-08 13:33:18.411 7512 7512 I MSHandlerLifeCycle: isMultiSplitHandlerRequested: windowingMode=1 isFullscreen=true isPopOver=false isHidden=false skipActivityType=false isHandlerType=true this: DecorView@74d17bc[PreferencesActivity]
10-08 13:33:18.428 7512 7512 I MSHandlerLifeCycle: isMultiSplitHandlerRequested: windowingMode=1 isFullscreen=true isPopOver=false isHidden=false skipActivityType=false isHandlerType=true this: DecorView@74d17bc[PreferencesActivity]
10-08 13:33:18.445 7512 7512 I MSHandlerLifeCycle: isMultiSplitHandlerRequested: windowingMode=1 isFullscreen=true isPopOver=false isHidden=false skipActivityType=false isHandlerType=true this: DecorView@74d17bc[PreferencesActivity]
10-08 13:33:18.461 7512 7512 I MSHandlerLifeCycle: isMultiSplitHandlerRequested: windowingMode=1 isFullscreen=true isPopOver=false isHidden=false skipActivityType=false isHandlerType=true this: DecorView@74d17bc[PreferencesActivity]
10-08 13:33:18.478 7512 7512 I MSHandlerLifeCycle: isMultiSplitHandlerRequested: windowingMode=1 isFullscreen=true isPopOver=false isHidden=false skipActivityType=false isHandlerType=true this: DecorView@74d17bc[PreferencesActivity]
10-08 13:33:18.481 7512 7512 I MSHandlerLifeCycle: isMultiSplitHandlerRequested: windowingMode=1 isFullscreen=true isPopOver=false isHidden=false skipActivityType=false isHandlerType=true this: DecorView@74d17bc[PreferencesActivity]
10-08 13:33:18.481 7512 7512 I ViewRootImpl@3bbf923[PreferencesActivity]: ViewPostIme pointer 1
10-08 13:33:19.489 7512 7512 I ViewRootImpl@3bbf923[PreferencesActivity]: ViewPostIme pointer 0
10-08 13:33:19.490 7512 7512 I MSHandlerLifeCycle: isMultiSplitHandlerRequested: windowingMode=1 isFullscreen=true isPopOver=false isHidden=false skipActivityType=false isHandlerType=true this: DecorView@74d17bc[PreferencesActivity]
10-08 13:33:19.526 7512 7512 I MSHandlerLifeCycle: isMultiSplitHandlerRequested: windowingMode=1 isFullscreen=true isPopOver=false isHidden=false skipActivityType=false isHandlerType=true this: DecorView@74d17bc[PreferencesActivity]
10-08 13:33:19.542 7512 7512 I MSHandlerLifeCycle: isMultiSplitHandlerRequested: windowingMode=1 isFullscreen=true isPopOver=false isHidden=false skipActivityType=false isHandlerType=true this: DecorView@74d17bc[PreferencesActivity]
10-08 13:33:19.559 7512 7512 I MSHandlerLifeCycle: isMultiSplitHandlerRequested: windowingMode=1 isFullscreen=true isPopOver=false isHidden=false skipActivityType=false isHandlerType=true this: DecorView@74d17bc[PreferencesActivity]
10-08 13:33:19.562 7512 7512 I MSHandlerLifeCycle: isMultiSplitHandlerRequested: windowingMode=1 isFullscreen=true isPopOver=false isHidden=false skipActivityType=false isHandlerType=true this: DecorView@74d17bc[PreferencesActivity]
10-08 13:33:19.562 7512 7512 I ViewRootImpl@3bbf923[PreferencesActivity]: ViewPostIme pointer 1
10-08 13:33:19.593 7512 7512 I wm_on_top_resumed_lost_called: [77731175,org.openhab.habdroid.ui.PreferencesActivity,topStateChangedWhenResumed]
10-08 13:33:19.598 7512 7512 I wm_on_paused_called: [77731175,org.openhab.habdroid.ui.PreferencesActivity,performPause]
10-08 13:33:19.619 7512 7512 I DecorView: [INFO] isPopOver=false, config=true
10-08 13:33:19.620 7512 7512 I DecorView: updateCaptionType >> DecorView@c584f15[], isFloating=false, isApplication=true, hasWindowControllerCallback=true, hasWindowDecorCaption=false
10-08 13:33:19.620 7512 7512 D DecorView: setCaptionType = 0, this = DecorView@c584f15[]
10-08 13:33:19.621 7512 7512 I DecorView: getCurrentDensityDpi: from real metrics. densityDpi=640 msg=resources_loaded
10-08 13:33:19.627 7512 7512 D ScrollView: initGoToTop
10-08 13:33:19.629 7512 7512 I wm_on_create_called: [144491731,org.openhab.habdroid.ui.LogActivity,performCreate]
10-08 13:33:19.629 7512 7512 I wm_on_start_called: [144491731,org.openhab.habdroid.ui.LogActivity,handleStartActivity]
10-08 13:33:19.630 7512 7512 I wm_on_resume_called: [144491731,org.openhab.habdroid.ui.LogActivity,RESUME_ACTIVITY]
10-08 13:33:19.630 7512 7512 I MSHandlerLifeCycle: isMultiSplitHandlerRequested: ignored. pkg=org.openhab.habdroid parent=null callers=com.android.internal.policy.DecorView.setVisibility:4295 android.app.ActivityThread.handleResumeActivity:5301 android.app.servertransaction.ResumeActivityItem.execute:54 android.app.servertransaction.ActivityTransactionItem.execute:45 android.app.servertransaction.TransactionExecutor.executeLifecycleState:176
10-08 13:33:19.630 7512 7512 I MSHandlerLifeCycle: removeMultiSplitHandler: no exist. decor=DecorView@c584f15[]
10-08 13:33:19.634 7512 7512 I ViewRootImpl@19032a2[LogActivity]: setView = com.android.internal.policy.DecorView@c584f15 TM=true
10-08 13:33:19.634 7512 7512 I MSHandlerLifeCycle: isMultiSplitHandlerRequested: windowingMode=1 isFullscreen=true isPopOver=false isHidden=false skipActivityType=false isHandlerType=true this: DecorView@c584f15[LogActivity]
10-08 13:33:19.634 7512 7512 I MSHandlerLifeCycle: removeMultiSplitHandler: no exist. decor=DecorView@c584f15[LogActivity]
10-08 13:33:19.635 7512 7512 I wm_on_top_resumed_gained_called: [144491731,org.openhab.habdroid.ui.LogActivity,topStateChangedWhenResumed]
10-08 13:33:19.643 7512 7512 I ViewRootImpl@19032a2[LogActivity]: Relayout returned: old=(0,0,1440,3200) new=(0,0,1440,3200) req=(1440,3200)0 dur=6 res=0x7 s={true 518949951632} ch=true fn=-1
10-08 13:33:19.644 7512 7561 D OpenGLRenderer: eglCreateWindowSurface
10-08 13:33:19.644 7512 7512 D ScrollView: onsize change changed
10-08 13:33:19.645 7512 7512 I ViewRootImpl@19032a2[LogActivity]: [DP] dp(1) 1 android.view.ViewRootImpl.reportNextDraw:11387 android.view.ViewRootImpl.performTraversals:4185 android.view.ViewRootImpl.doTraversal:2911
10-08 13:33:19.645 7512 7512 D ViewRootImpl@19032a2[LogActivity]: Creating frameDrawingCallback nextDrawUseBlastSync=false reportNextDraw=true hasBlurUpdates=false
10-08 13:33:19.645 7512 7512 D ViewRootImpl@19032a2[LogActivity]: Creating frameCompleteCallback
10-08 13:33:19.650 7512 7582 D ViewRootImpl@19032a2[LogActivity]: Received frameDrawingCallback frameNum=1. Creating transactionCompleteCallback=false
10-08 13:33:19.652 7512 7561 D ViewRootImpl@19032a2[LogActivity]: Received frameCompleteCallback lastAcquiredFrameNum=1 lastAttemptedDrawFrameNum=1
10-08 13:33:19.653 7512 7512 I ViewRootImpl@19032a2[LogActivity]: [DP] pdf(0) 1 android.view.ViewRootImpl.lambda$addFrameCompleteCallbackIfNeeded$3$ViewRootImpl:4987 android.view.ViewRootImpl$$ExternalSyntheticLambda16.run:6 android.os.Handler.handleCallback:938
10-08 13:33:19.653 7512 7512 I ViewRootImpl@19032a2[LogActivity]: [DP] rdf()
10-08 13:33:19.653 7512 7512 D ViewRootImpl@19032a2[LogActivity]: reportDrawFinished (fn: -1)
10-08 13:33:19.653 7512 7512 I ViewRootImpl@3bbf923[PreferencesActivity]: MSG_WINDOW_FOCUS_CHANGED 0 1
10-08 13:33:19.654 7512 7512 D LogActivity: onCreateOptionsMenu()
10-08 13:33:19.672 7512 7512 D InsetsSourceConsumer: ensureControlAlpha: for ITYPE_NAVIGATION_BAR on org.openhab.habdroid/org.openhab.habdroid.ui.LogActivity
10-08 13:33:19.672 7512 7512 D InsetsSourceConsumer: ensureControlAlpha: for ITYPE_STATUS_BAR on org.openhab.habdroid/org.openhab.habdroid.ui.LogActivity
10-08 13:33:19.693 7512 7512 I ViewRootImpl@19032a2[LogActivity]: MSG_WINDOW_FOCUS_CHANGED 1 1
10-08 13:33:19.693 7512 7512 D InputMethodManager: startInputInner - Id : 0
10-08 13:33:19.693 7512 7512 I InputMethodManager: startInputInner - mService.startInputOrWindowGainedFocus
Thank you for any hints!
