When switching the OH2 from Raspi in a container to QNAP NAS via https://github.com/openhab/openhab-qnap-qpkg/releases2.2.0-1 I have problems with the registration on the terminal of the MAC. I would like to update to M 2.5 with the config tool.
ssh openhab@IP ----PW habopen or openhab are not accepted.
@Kai I was going to suggest that the OP o[pen an issue, but when looking at the open issues, it appears this had been abandoned and not updated for 2.4 ??
Depending on your ssh configuration it may be necessary to ssh into the physical box first, then from there ssh into openhab. This was the case on my docker setup on Synology (because ssh per default was configured to only allow access from localhost)
I’d suggest you try that. If it works then you can look into relaxing the ssh security configuration to avoid the extra step.
ssh: connect to host localhost port 8101: Connection refused
I get into the box without any problems, from there I can also go to the container station and from there call OH.
Then I see the start page with the UIs.
I can also access the UIs from the browser using http: // IP: 32834 / start / index.
