After upgrading Zigbee2MQTT from 1.3 to 2.6.2 my OH 4.2.1 no longer updates states of the items like aqara temp/humidity sensors WSDCGQ11LM and some ikea buttons
I can see in the logs of mosquitto and z2m that everything is working, payload is there, but I guess they changed something in the json format…i could not dig out online what is it, I’m sure its just some option in configuration.yaml that will make it work with OH again…or I need to use some transformations?
The strangest thing is that at some point this worked, and then after a reboot of the machine (so, fresh start of openhab, z2m docker, mosquitto service) it just stopped working. But some smart switches do work (they receive ON/OFF commands) - the issue is mostly with stuff that is supposed to send state.
Z2M LOG:
[2025-10-03 23:02:07] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/SensorFridge', payload '{"battery":77,"humidity":85.79,"linkquality":84,"power_outage_count":85,"pressure":1000.7,"temperature":4.5,"voltage":2965}'
item
Number FridgeTemperature "Fridge Temperature [%.1f °C]" <temperature> (gKitchenSensors) ["Measurement", "Temperature"] {channel="mqtt:topic:mosquitto:SensorFridge:FridgeTemperature"}
Number FridgeHumidity "Fridge Humidity [%d %%]" <humidity> (gKitchenSensors) ["Measurement", "Humidity"] {channel="mqtt:topic:mosquitto:SensorFridge:FridgeHumidity"}
Number FridgePressure "Fridge Pressure [%d mbar]" <pressure> {channel="mqtt:topic:mosquitto:SensorFridge:FridgePressure"}
Number FridgeBattery "Fridge Battery [%.1f %%]" <battery> (gBattery) {channel="mqtt:topic:mosquitto:SensorFridge:FridgeBattery"}
Number FridgeVoltage "Fridge Voltage [%d]" {channel="mqtt:topic:mosquitto:SensorFridge:FridgeVoltage"}
Number FridgeLink "Fridge Link [%d]" {channel="mqtt:topic:mosquitto:SensorFridge:FridgeLink"}
thing
Thing topic SensorFridge "SensorFridge" @ "Fridge" {
Channels:
Type number: FridgeTemperature "Fridge Temperature [%.1f °C]" [stateTopic="zigbee2mqtt/SensorFridge/temperature"]
Type number: FridgeHumidity "Fridge Humidity [%d %%]" [stateTopic="zigbee2mqtt/SensorFridge/humidity"]
Type number: FridgePressure "Fridge Pressure [%d mbar]" [stateTopic="zigbee2mqtt/SensorFridge/pressure"]
Type number: FridgeBattery "Fridge Battery [%.1f %%]" [stateTopic="zigbee2mqtt/SensorFridge/battery"]
Type number: FridgeVoltage "Fridge Voltage [%d mV]" [stateTopic="zigbee2mqtt/SensorFridge/voltage"]
Type number: FridgeLink "Fridge Link Quality [%d]" [stateTopic="zigbee2mqtt/SensorFridge/linkquality"]
