Max_G
(Max G)
August 13, 2017, 1:16pm
1
I have noticed that my OH1 needs a reboot every 70-ish days…
Looking into this issue revealed that Java has 40,000 files open…
sudo lsof | cut -d " " -f 1 | uniq -c | sort -nr
40041 java
415 apache2
Looking up the Java PID and listing the files with:
sudo ls -l /proc/9466/fd
shows tons of openHAB files.
How can I fix his?
Can I fix it? As in, is it an openAB problem?
What other info is needed to look into this?
namraccr
(namraccr)
August 13, 2017, 9:48pm
2
Reboot the device. That will fix the problem. It might come back again, though.
As to whether it’s an OH problem, is harder to say.
You should make a list of the bundles that were running during the time period in question. It’s possible one (or more) of them is leaking.
Max_G
(Max G)
August 13, 2017, 10:59pm
3
Yes, reboot will fix it, but is a band aid rather than a solution.
And it does come back…
I am interested in a fix; e.g. a proper way to get to the bottom of this, so that I can log an issue with whomever I need to…
Any hints appreciated…
Today’s stats look like this:
sudo lsof | awk '{ print $2 " " $1; }' | sort -rn | uniq -c | sort -rn | head -20
41269 9466 java
380 669 llvmpipe-
namraccr
(namraccr)
August 14, 2017, 12:30am
4
Again, we need to know which bundles/bindings were running.
Also, it would be interesting to compare the numbers above with these scenarios:
OH not running
OH running with no bindings installed
Max_G
(Max G)
August 14, 2017, 2:39am
5
Hmmm…
This is from a fresh install of openHABian… not config done to it, nothing installed (other than lsof
I selected EXPERT mode, hence, no bindings are installed as I understand it.
[12:35:40] root@openHABianPi:/home/openhabian# sudo lsof | awk '{ print $2 " " $1; }' | sort -rn | uniq -c | sort -rn | head -20
36618 31302 java
193 7012 smbd
188 29706 smbd
182 29712 smbd
156 30780 node
104 30780 V8
55 31470 sshd
51 31461 sshd
45 1 systemd
39 132 systemd-j
38 420 dbus-daem
37 417 avahi-dae
36 5486 systemd-u
34 477 wpa_suppl
33 844 sshd
33 539 bluetooth
33 10039 rpcbind
32 31954 su
31 31950 sudo
31 1058 sudo
[12:35:50] root@openHABianPi:/home/openhabian# uptime
12:38:30 up 7 days, 4:18, 1 user, load average: 0.11, 0.30, 0.18
