Hi, does anyone know if OH can be ran on the pi zero?
It doesn’t run well on the first gen pi so would guess the answer is no. But would love to hear if anyone has tried.
Anyone try it yet?
I tried the openhabian approach on pi zero but:
-the lack of built in ethernet (eth0) on pi0,
-inability to install openhabian over wifi,
-fact that the usb ethernet device I bought to test does not come up as eth0 either,
-and the fact that setting openhabian up on a regular pi2 then trying to swap the sd into the pi0 does not work (just get that color pallet screen and nothing).
I gave up. It wasn’t all the important to me but I have a pi0 that I have never used and thought I would try to put it to use.
I really use openhab as a many device - to - MQTT concentrator
So I would think zero might be up to the task - maybe I’ll try again
(I don’t use the web GUI, etc.)
I’ve compared the specs and it should work. I’ve been running openHAB 2 on a 1B+. https://en.wikipedia.org/wiki/Raspberry_Pi?wprov=sfla1
The problem for openHABian is the Wifi connection. I have another idea though. Let me know if you are interested to try
Btw what’s the other side of your MQTT net?
I use it to pump my house data alongside my business data in http://online.wonderware.com
I’m really aggregating everything “I” care about (work data, home data, etc.) into my own personal dashboard.
OpenHAB, and you, have brought me things that were impossible without it including insteon and chamberlain myq.
Really is pretty cool.
Thx.
I would definitely be willing to try a few things with wifi/pi0, whatever - I owe ya.
yes It’s work, I’m testing, but I ussing only myopnehab and GPIO, not other things
I tried openhabian again on my pi zero.
First with a combo usb hub+ethernet but can’t get to see eth0.
Second with a Edimax USB wifi but can’t get it to work ether. I tried adding wpa_supplicant.conf to /config/
I didn’t quite follow how to find and add wifi drivers that seem to be suggested by:
https://github.com/debian-pi/raspbian-ua-netinst/pull/175
Even with just a pi zero & a USB wired ethernet dongle I can’t get past:
waiting for eth0
then Oh noes, something went wrong.
I can see in the boot log that Realtek USB Ethernet was found.
Ideas?
It’s simply not supported yet
I’d like to provide a solution for you but that will take a few more days. I’m currently in exactly that process (hint).
What you can do right here, right now: Get a Raspbian system up and running and install and execute openHABian manually: openHABian hassle-free openHAB Setup
Let me know about all problems and differences you are seeing!
So I have openhabian mostly installed on an rpi0 using the manual method from above.
I had to enable ssh
I can access the openhab shares such as config over the network.
2 Qs:
why in my manual setup do I execute:
/opt/openhabian/openhabian-setup.sh
instead of:
openhabian-config
and how do I start openhab (I don’t have the website )
===> edit/update>>>
Well the service is already running from:
sudo systemctl status openhab2.service
but I don’t have the website
ports?
it might be a good idea to add the above steps to the manual linux instructions.
Wonderful.
Question 1: That’s simple. Part of the openHABian RPi image setup is the following command. Execute it:
ln -s /opt/openhabian/openhabian-setup.sh /usr/local/bin/openhabian-config
Question 2: If the service is running you should be able to access the website as always (Port 8080). There is no special setup or installation step. I can’t think of any. Please check the openhab.log and listening ports on your system (random tutoial).
It would be great to add the RPi Zero as a supported device to the openHABian article in the docs. I’m in the process of writing the article. Could you have a look what’s missing!? openHABian hassle-free openHAB Setup
That:
sudo netstat -plnt
is handy and tells me that nothing is using 8080 so I looked at the logs and the errors are so many/so long I’m not sure I should post.
Here goes:
[08:36:24] pi@rpi0:~$ tail -f /var/log/openhab2/openhab.log -f /var/log/openhab2/events.log
2017-01-20 07:36:00.685 [ERROR] [ternal.service.BootFeaturesInstaller] - Error installing boot features
java.lang.IllegalStateException: Resource has no uri
at org.apache.karaf.features.internal.service.Deployer.getBundleInputStream(Deployer.java:1403)[8:org.apache.karaf.features.core:4.0.8]
at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:737)[8:org.apache.karaf.features.core:4.0.8]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1176)[8:org.apache.karaf.features.core:4.0.8]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl$1.call(FeaturesServiceImpl.java:1074)[8:org.apache.karaf.features.core:4.0.8]
at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_121]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_121]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_121]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_121]
2017-01-20 08:37:29.853 [ERROR] [org.eclipse.smarthome.core.audio ] - FrameworkEvent ERROR - org.eclipse.smarthome.core.audio
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.core.audio [99]
Unresolved requirement: Import-Package: org.osgi.service.http
at org.eclipse.osgi.container.Module.start(Module.java:434)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1561)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1533)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1476)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
2017-01-20 08:37:30.256 [ERROR] [org.eclipse.smarthome.core.voice ] - FrameworkEvent ERROR - org.eclipse.smarthome.core.voice
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.core.voice [108]
Unresolved requirement: Import-Package: org.eclipse.smarthome.core.audio
-> Export-Package: org.eclipse.smarthome.core.audio; bundle-symbolic-name="org.eclipse.smarthome.core.audio"; bundle-version="0.9.0.201701192225"; version="0.0.0"
2017-01-20 08:37:30.307 [ERROR] [org.eclipse.smarthome.io.javasound ] - FrameworkEvent ERROR - org.eclipse.smarthome.io.javasound
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.io.javasound [111]
2017-01-20 08:37:30.355 [ERROR] [org.eclipse.smarthome.io.rest.voice ] - FrameworkEvent ERROR - org.eclipse.smarthome.io.rest.voice
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.io.rest.voice [119]
Unresolved requirement: Import-Package: org.eclipse.smarthome.core.voice
-> Export-Package: org.eclipse.smarthome.core.voice; bundle-symbolic-name="org.eclipse.smarthome.core.voice"; bundle-version="0.9.0.201701192225"; version="0.0.0"
2017-01-20 08:37:30.404 [ERROR] [org.eclipse.smarthome.io.webaudio ] - FrameworkEvent ERROR - org.eclipse.smarthome.io.webaudio
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.io.webaudio [121]
2017-01-20 08:37:30.886 [ERROR] [org.eclipse.smarthome.model.core ] - FrameworkEvent ERROR - org.eclipse.smarthome.model.core
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.model.core [122]
Unresolved requirement: Import-Package: com.google.inject
-> Export-Package: com.google.inject; bundle-symbolic-name="com.google.inject"; aop="false"; bundle-version="3.0.0.v201312141243"; version="1.3.0"
com.google.inject [13]
Unresolved requirement: Import-Package: javax.inject
2017-01-20 08:37:30.933 [ERROR] [org.eclipse.smarthome.model.rule ] - FrameworkEvent ERROR - org.eclipse.smarthome.model.rule
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.model.rule [127]
Unresolved requirement: Import-Package: org.eclipse.smarthome.model.core
-> Export-Package: org.eclipse.smarthome.model.core; bundle-symbolic-name="org.eclipse.smarthome.model.core"; bundle-version="0.9.0.201701192225"; version="0.0.0"
2017-01-20 08:37:30.996 [ERROR] [eclipse.smarthome.model.rule.runtime] - FrameworkEvent ERROR - org.eclipse.smarthome.model.rule.runtime
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.model.rule.runtime [128]
2017-01-20 08:37:31.033 [ERROR] [org.eclipse.smarthome.model.script ] - FrameworkEvent ERROR - org.eclipse.smarthome.model.script
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.model.script [129]
2017-01-20 08:37:31.107 [ERROR] [lipse.smarthome.model.script.runtime] - FrameworkEvent ERROR - org.eclipse.smarthome.model.script.runtime
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.model.script.runtime [130]
2017-01-20 08:37:31.234 [ERROR] [org.eclipse.xtext ] - FrameworkEvent ERROR - org.eclipse.xtext
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.xtext [141]
Unresolved requirement: Require-Bundle: com.google.inject; bundle-version="3.0.0"; visibility:="reexport"
-> Bundle-SymbolicName: com.google.inject; bundle-version="3.0.0.v201312141243"
2017-01-20 08:37:31.305 [ERROR] [org.eclipse.xtext.common.types ] - FrameworkEvent ERROR - org.eclipse.xtext.common.types
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.xtext.common.types [142]
I started from scratch again using your document at:
http://docs.openhab.org/installation/openhabian.html
I am following the “Manual Setup” instructions on my raspberry pi zero.
I ran into “directory does not exist” - cleaned up as if starting from scratch but this time making an adjustment to this line:
sudo git -C /opt/openhabian clone https://github.com/openhab/openhabian.git
Removing the first “/openhabian” to be:
sudo git -C /opt clone https://github.com/openhab/openhabian.git
I created:
It’s chugging along now…
A summary of what went well, problems you encountered and extra steps you had to take would be great. I’ll add them to the article…
Manual Setup worked great on Pi zero and performance is excellent.
I looked at HABmin because I haven’t seen it in a long time and it’s performance is great too.
Hard to believe I am monitoring and controlling hundred or so items and passing them to an MQ TT broker using this:
Here are my steps in detail:
20170116: created this doc for setting up rpi0
# initially set up raspbian on rpi zero using:
# * - items mared with astrisk are only needed for initial setup
# - a good, high quality, 2.5A power supply with micro USB for pi zero
# - micro sd card for pi zero (I used 8GB kensington class 4)
# - Edimax wifi adapter
# - USB to micro USB adapter (first for hub then later for wifi adapter)
# - a separate, good, high quality, 2.5A power supply for Kensington POWERED USB HUB*
# ### Get good power supplies - I wasted hours with wifi not working only to
# ### realize that between wifi, HDMI, kbd/mouse my wifi would not work because
# ### I was having power problems
# - mini HDMI cable and monitor*
# - Logitech Wireless Kbd/Mouse adapter*
# downloaded and transferred to micro sd clean raspbian-only (no noobs) image from 2017-01-11 build and booted
# set keyboard, local, timezone, hostname, password
# RPi Menu>Preferences>Mouse and Keyboard Settings>Keyboard (tab)> United States English
# RPi Menu>Interfaces > Enable SSH
# RPi Menu>Preferences>Raspberry Pi Configuration>Localization (tab)>Timezone (tab)> US Central
# RPi Menu>Preferences>Raspberry Pi Configuration>System>Hostname: rpi0
# log into wifi
# uninstall unused heavy stuff:
sudo apt-get purge wolfram-engine libreoffice-*
# I use xrdp instead of vnc so uninstall realvnc server (before installing xrdp because they are incompatible)
sudo apt-get purge realvnc-vnc-server
sudo apt-get update
sudo apt-get install xrdp
sudo apt-get upgrade
sudo apt-get autoremove && sudo apt-get clean
sudo apt-get install rpi-update gparted && sudo rpi-update
20170119 made rpi0 sd backup to hard disk so I can start with it and skip hub, keyboard, etc.
# removed USB hub/power, and wireless kbd/mouse adapter - no longer needed
# put USB to Micro USB adapter directly in wifi adapter and plug combo into pi zero micro USB port
# boot and access via putty (ssh client)
# install openhabian: following http://docs.openhab.org/installation/openhabian.html
# install git
sudo apt-get update
sudo apt-get install git
# download and link
sudo openhabian-config # and then step through first 6 steps (Update,Basic Setup, Java 8,OpenHAB 2,Samba, Karaf)
# once complete, start openhab and verify status:
sudo systemctl start openhab2.service
# it takes 5-10 minutes for the website http://192.x.x.x:8080/ to become available
# from there select expert setup so you have 1.x bindings, should NOT have selected "simple setup"
# set up my config, items, services, etc.
I’ve ordered one yesterday. Seems like we’ll need yet another openHABian image
I’ll be first to test it then, because I’ve ordered one too!
Thanks for the info on the new product! Have only just bought a Raspberry Pi Zero for use as a remote camera. Unfortunately I needed two USB ports, one for the wifi and one for the USB camera. Just about to buy a USB board extension when I read this.
The wireless version arrived today and thought I would try Openhab2 first. Used the Noobs Lite to install Raspian Lite. Needed to setup wifi name and password within wpa_supplicant.conf and then installed openhabian-config. From this I installed Zulu Java, Openhab2 and Mosquitto in that order.
All working with a test MQTT sitemap within 1½ hours. That’s what I call hassle free!!
