I tried to install a binding manually.
Now the status of my things is “ERROR:HANDLER” and I get following log message:
2023-09-08 18:11:05.602 [ERROR] [Events.Framework ] - FrameworkEvent ERROR
java.lang.IllegalStateException: Configuration Admin service has been unregistered
at org.apache.felix.cm.impl.ConfigurationAdminImpl.getConfigurationManager(ConfigurationAdminImpl.java:325) ~[?:?]
at org.apache.felix.cm.impl.ConfigurationAdminImpl.getConfiguration(ConfigurationAdminImpl.java:156) ~[?:?]
at org.apache.karaf.log.core.internal.LogServiceImpl.getConfiguration(LogServiceImpl.java:129) ~[?:?]
at org.apache.karaf.log.core.internal.LogServiceImpl.setLevel(LogServiceImpl.java:111) ~[?:?]
at org.apache.karaf.log.command.LogTail$LogServiceTracker.removedService(LogTail.java:103) ~[?:?]
at org.apache.karaf.log.command.LogTail$LogServiceTracker.removedService(LogTail.java:76) ~[?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerRemoved(ServiceTracker.java:969) ~[osgi.core-8.0.0.jar:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerRemoved(ServiceTracker.java:871) ~[osgi.core-8.0.0.jar:?]
at org.osgi.util.tracker.AbstractTracked.untrack(AbstractTracked.java:341) ~[osgi.core-8.0.0.jar:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:911) ~[osgi.core-8.0.0.jar:?]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:123) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:961) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:151) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:937) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:874) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.unregister(ServiceRegistrationImpl.java:241) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.apache.karaf.util.tracker.BaseActivator.doStop(BaseActivator.java:146) ~[?:?]
at org.apache.karaf.util.tracker.BaseActivator.stop(BaseActivator.java:108) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:875) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1) ~[org.eclipse.osgi-3.18.0.jar:?]
at java.security.AccessController.doPrivileged(AccessController.java:569) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.stop(BundleContextImpl.java:867) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.stopWorker0(EquinoxBundle.java:1046) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.stopWorker(EquinoxBundle.java:376) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.container.Module.doStop(Module.java:660) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.container.Module.stop(Module.java:521) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.decStartLevel(ModuleContainer.java:1888) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1763) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.container.SystemModule.stopWorker(SystemModule.java:275) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule.stopWorker(EquinoxBundle.java:208) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.container.SystemModule.stop(SystemModule.java:207) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule$1.run(EquinoxBundle.java:226) ~[org.eclipse.osgi-3.18.0.jar:?]
at java.lang.Thread.run(Thread.java:833) ~[?:?]
I removed the binding, rebooted the OS multiple times, restarted OH multiple times and cleared the cache. What to do now?
Platform information:
- Hardware: RPI4 8GB
- OS: Ubuntu 22.04 LTS arm64
- Java Runtime Environment: Zulu17.44+15-CA (build 17.0.8+7-LTS)
- openHAB version: 4.0.2
Edit:
I decided to apt purge
and apt install
openhab. Doesn’t help. OH seems to stuck while starting.
openhab> log:tail
16:42:09.505 [INFO ] [org.openhab.core.Activator ] - Starting openHAB 4.0.2 (build Release Build)
16:42:29.110 [WARN ] [org.openhab.core.net.NetUtil ] - Found multiple local interfaces - ignoring 192.168.179.3
16:42:29.114 [WARN ] [org.openhab.core.net.NetUtil ] - Found multiple local interfaces - ignoring 192.168.178.56
16:42:39.787 [INFO ] [b.core.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
16:42:45.839 [INFO ] [re.automation.internal.RuleEngineImpl] - Rule engine started.
16:43:16.192 [WARN ] [sshd.server.session.ServerSessionImpl] - exceptionCaught(ServerSessionImpl[null@/127.0.0.1:48936])[state=Opened] IOException: Broken pipe
Does anyone know what to do to be able to install openhab again and start from scratch?
Edit: installed OH using openhabian (unattended). No luck.
Next I will try it with removing and installing java.
