I updated to OH3 with my OH setup on Rpi4 and everything was working. Explicitly the Webinterface was reachable as before. For performance reasons with another Pi Setup I moved the SD Card to my Rpi3 as suggested here and restarted. Everything seems to be working (rules and switches work) except the Webinterface. When I call http://IPoftheOHsetup:8080 from another computer I get “connection cancelled” error. I tried to find the reason in the logs from http://IPoftheOHsetup:9001 but it seems to only show logs till the day of the update to OH3 and in the Karaf Konsole with
ssh -p 8101 openhab@localhost
log:tail
I see recent logs but nothing seems to be related to the webinterface.
Probably I am not reading the (correct) logs correctly but I am stuck. Any suggestions how to investigate to problem correctly, so I can solve it?
Thanks for your quick response. I hesitated to include the useless logs I found via the mentioned command and concluded the first step would be I get a hint which logs to post and how to get them.
But let me show you what I got so far with
log:tail
12:50:38.053 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Verbrauch_Kodi' changed from 3.8 to 4.1
12:50:39.051 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Verbrauch_Kodi' changed from 4.1 to 3.7
12:50:40.072 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Verbrauch_Kodi' changed from 3.7 to 4
12:50:41.063 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Verbrauch_Kodi' changed from 4 to 3.7
12:50:44.063 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Verbrauch_Kodi' changed from 3.7 to 3.8
12:50:52.062 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Verbrauch_Kodi' changed from 3.8 to 3.7
12:50:53.061 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Verbrauch_Kodi' changed from 3.7 to 4.1
12:50:54.062 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Verbrauch_Kodi' changed from 4.1 to 3.8
12:50:56.063 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Verbrauch_Kodi' changed from 3.8 to 3.7
12:50:57.063 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Verbrauch_Kodi' changed from 3.7 to 3.9
12:51:08.061 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Verbrauch_Kodi' changed from 3.9 to 4.1
12:51:09.061 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Verbrauch_Kodi' changed from 4.1 to 3.8
12:51:11.063 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Verbrauch_Kodi' changed from 3.8 to 3.7
12:51:12.062 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Verbrauch_Kodi' changed from 3.7 to 4.1
12:51:13.071 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Verbrauch_Kodi' changed from 4.1 to 3.7
12:51:23.073 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Verbrauch_Kodi' changed from 3.7 to 4
12:51:24.063 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Verbrauch_Kodi' changed from 4 to 3.7
12:51:25.062 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Verbrauch_Kodi' changed from 3.7 to 4
12:51:28.065 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Verbrauch_Kodi' changed from 4 to 3.7
12:51:29.065 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Verbrauch_Kodi' changed from 3.7 to 4
12:51:34.061 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Verbrauch_Kodi' changed from 4 to 3.9
12:51:40.063 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Verbrauch_Kodi' changed from 3.9 to 4.1
12:51:41.064 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Verbrauch_Kodi' changed from 4.1 to 3.7
12:51:42.064 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Verbrauch_Kodi' changed from 3.7 to 4
12:51:44.062 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Verbrauch_Kodi' changed from 4 to 4.1
12:51:45.066 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Verbrauch_Kodi' changed from 4.1 to 3.7
12:51:55.063 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Verbrauch_Kodi' changed from 3.7 to 4
12:51:57.062 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Verbrauch_Kodi' changed from 4 to 4.1
12:51:58.061 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Verbrauch_Kodi' changed from 4.1 to 3.8
12:51:59.063 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Verbrauch_Kodi' changed from 3.8 to 4.1
12:52:00.061 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Verbrauch_Kodi' changed from 4.1 to 3.7
12:52:01.062 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Verbrauch_Kodi' changed from 3.7 to 4
12:52:10.061 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Verbrauch_Kodi' changed from 4 to 3.9
12:52:12.063 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Verbrauch_Kodi' changed from 3.9 to 4.1
12:52:13.066 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Verbrauch_Kodi' changed from 4.1 to 3.8
12:52:15.062 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Verbrauch_Kodi' changed from 3.8 to 3.7
12:52:16.061 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Verbrauch_Kodi' changed from 3.7 to 4
12:52:27.063 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Verbrauch_Kodi' changed from 4 to 4.1
12:52:28.062 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Verbrauch_Kodi' changed from 4.1 to 3.8
12:52:29.061 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Verbrauch_Kodi' changed from 3.8 to 4.1
12:52:30.061 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Verbrauch_Kodi' changed from 4.1 to 3.8
12:52:31.061 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Verbrauch_Kodi' changed from 3.8 to 4.1
12:52:32.063 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Verbrauch_Kodi' changed from 4.1 to 3.7
12:52:33.062 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Verbrauch_Kodi' changed from 3.7 to 4
12:52:34.061 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Verbrauch_Kodi' changed from 4 to 3.7
12:52:38.063 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Verbrauch_Kodi' changed from 3.7 to 3.9
12:52:44.062 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Verbrauch_Kodi' changed from 3.9 to 4.1
12:52:45.061 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Verbrauch_Kodi' changed from 4.1 to 3.8
12:52:48.071 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Verbrauch_Kodi' changed from 3.8 to 4.1
12:52:49.063 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Verbrauch_Kodi' changed from 4.1 to 3.8
I believe there are some OS kernel level differences in between those CPUs. As stated in the other thread, that is beyond the scope of the openHAB forum. Starting a new thread here does not change that fact.
Suggestions here would be:
Do not do that
If you want to move OH to the Pi 3, import a backup of OH on the Pi 4 to a different SD card on the Pi 3.
The only problem I am experiencing is with the Webinterface which is not reachable. Since the OH backup does not include my Z-Wave (RaZberry2) settings and devices I would appreciate not having to start from scratch, especially as everything except the Webinterface seems working. Nevertheless if I missed a way to backup Z-Wave settings and devices you might want to forward me to I will of course try again.
After following the recommendations by Bruce-Osborne above (installing from scratch and loading backup files) I learned that the Webinterface is first working fine and only after installing deConz Phoscon App it ist not reachable any more. Therefore I assume it is not a problem with Kernel Differences of the zwo Rpi’s I was using (since I did a fresh install and it was working first). It seems it is running on the same port (8080).
That’s why I came to the conclusion to change the pprot of deConz ans suggested here: Phoscon/deCONZ on openHABian
Unfortunately it seems even after restarting deConz somehow still runs on 8080 but not OH:
sudo lsof -i :8080
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
deCONZ 383 openhabian 12u IPv4 17334 0t0 TCP *:http-alt (LISTEN)
