Oh-repeater and oh-masonry
Hello Community!
This is my first post here, sorry if not everything is up to the guidelines.
I am trying to use oh-repeater in an oh-masonry layout, for responsiveness. The child component is a custom widget based on f7-card. I set the fragment to true in the oh-repeater options, but the cards are placed one below the other, even on a desktop, not in a responsive manner, like they would if I would add the widgets one-by-one, without the repeater. Any ideas how I could make it to be responsive?
Here is a snippet from the page config:
  - component: oh-masonry
    slots:
      default:
        - component: oh-repeater
            for: index
            sourceType: range
            rangeStart: 1
            rangeStop: 26
            rangeStep: 1
            fragment: true
          slots:
            default:
              - component: widget:sprinkler_valve_settings
                  item: ="Arduino_Controller_Relay" + (loop.index + 2)
                  title: =loop.index + ". zona"
                  duration: ="ValveTimer_" + loop.index
and here is the widget
uid: sprinkler_valve_settings
tags: []
props:
  parameters:
    - description: Title of the card
      label: Title
      required: false
      type: TEXT
    - context: item
      description: Valve relay
      label: Item
      required: false
      type: TEXT
    - context: item
      description: Valve timer
      label: Time duration item
      required: false
      type: TEXT
  parameterGroups: []
timestamp: May 31, 2022, 8:01:23 PM
component: f7-card
  title: '=(props.title) ? props.title : "Set the title"'
  style:
    justify-content: space-between
    align-content: space-between
    padding: 5px
slots:
  default:
    - component: oh-button
        large: true
        text: '=(items[props.item].state == "ON") ? "Stop" : "Start"'
        color: '=(items[props.item].state == "ON") ? "red" : "green"'
        fill: true
        action: toggle
        actionItem: =props.item
        actionCommand: ON
        actionCommandAlt: OFF
    - component: f7-row
        style:
          padding-top: 5px
          padding-bottom: 5px
      slots:
        default:
          - component: Label
              text: Automatic
          - component: oh-toggle
              color: green
    - component: f7-row
        class:
          - text-align-center
        style:
          padding-bottom: 5px
      slots:
        default:
          - component: Label
              text: Ido
          - component: oh-stepper
              fill: true
              min: 1
              max: 60
              raised: true
              large: true
              item: =props.duration
    - component: f7-row
      slots:
        default:
          - component: Label
              text: Current State
          - component: Label
              text: =(items[props.item].state)
Greetings,
ZK
I don’t think there’s a way to make this work directly. Because of the way the masonry works, the repeater’s list is always constrained to one of the masonry segments.
Check out my Dynamic favorites widget to see how I accomplished something similar by putting the repeater in a widget as a child of an f7-block which permitted better control of the responsiveness of the cards. Then you just add the widget to a page as part of its own block, not masonry, which makes the widget one large column across the whole page.
  - component: oh-block
      title: Favorites Quick Access
    slots:
      default:
        - component: oh-grid-row
          config: {}
          slots:
            default:
              - component: oh-grid-col
                config: {}
                slots:
                  default:
                    - component: widget:widget_favorite_grid
                      config: {}
