Oh-input datepicker parameters not working
I’d be grateful for any guidance on using a datepicker oh-input widget.
It seems to work except for anything under the calendarParams (or calendar-params, I’ve tried both).
My simple widget just for testing so far is as follows
uid: datePicker
tags: []
props:
  parameters: []
  parameterGroups: []
timestamp: Jun 7, 2024, 8:03:49 AM
component: f7-block
config: []
slots:
  default:
    - component: oh-input
        type: datepicker
        validate: true
        required: true
        item: TestDate
        outline: false
        sendButton: true
        calendar-params:
          locale: en-GB
          dateFormat: d mmmm yyyy
          closeOnSelect: true
Properties such as sendButton work correctly but the properties under calendarParams don’t. I can’t change the date format (moreover Chrome shows it in US m.d.y format and Firefox in Eurpean d.m.y format) and I can’t get the datepicker to close on a click on a date.
I have tried all sorts of variations but other people seem to be reporting that they have it working. I can’t seem to make any progress but I cannot see what I am doing wrong.
Any help gratefully received
I’ve never tried to use this, but from a quick glance at the code for the oh-input the issue appears to be that the oh-input overwrites the calendar-params property with its own set of default settings. It should be an easy fix, but you’re going to have to file an issue on the repo.
Thanks Justin
I’ll do exactly that
