[OH1] Problem with calculation with a Number Item inside script
Running OH1 on a sRaspPi
I have a Number item defined with a Range inside the Sitemap betweet 1 and 30
I can not get the value inside a script and calculate with it. I get an exception:
Item:
Number XYZ “Blubb [%d]”
Sitemap:
Setpoint item=XYZ label=“Blubb [%d]” step=1 minValue=1 maxValue=30
Script:
var int abc = XYZ.state
Exception:
Error during the execution of rule ZeitprofileRollershutter
org.openhab.core.scriptengine.ScriptExecutionException: An error occured during the script execution: Could not invoke method: org.eclipse.xtext.xbase.lib.IntegerExtensions.operator_multiply(int,int) on instance: null
at org.openhab.model.script.internal.engine.ScriptImpl.execute(ScriptImpl.java:72) ~[na:na]
at org.openhab.model.script.internal.engine.ScriptImpl.execute(ScriptImpl.java:53) ~[na:na]
at org.openhab.model.script.actions.ScriptExecution.callScript(ScriptExecution.java:68) ~[na:na]
at sun.reflect.GeneratedMethodAccessor13266.invoke(Unknown Source) ~[na:na]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:1.8.0_65]
at java.lang.reflect.Method.invoke(Method.java:497) ~[na:1.8.0_65]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:729) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._featureCallOperation(XbaseInterpreter.java:713) ~[na:na]
at sun.reflect.GeneratedMethodAccessor13241.invoke(Unknown Source) ~[na:na]
at org.eclipse.xtext.util.PolymorphicDispatcher.invoke(PolymorphicDispatcher.java:291) ~[na:na]
at org.openhab.model.script.interpreter.ScriptInterpreter.internalFeatureCallDispatch(ScriptInterpreter.java:69) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateAbstractFeatureCall(XbaseInterpreter.java:658) ~[na:na]
at sun.reflect.GeneratedMethodAccessor13242.invoke(Unknown Source) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:218) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateBlockExpression(XbaseInterpreter.java:321) ~[na:na]
at sun.reflect.GeneratedMethodAccessor13255.invoke(Unknown Source) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:204) ~[na:na]
at org.openhab.model.script.internal.engine.ScriptImpl.execute(ScriptImpl.java:59) ~[na:na]
at org.openhab.model.rule.internal.engine.ExecuteRuleJob.execute(ExecuteRuleJob.java:55) ~[na:na]
at org.quartz.core.JobRunShell.run(JobRunShell.java:213) [quartz-all-2.1.7.jar:na]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:557) [quartz-all-2.1.7.jar:na]
Caused by: java.lang.IllegalStateException: Could not invoke method: org.eclipse.xtext.xbase.lib.IntegerExtensions.operator_multiply(int,int) on instance: null
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:738) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateAssignment(XbaseInterpreter.java:843) ~[na:na]
at sun.reflect.GeneratedMethodAccessor13250.invoke(Unknown Source) ~[na:na]
… 29 common frames omitted
Try var int abc = (XYZ.state as Number).intValue instead.
This “try” was successful.
Thanks.
