I had a look through the posts I could find…
I am running OH1 v1.8.3 and the TR064 binding 1.9.0 – is this a valid configuration?
The rule I am working with looks like this:
// ----- 170303 MaxG: fBox incoming call name resolution
rule "fbox_PhoneLine is ringing"
// fbox_Ringing is a switch item which switches to ON if an incoming call is detected
// https://community.openhab.org/t/fritzbox-tr064-binding-creation-of-esh-event-failed/10064/14
// callType no longer exists
Item fbox_Ringing changed from OFF to ON
logInfo("fbox_Ringing.rule", "Generating caller name message...")
// fbox_Incoming call receives numbers/name of incoming call
// callerNumber is external number OR resolved name if no phonebook entry exists
val CallType inCall = fbox_IncomingCallResolved.state as CallType
//val inCall = fbox_IncomingCallResolved.state as StringListType
logInfo("fbox_Ringing.rule", "inCall: {}", inCall)
//val callerNumber0 = inCall.getValue(0)
val callerNumber0 = inCall.destNum
logInfo("fbox_Ringing.rule", "callerNumber0: {}", callerNumber0)
val tmpCallNum0 = callerNumber0.toString as String
logInfo("fbox_Ringing.rule", "tmpCallNum0: {}", tmpCallNum0)
postUpdate(fbox_LastInCall0, tmpCallNum0)
// val callerNumber1 = inCall.getValue(1)
// logInfo("fbox_Ringing.rule", "callerNumber1: {}", callerNumber1)
// val tmpCallNum1 = callerNumber1.toString as String
// logInfo("fbox_Ringing.rule", "tmpCallNum1: {}", tmpCallNum1)
// postUpdate(fbox_LastInCall1, tmpCallNum1)
The rule does not work either way, be it CallType or StringListType
… producing the follwing log entry:
2017-03-03 16:49:23 - fbox_Ringing state updated to ON
2017-03-03 16:49:23 - fbox_IncomingCallResolved state updated to 0754246505##Name n ot found for 0411511002
2017-03-03 16:49:23 - fbox_IncomingCall state updated to 0754246505##0411511002
2017-03-03 16:49:29 - fbox_Ringing state updated to OFF
2017-03-03 16:49:29 - fbox_IncomingCallResolved state updated to ##
2017-03-03 16:49:29 - fbox_IncomingCall state updated to ##
2017-03-03 16:49:29 - fbox_OutgoingCall state updated to ##
2017-03-03 16:49:29 - fbox_Ringing_Out state updated to OFF
2017-03-03 16:49:23.296 [INFO ] [o.o.b.f.i.FritzboxTr064Binding] - Trying to resolve number 0411511002 to name comparing 7 characters
2017-03-03 16:49:23.506 [INFO ] [model.script.fbox_Ringing.rule] - Generating caller name message...
2017-03-03 16:49:23.807 [ERROR] [o.o.c.s.ScriptExecutionThread ] - Error during the execution of rule 'fbox_PhoneLine is ringing': Cannot cast org.openhab.library.tel.types.CallType to void
Also, my hope was that I would see the incoming call number, however, this is not the case.
My sitemap shows the numbers, but the call ends the numbers are cone.
Since I tried both versions, CallType and StringListType, and get the same result, I wonder:
a) is CallType still valid or not?
b) what causes the error?
sitemap:
Text item=fbox_Ringing
Text item=fbox_Ringing_Out
Text item=fbox_IncomingCall
Text item=fbox_OutgoingCall
Text item=fbox_IncomingCallResolved
Text item=fbox_MissedCalls
Text item=fbox_LastInCall0
Text item=fbox_LastInCall1
Items:
Switch fbox_Ringing "Phone ringing in [%s]" (gFritzBox) {fritzboxtr064="callmonitor_ringing"}
Switch fbox_Ringing_Out "Phone ringing out [%s]" (gFritzBox) {fritzboxtr064="callmonitor_outgoing"}
Call fbox_IncomingCall "Incoming call: [%1$s to %2$s]" (gFritzBox) {fritzboxtr064="callmonitor_ringing"}
Call fbox_OutgoingCall "Outgoing call: [%1$s to %2$s]" (gFritzBox) {fritzboxtr064="callmonitor_outgoing"}
Call fbox_IncomingCallResolved "Incoming call: [%1$s to %2$s]" (gFritzBox) {fritzboxtr064="callmonitor_ringing:resolveName"}
Number fbox_MissedCalls "Missed Calls (last 2 days) [%s]" (gFritzBox) {fritzboxtr064="missedCallsInDays:2"}
String fbox_LastInCall0 "CallerNumber0 [%s]" (gFritzBox)
String fbox_LastInCall1 "CallerNumber1 [%s]" (gFritzBox)
A side issue: the name exists in the pone book, but cannot be resolved…
Any hints appreciated.
