i get every 2 minutes 15 mqtt messages from a mosqitto server. Even i can see every of the 15 massages in the log of the mosqitto server. That seems to work
But, the mqtt-binding receives each time just 6 or 7 messages. But not each time the same 6/7 messages, the mqtt-binding receives each time by random 6 or 7 out of 15 messages.
Here are my events.log
2018-01-21 23:38:28.359 [vent.ItemStateChangedEvent] - Temperatur_Heizung_OG_Vorlauf_1wire changed from 51.31 to 51.06
2018-01-21 23:38:29.097 [vent.ItemStateChangedEvent] - Temperatur_Wasser_Kalt_1wire changed from 20.75 to 18.00
2018-01-21 23:38:29.110 [vent.ItemStateChangedEvent] - Temperatur_Wasser_Warm_1wire changed from 32.31 to 32.19
2018-01-21 23:38:29.852 [vent.ItemStateChangedEvent] - Temperatur_OG_Bad_Fussboden_1wire changed from 26.19 to 26.00
2018-01-21 23:38:30.584 [vent.ItemStateChangedEvent] - Temperatur_Wasser_Dusche_Oben_1wire changed from 23.94 to 23.88
2018-01-21 23:38:30.603 [vent.ItemStateChangedEvent] - Temperatur_T14_1wire changed from 28.81 to 28.75
2018-01-21 23:40:29.412 [vent.ItemStateChangedEvent] - Temperatur_Heizung_OG_Vorlauf_1wire changed from 51.06 to 50.88
2018-01-21 23:40:30.155 [vent.ItemStateChangedEvent] - Temperatur_Wasser_Kalt_1wire changed from 18.00 to 16.31
2018-01-21 23:40:30.167 [vent.ItemStateChangedEvent] - Temperatur_Wasser_Warm_1wire changed from 32.19 to 32.00
2018-01-21 23:40:30.654 [vent.ItemStateChangedEvent] - Temperatur_T8_1wire changed from 43.50 to 43.00
2018-01-21 23:40:30.902 [vent.ItemStateChangedEvent] - Temperatur_EG_Kueche_Fussboden_1wire changed from 24.44 to 24.38
2018-01-21 23:40:30.914 [vent.ItemStateChangedEvent] - Temperatur_OG_Bad_Fussboden_1wire changed from 26.00 to 25.88
2018-01-21 23:42:30.470 [vent.ItemStateChangedEvent] - Temperatur_Heizung_OG_Vorlauf_1wire changed from 50.88 to 50.63
2018-01-21 23:42:31.215 [vent.ItemStateChangedEvent] - Temperatur_Wasser_Kalt_1wire changed from 16.31 to 15.88
2018-01-21 23:42:31.233 [vent.ItemStateChangedEvent] - Temperatur_Wasser_Warm_1wire changed from 32.00 to 31.81
2018-01-21 23:42:31.974 [vent.ItemStateChangedEvent] - Temperatur_OG_Bad_Fussboden_1wire changed from 25.88 to 25.75
2018-01-21 23:42:32.700 [vent.ItemStateChangedEvent] - Temperatur_Wasser_Dusche_Oben_1wire changed from 23.88 to 23.81
2018-01-21 23:42:32.714 [vent.ItemStateChangedEvent] - Temperatur_T14_1wire changed from 28.75 to 28.69
2018-01-22 00:10:17.943 [vent.ItemStateChangedEvent] - Temperatur_Wohnzimmer_KNX changed from 22.34 to 22.3
2018-01-22 00:10:45.277 [vent.ItemStateChangedEvent] - Temperatur_Heizung_OG_Vorlauf_1wire changed from 48.13 to 47.94
2018-01-22 00:10:46.017 [vent.ItemStateChangedEvent] - Temperatur_Wasser_Kalt_1wire changed from 17.88 to 18.00
2018-01-22 00:10:46.029 [vent.ItemStateChangedEvent] - Temperatur_Wasser_Warm_1wire changed from 29.63 to 29.50
2018-01-22 00:10:46.514 [vent.ItemStateChangedEvent] - Temperatur_T8_1wire changed from 41.50 to 41.00
2018-01-22 00:10:46.772 [vent.ItemStateChangedEvent] - Temperatur_OG_Bad_Fussboden_1wire changed from 24.50 to 24.44
2018-01-22 00:10:47.508 [vent.ItemStateChangedEvent] - Temperatur_Wasser_Dusche_Oben_1wire changed from 23.25 to 23.19
as you can see, the item Temperatur_OG_Bad_Fussboden_1wire is received in each block, but the item Temperatur_T14_1wire just 2 times in the 4 blocks.
is there a limit of received messages or …?
