Hi you all,
how can I make a OH-toggle send the values 100/0 rather than ON/OFF?
BR
WR
Hi you all,
BR
WR
Quick note: The Tutorials & Examples category is for posting your own complete solutions. Please move this to a more appropriate category for questions.
You cannot. Those commands are hard-coded into the toggle.
There are many workarounds for this. You could add a map Transform to your Item that converts ON → 100 and OFF → 0. You could create a proxy Item that is a Switch and have a rule that passes the correct value on to your real Item when you change the proxy Item. Instead of a toggle you could use any of the oh components that include OH actions and define your own toggle commands in that component. There are more advanced options too.
