- Platform information: Win10 64bit / 32GB RAM / intel Z270 / M2e SSD
- Java Runtime Environment: 1.8.0_152
- openHAB version: 1.8.3
- Hue Binding version: 1.11.0
- KNX Binding version: 1.11.0
Dear all
since I see from time to time problems with my Hue bulbs (switching on/off without any commands) I was looking for the root cause. In my log file I see a lot of entries which seems to be caused by an interferring problem between Hue and KNX binding.
2017-11-25 18:44:11.955 [INFO ] [b.k.i.connection.KNXConnection] - Established connection to KNX bus on 192.168.0.2:3671 in mode TUNNEL.
2017-11-25 18:44:11.976 [INFO ] [b.k.i.connection.KNXConnection] - Connected to KNX
2017-11-25 18:46:07.482 [WARN ] [.h.internal.hardware.HueBridge] - Failed to connect to Hue bridge: HTTP request timed out.
2017-11-25 18:46:07.482 [WARN ] [inding.hue.internal.HueBinding] - Hue settings were null, maybe misconfigured bridge IP.
2017-11-25 18:46:10.928 [WARN ] [b.k.i.connection.KNXConnection] - KNX link has been lost (reason: server request on object tunneling link link (closed) 192.168.0.2:3671 TP1 medium, device 0.0.0, hopcount 6)
2017-11-25 18:46:10.930 [INFO ] [b.k.i.connection.KNXConnection] - KNX link will be retried in 30 seconds
2017-11-25 18:46:10.932 [ERROR] [.b.knx.internal.bus.KNXBinding] - Received detach Event.
2017-11-25 18:46:17.494 [WARN ] [.h.internal.hardware.HueBridge] - Failed to connect to Hue bridge: HTTP request timed out.
2017-11-25 18:46:17.494 [WARN ] [inding.hue.internal.HueBinding] - Hue settings were null, maybe misconfigured bridge IP.
2017-11-25 18:46:40.934 [INFO ] [b.k.i.connection.KNXConnection] - Trying to (re-)connect to KNX...
2017-11-25 18:46:40.939 [INFO ] [b.k.i.connection.KNXConnection] - Established connection to KNX bus on 192.168.0.2:3671 in mode TUNNEL.
2017-11-25 18:46:40.960 [INFO ] [b.k.i.connection.KNXConnection] - Connected to KNX
2017-11-25 18:48:34.926 [WARN ] [b.k.i.connection.KNXConnection] - KNX link has been lost (reason: server request on object tunneling link link (closed) 192.168.0.2:3671 TP1 medium, device 0.0.0, hopcount 6)
2017-11-25 18:48:34.928 [INFO ] [b.k.i.connection.KNXConnection] - KNX link will be retried in 30 seconds
2017-11-25 18:48:34.931 [ERROR] [.b.knx.internal.bus.KNXBinding] - Received detach Event.
2017-11-25 18:48:43.220 [WARN ] [.h.internal.hardware.HueBridge] - Failed to connect to Hue bridge: HTTP request timed out.
2017-11-25 18:48:43.220 [WARN ] [inding.hue.internal.HueBinding] - Hue settings were null, maybe misconfigured bridge IP.
2017-11-25 18:48:58.222 [WARN ] [.h.internal.hardware.HueBridge] - Failed to connect to Hue bridge: HTTP request timed out.
2017-11-25 18:48:58.222 [WARN ] [inding.hue.internal.HueBinding] - Hue settings were null, maybe misconfigured bridge IP.
2017-11-25 18:49:04.930 [INFO ] [b.k.i.connection.KNXConnection] - Trying to (re-)connect to KNX...
2017-11-25 18:49:08.234 [WARN ] [.h.internal.hardware.HueBridge] - Failed to connect to Hue bridge: HTTP request timed out.
2017-11-25 18:49:08.234 [WARN ] [inding.hue.internal.HueBinding] - Hue settings were null, maybe misconfigured bridge IP.
2017-11-25 18:49:14.931 [ERROR] [b.k.i.connection.KNXConnection] - Error connecting to KNX bus: timeout connecting to control endpoint /192.168.0.2:3671
2017-11-25 18:49:14.931 [ERROR] [tuwien.auto.calimero ] - KNXnet/IP Tunneling 192.168.0.2:3671: establishing connection failed, timeout connecting to control endpoint /192.168.0.2:3671
2017-11-25 18:49:14.931 [INFO ] [b.k.i.connection.KNXConnection] - KNX link will be retried in 30 seconds
2017-11-25 18:49:34.930 [INFO ] [b.k.i.connection.KNXConnection] - Trying to (re-)connect to KNX...
2017-11-25 18:49:34.933 [INFO ] [b.k.i.connection.KNXConnection] - Established connection to KNX bus on 192.168.0.2:3671 in mode TUNNEL.
2017-11-25 18:49:34.953 [INFO ] [b.k.i.connection.KNXConnection] - Connected to KNX
2017-11-25 18:51:30.856 [WARN ] [b.k.i.connection.KNXConnection] - KNX link has been lost (reason: server request on object tunneling link link (closed) 192.168.0.2:3671 TP1 medium, device 0.0.0, hopcount 6)
2017-11-25 18:51:30.856 [INFO ] [b.k.i.connection.KNXConnection] - KNX link will be retried in 30 seconds
2017-11-25 18:51:30.858 [ERROR] [.b.knx.internal.bus.KNXBinding] - Received detach Event.
2017-11-25 18:51:33.915 [WARN ] [.h.internal.hardware.HueBridge] - Failed to connect to Hue bridge: HTTP request timed out.
2017-11-25 18:51:33.915 [WARN ] [inding.hue.internal.HueBinding] - Hue settings were null, maybe misconfigured bridge IP.
2017-11-25 18:51:48.917 [WARN ] [.h.internal.hardware.HueBridge] - Failed to connect to Hue bridge: HTTP request timed out.
2017-11-25 18:51:48.917 [WARN ] [inding.hue.internal.HueBinding] - Hue settings were null, maybe misconfigured bridge IP.
2017-11-25 18:51:58.929 [WARN ] [.h.internal.hardware.HueBridge] - Failed to connect to Hue bridge: HTTP request timed out.
2017-11-25 18:51:58.929 [WARN ] [inding.hue.internal.HueBinding] - Hue settings were null, maybe misconfigured bridge IP.
2017-11-25 18:52:00.858 [INFO ] [b.k.i.connection.KNXConnection] - Trying to (re-)connect to KNX...
Regarding HUE:
I checked config, the pairing is done, it receives commands and reacts on it (with problems as described above).
Regarding KNX:
I tried to use ROUTER instead of TUNNEL, it is connecting but then I see a lot of other errors and KNX is not reacting anymore when it gets commands via OH.
2017-11-25 18:31:30.408 [WARN ] [.KNXBindingDatapointReaderTask] - Autorefresh: Cannot read value for item 'Heiz_EG_WZ_Status_Stellwert' from KNX bus: timeout waiting for group read response: timeout
2017-11-25 18:31:30.408 [WARN ] [.KNXBindingDatapointReaderTask] - Autorefresh: Remaining retries for address '1/2/14' = '2'
2017-11-25 18:31:40.460 [WARN ] [.KNXBindingDatapointReaderTask] - Autorefresh: Cannot read value for item 'Fassade2_Nachtschliessen_Status' from KNX bus: timeout waiting for group read response: timeout
2017-11-25 18:31:40.460 [WARN ] [.KNXBindingDatapointReaderTask] - Autorefresh: Remaining retries for address '6/1/23' = '2'
2017-11-25 18:31:50.512 [WARN ] [.KNXBindingDatapointReaderTask] - Autorefresh: Cannot read value for item 'Bus_Busverkehr_Ueberwachung_Maximaler_Busverkehr' from KNX bus: timeout waiting for group read response: timeout
2017-11-25 18:31:50.513 [WARN ] [.KNXBindingDatapointReaderTask] - Autorefresh: Remaining retries for address '0/0/18' = '2'
2017-11-25 18:32:00.564 [WARN ] [.KNXBindingDatapointReaderTask] - Autorefresh: Cannot read value for item 'Sicherung_F13_Strommessung' from KNX bus: timeout waiting for group read response: timeout
2017-11-25 18:32:00.564 [WARN ] [.KNXBindingDatapointReaderTask] - Autorefresh: Remaining retries for address '4/1/13' = '2'
2017-11-25 18:32:10.616 [WARN ] [.KNXBindingDatapointReaderTask] - Autorefresh: Cannot read value for item 'Fassade1_Sonnenauto_Hellig_Kurz_Status' from KNX bus: timeout waiting for group read response: timeout
2017-11-25 18:32:10.616 [WARN ] [.KNXBindingDatapointReaderTask] - Autorefresh: Remaining retries for address '6/0/48' = '2'
As a side effect I see very often a network adapter disconnect when the problems above appear.
Can you please help me to resolve this problems or at least find out what the root causes are?
Thanks & Regards
John
