I’ve been playing around with the DMX Binding for OH1 and have been able to light a couple neopixel strips over artnet.
I’m using a Arduino Ethernet Shield to receive the commands and pass them on here is some of my code.
.ITEMS
Group YELLOW_Alert (All)
Group RED_Alert (All)
Switch RED_Alert (All)
Switch YELLOW_Alert (All)
Switch all_living_room_leds "Doorbell Flash" (All) {dmx="CHANNEL[1/480], ON[FADE|0:255,255,255,255:125|0:0,0,255,0:125|0:255,255,255,255:125|0:0,0,255,0:125|0:255,255,255,255:125|0:0,0,255,0:125|0:255,255,255,255:125|0:0,0,255,0:125|0:255,255,255,255:125|0:0,0,255,0:125|0:0,0,0,0:-1]"}
Switch all_living_room_led "Warm White" (All) {dmx="CHANNEL[1/480:1000], ON[FADE|0:0,0,0,255:125]"}
Color Left_Hatch_Color "Left Hatch Color" (All) {dmx="CHANNEL[1/480:1000]"}
Switch hatch_1_yellow_alert "Hatch 1 Yellow Alert" (YELLOW_Alert) {dmx="CHANNEL[1/160], ON[FADE|0:255,255,255,255:500|0:255,200,0,0:300|0:255,255,255,255:500|0:255,200,0,0:300|0:255,255,255,255:500|0:255,200,0,0:300|0:255,255,255,255:500|0:255,200,0,0:300|0:255,255,255,255:500|0:255,200,0,0:300|0:0,0,0,0:-1]"}
Switch hatch_1_red_alert "Hatch 1 Red Alert" (RED_Alert) {dmx="CHANNEL[1/160], ON[FADE|0:255,255,255,255:500|0:255,0,0,0:300|0:255,255,255,255:500|0:255,0,0,0:300|0:255,255,255,255:500|0:255,0,0,0:300|0:255,255,255,255:500|0:255,0,0,0:300|0:255,255,255,255:500|0:255,0,0,0:300|0:0,0,0,0:-1]"}
Switch hatch_2_yellow_alert "Hatch 2 Yellow Alert" (YELLOW_Alert) {dmx="CHANNEL[161/160], ON[FADE|0:255,255,255,255:500|0:255,200,0,0:300|0:255,255,255,255:500|0:255,200,0,0:300|0:255,255,255,255:500|0:255,200,0,0:300|0:255,255,255,255:500|0:255,200,0,0:300|0:255,255,255,255:500|0:255,200,0,0:300|0:0,0,0,0:-1]"}
Switch hatch_2_red_alert "Hatch 2 Red Alert" (RED_Alert) {dmx="CHANNEL[161/160], ON[FADE|0:255,255,255,255:500|0:255,0,0,0:300|0:255,255,255,255:500|0:255,0,0,0:300|0:255,255,255,255:500|0:255,0,0,0:300|0:255,255,255,255:500|0:255,0,0,0:300|0:255,255,255,255:500|0:255,0,0,0:300|0:0,0,0,0:-1]"}
Switch hatch_3_yellow_alert "Hatch 3 Yellow Alert" (YELLOW_Alert) {dmx="CHANNEL[321/160], ON[FADE|0:255,255,255,255:500|0:255,200,0,0:300|0:255,255,255,255:500|0:255,200,0,0:300|0:255,255,255,255:500|0:255,200,0,0:300|0:255,255,255,255:500|0:255,200,0,0:300|0:255,255,255,255:500|0:255,200,0,0:300|0:0,0,0,0:-1]"}
Switch hatch_3_red_alert "Hatch 3 Red Alert" (RED_Alert) {dmx="CHANNEL[321/160], ON[FADE|0:255,255,255,255,255,0,0,0:500|0:255,0,0,0,255,255,255,255:300|0:255,255,255,255,255,0,0,0:500|0:255,0,0,0,255,255,255,255:300|0:255,255,255,255,255,0,0,0:500|0:255,0,0,0,255,255,255,255:300|0:255,255,255,255,255,0,0,0:500|0:255,0,0,0,255,255,255,255:300|0:255,255,255,255,255,0,0,0:500|0:255,0,0,0,255,255,255,255:300|0:0,0,0,0:-1]"}
Color Left_Hatch_WWA "Left Hatch WWA" (All) {dmx="CHANNEL[1/480:1000]"}
Switch Left_Hatch_WWA_WW "WWA Warm White" (All) {dmx="CHANNEL[1/480:1000], ON[FADE|0:0,0,255,0:125]"}
Switch Left_Hatch_WWA_W "WWA White" (All) {dmx="CHANNEL[1/480:1000], ON[FADE|0:0,255,0,0:125]"}
Switch Left_Hatch_WWA_A "WWA Amber" (All) {dmx="CHANNEL[1/480:1000], ON[FADE|0:255,0,0,0:125]"}
The arduino code is from natcl/Artnet with a couple modifications
3 channel strip. because anything over 4 channels registers as RGBW I had to make a way to strip out the 4th channel.
This example will receive multiple universes via Artnet and control a strip of ws2811 leds via
Adafruit's NeoPixel library: https://github.com/adafruit/Adafruit_NeoPixel
This example may be copied under the terms of the MIT license, see the LICENSE file for details
#ifdef __AVR__
#include <avr/power.h>
#endif
#include <Artnet.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
#include <SPI.h>
#include <Adafruit_NeoPixel.h>
// Neopixel settings
const int numLeds = 120; // change for your setup
const int numberOfChannels = numLeds * 3; // Total number of channels you want to receive (1 led = 3 channels)
const byte dataPin = 2;
Adafruit_NeoPixel leds = Adafruit_NeoPixel(numLeds, dataPin, NEO_GRB + NEO_KHZ800);
// Artnet settings
Artnet artnet;
const int startUniverse = 0; // CHANGE FOR YOUR SETUP most software this is 1, some software send out artnet first universe as 0.
// Check if we got all universes
const int maxUniverses = numberOfChannels / 512 + ((numberOfChannels % 512) ? 1 : 0);
bool universesReceived[maxUniverses];
bool sendFrame = 1;
int previousDataLength = 0;
// Change ip and mac address for your setup
byte ip[] = {192, 168, 1, 110};
byte mac[] = {0x90, 0xA2, 0xDA, 0x10, 0x27, 0x6B};
void setup()
//Serial.begin(115200);
artnet.begin(mac, ip);
leds.begin();
initTest();
// this will be called for each packet received
artnet.setArtDmxCallback(onDmxFrame);
void loop()
// we call the read function inside the loop
artnet.read();
void onDmxFrame(uint16_t universe, uint16_t length, uint8_t sequence, uint8_t* data)
sendFrame = 1;
// set brightness of the whole strip
if (universe == 15)
leds.setBrightness(data[0]);
leds.show();
// Store which universe has got in
if ((universe - startUniverse) < maxUniverses)
universesReceived[universe - startUniverse] = 1;
for (int i = 0 ; i < maxUniverses ; i++)
if (universesReceived[i] == 0)
//Serial.println("Broke");
sendFrame = 0;
break;
// read universe and put into the right part of the display buffer
for (int i = 0; i < length / 3; i++)
int led = i + (universe - startUniverse) * (previousDataLength / 4);
if (led < numLeds)
leds.setPixelColor(led, data[i * 4], data[i * 4 + 1], data[i * 4 + 2], data[i * 4 + 3]);
previousDataLength = length;
if (sendFrame)
leds.show();
// Reset universeReceived to 0
memset(universesReceived, 0, maxUniverses);
void initTest()
for (int i = 0 ; i < numLeds ; i++)
leds.setPixelColor(i, 127, 0, 0);
leds.show();
delay(500);
leds.setPixelColor(i, 0, 127, 0);
leds.show();
delay(500);
leds.setPixelColor(i, 0, 0, 127);
leds.show();
delay(500);
leds.setPixelColor(i, 0, 0, 0);
leds.show();
Arduino RGBW strip
#include <Artnet.h>
#include <SPI.h>
const int numberOfChannels = numLeds * 4; // Total number of channels you want to receive (1 led = 3 channels)
#define dataPin1 7
Adafruit_NeoPixel leds1 = Adafruit_NeoPixel(numLeds, dataPin1, NEO_GRBW + NEO_KHZ800);
// Artnet settings
Artnet artnet;
bool sendFrame = 1;
byte ip[] = {192, 168, 1, 109};
byte mac[] = {0x90, 0xA2, 0xDA, 0x10, 0x26, 0x17};
void setup()
leds1.begin();
leds2.setBrightness(BRIGHTNESS);
leds2.begin();
initTest();
void loop()
artnet.read();
sendFrame = 1;
if (universe == 15)
leds1.setBrightness(data[0]);
leds1.show();
sendFrame = 0;
break;
for (int i = 0; i < length / 4; i++)
if (led < numLeds)
leds1.setPixelColor(led, data[i * 4], data[i * 4 + 1], data[i * 4 + 2],data[i * 4 + 3]);
if (sendFrame)
leds1.show();
void initTest()
leds1.setPixelColor(i, 127, 0, 0, 0);
leds1.show();
delay(500);
leds1.setPixelColor(i, 0, 127, 0, 0);
leds1.show();
delay(500);
leds1.setPixelColor(i, 0, 0, 127, 0);
leds1.show();
delay(500);
leds1.setPixelColor(i, 0, 0, 0, 127);
leds1.show();
delay(500);
leds1.setPixelColor(i, 0, 0, 0, 0);
leds1.show();
