OH1: Specific device class 0x0a not found
I try to use a Electric Strike Lock Control from Popp and get the message above (http://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/419)
The latest zwave bindings 1.10 is installed. Is there anything I can do ?
Regards,
Thomas
XML for the new device is not created, what is going wrong ?
2017-05-13 08:43:57.580 [DEBUG] [.b.z.i.p.s.AddNodeMessageClass:84 ]- NODE 70: Adding slave.
2017-05-13 08:43:57.585 [DEBUG] [b.z.i.protocol.ZWaveController:668 ]- NODE 70: Notifying event listeners: ZWaveInclusionEvent
2017-05-13 08:43:57.600 [DEBUG] [b.z.i.protocol.ZWaveController:683 ]- NODE 70: Including node.
2017-05-13 08:43:57.622 [DEBUG] [b.z.i.protocol.ZWaveController:512 ]- NODE 70: Init node thread start
2017-05-13 08:43:58.472 [DEBUG] [.b.z.i.p.i.ZWaveNodeSerializer:138 ]- NODE 70: Serializing from file etc/zwave/node70.xml
2017-05-13 08:43:58.485 [DEBUG] [.b.z.i.p.i.ZWaveNodeSerializer:141 ]- NODE 70: Error serializing from file: file does not exist.
2017-05-13 08:43:58.500 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:277 ]- NODE 70: Node advancer - EMPTYNODE: queue length(0), free to send(true)
2017-05-13 08:43:58.505 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:342 ]- NODE 70: Node advancer: loop - EMPTYNODE try 1: stageAdvanced(false)
2017-05-13 08:43:58.516 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:347 ]- NODE 70: Node advancer: Initialisation starting
2017-05-13 08:43:58.524 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:994 ]- NODE 70: Node advancer - advancing to PROTOINFO
2017-05-13 08:43:58.537 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:342 ]- NODE 70: Node advancer: loop - PROTOINFO try 0: stageAdvanced(true)
2017-05-13 08:43:58.541 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:356 ]- NODE 70: Node advancer: PROTOINFO - send IdentifyNode
2017-05-13 08:43:58.581 [DEBUG] [z.i.p.i.ZWaveNodeStageAdvancer:250 ]- NODE 70: Node advancer - queued packet. Queue length is 1
2017-05-13 08:43:58.593 [DEBUG] [b.z.i.protocol.ZWaveController:601 ]- NODE 70: Init node thread finished
2017-05-13 08:43:58.685 [DEBUG] [i.p.s.IdentifyNodeMessageClass:56 ]- NODE 70: ProtocolInfo
2017-05-13 08:43:58.690 [DEBUG] [i.p.s.IdentifyNodeMessageClass:72 ]- NODE 70: Listening = false
2017-05-13 08:43:58.695 [DEBUG] [i.p.s.IdentifyNodeMessageClass:73 ]- NODE 70: Routing = true
2017-05-13 08:43:58.704 [DEBUG] [i.p.s.IdentifyNodeMessageClass:74 ]- NODE 70: Beaming = true
2017-05-13 08:43:58.718 [DEBUG] [i.p.s.IdentifyNodeMessageClass:75 ]- NODE 70: Version = 4
2017-05-13 08:43:58.724 [DEBUG] [i.p.s.IdentifyNodeMessageClass:76 ]- NODE 70: FLIRS = true
2017-05-13 08:43:58.730 [DEBUG] [i.p.s.IdentifyNodeMessageClass:77 ]- NODE 70: Security = false
2017-05-13 08:43:58.737 [DEBUG] [i.p.s.IdentifyNodeMessageClass:78 ]- NODE 70: Max Baud = 40000
2017-05-13 08:43:58.757 [DEBUG] [i.p.s.IdentifyNodeMessageClass:94 ]- NODE 70: Basic = Routing Slave
2017-05-13 08:43:58.762 [DEBUG] [i.p.s.IdentifyNodeMessageClass:102 ]- NODE 70: Generic = Entry Control
2017-05-13 08:43:58.767 [ERROR] [i.p.s.IdentifyNodeMessageClass:106 ]- NODE 70: Specific device class 0x0a not found
2017-05-13 08:44:03.801 [DEBUG] [i.p.s.IdentifyNodeMessageClass:56 ]- NODE 70: ProtocolInfo
2017-05-13 08:44:03.811 [DEBUG] [i.p.s.IdentifyNodeMessageClass:72 ]- NODE 70: Listening = false
2017-05-13 08:44:03.827 [DEBUG] [i.p.s.IdentifyNodeMessageClass:73 ]- NODE 70: Routing = true
2017-05-13 08:44:03.836 [DEBUG] [i.p.s.IdentifyNodeMessageClass:74 ]- NODE 70: Beaming = true
2017-05-13 08:44:03.848 [DEBUG] [i.p.s.IdentifyNodeMessageClass:75 ]- NODE 70: Version = 4
2017-05-13 08:44:03.859 [DEBUG] [i.p.s.IdentifyNodeMessageClass:76 ]- NODE 70: FLIRS = true
2017-05-13 08:44:03.865 [DEBUG] [i.p.s.IdentifyNodeMessageClass:77 ]- NODE 70: Security = false
2017-05-13 08:44:03.890 [DEBUG] [i.p.s.IdentifyNodeMessageClass:78 ]- NODE 70: Max Baud = 40000
2017-05-13 08:44:03.895 [DEBUG] [i.p.s.IdentifyNodeMessageClass:94 ]- NODE 70: Basic = Routing Slave
2017-05-13 08:44:03.900 [DEBUG] [i.p.s.IdentifyNodeMessageClass:102 ]- NODE 70: Generic = Entry Control
2017-05-13 08:44:03.913 [ERROR] [i.p.s.IdentifyNodeMessageClass:106 ]- NODE 70: Specific device class 0x0a not found
2017-05-13 08:44:09.001 [DEBUG] [i.p.s.IdentifyNodeMessageClass:56 ]- NODE 70: ProtocolInfo
2017-05-13 08:44:09.005 [DEBUG] [i.p.s.IdentifyNodeMessageClass:72 ]- NODE 70: Listening = false
2017-05-13 08:44:09.013 [DEBUG] [i.p.s.IdentifyNodeMessageClass:73 ]- NODE 70: Routing = true
2017-05-13 08:44:09.019 [DEBUG] [i.p.s.IdentifyNodeMessageClass:74 ]- NODE 70: Beaming = true
2017-05-13 08:44:09.047 [DEBUG] [i.p.s.IdentifyNodeMessageClass:75 ]- NODE 70: Version = 4
2017-05-13 08:44:09.051 [DEBUG] [i.p.s.IdentifyNodeMessageClass:76 ]- NODE 70: FLIRS = true
2017-05-13 08:44:09.056 [DEBUG] [i.p.s.IdentifyNodeMessageClass:77 ]- NODE 70: Security = false
2017-05-13 08:44:09.069 [DEBUG] [i.p.s.IdentifyNodeMessageClass:78 ]- NODE 70: Max Baud = 40000
2017-05-13 08:44:09.077 [DEBUG] [i.p.s.IdentifyNodeMessageClass:94 ]- NODE 70: Basic = Routing Slave
2017-05-13 08:44:09.096 [DEBUG] [i.p.s.IdentifyNodeMessageClass:102 ]- NODE 70: Generic = Entry Control
2017-05-13 08:44:09.104 [ERROR] [i.p.s.IdentifyNodeMessageClass:106 ]- NODE 70: Specific device class 0x0a not found
2017-05-13 08:44:14.049 [DEBUG] [i.p.s.IdentifyNodeMessageClass:56 ]- NODE 70: ProtocolInfo
2017-05-13 08:44:14.058 [DEBUG] [i.p.s.IdentifyNodeMessageClass:72 ]- NODE 70: Listening = false
2017-05-13 08:44:14.066 [DEBUG] [i.p.s.IdentifyNodeMessageClass:73 ]- NODE 70: Routing = true
2017-05-13 08:44:14.088 [DEBUG] [i.p.s.IdentifyNodeMessageClass:74 ]- NODE 70: Beaming = true
2017-05-13 08:44:14.100 [DEBUG] [i.p.s.IdentifyNodeMessageClass:75 ]- NODE 70: Version = 4
2017-05-13 08:44:14.105 [DEBUG] [i.p.s.IdentifyNodeMessageClass:76 ]- NODE 70: FLIRS = true
2017-05-13 08:44:14.128 [DEBUG] [i.p.s.IdentifyNodeMessageClass:77 ]- NODE 70: Security = false
2017-05-13 08:44:14.133 [DEBUG] [i.p.s.IdentifyNodeMessageClass:78 ]- NODE 70: Max Baud = 40000
2017-05-13 08:44:14.148 [DEBUG] [i.p.s.IdentifyNodeMessageClass:94 ]- NODE 70: Basic = Routing Slave
2017-05-13 08:44:14.158 [DEBUG] [i.p.s.IdentifyNodeMessageClass:102 ]- NODE 70: Generic = Entry Control
2017-05-13 08:44:14.169 [ERROR] [i.p.s.IdentifyNodeMessageClass:106 ]- NODE 70: Specific device class 0x0a not found
2017-05-13 08:44:19.217 [DEBUG] [b.z.i.protocol.ZWaveController:668 ]- NODE 70: Notifying event listeners: ZWaveInclusionEvent
Hi tom,
i don’t think there will be much help/support any more for OH1.
Maybe it would be best to move to OH2?
Matthias
Hi Matthias,
I played already with OH2. but at this time the user authentication / access was not available. For me it is a no go because I mainly OpenHAB with remote access to different buildings in different cities.
I will check again what the current status is concerning remote access and authentication.
I made little progress with OH1, pulled the product and database file out of cd jacksons device list and inserted it in the snapshot. Configured the device with z-way-server, (config software for my interface on Raspberrry) picked up the secure key from the configuration, copied it to the zwave cfg for OH1.
Secure communication is set up by openhab, but never comes to an end. The xml is still not build. The missing device class could not be the problem here. Will try more !
Tom
