Since yesterday (when I upgraded to 2.1 (and also started working on a habpanel if this could be related), I have these exceptions in my log quite frequently. I cannot see any logic to when they happen unfortunately…
I previously run nightly snapshot from about a month ago, and cleared both tmp and cache upon upgrading.
I have disabled bindings (harmonyhub, sonos, hue, mqtt, epson projecotr) and habpanel, but they still arrive.
Granted I just have uninstalled the bindings, and waited, I have not restarted oh every time.
Is there any good way to find out the cause of these kind of exceptions?
java.io.IOException: java.util.concurrent.TimeoutException: Idle timeout expired: 30001/30000 ms
at org.eclipse.jetty.util.SharedBlockingCallback$Blocker.block(SharedBlockingCallback.java:213)
at org.eclipse.jetty.server.HttpInputOverHTTP.blockForContent(HttpInputOverHTTP.java:66)
at org.eclipse.jetty.server.HttpInput$1.waitForContent(HttpInput.java:489)
at org.eclipse.jetty.server.HttpInput.read(HttpInput.java:122)
at java.io.InputStream.read(InputStream.java:101)
at org.jupnp.util.io.IO.copyLarge(IO.java:969)
at org.jupnp.util.io.IO.copy(IO.java:943)
at org.jupnp.util.io.IO.toByteArray(IO.java:391)
at org.jupnp.util.io.IO.readBytes(IO.java:110)
at org.jupnp.transport.impl.ServletUpnpStream.readRequestMessage(ServletUpnpStream.java:137)
at org.jupnp.transport.impl.ServletUpnpStream.run(ServletUpnpStream.java:61)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:748)
Caused by: java.util.concurrent.TimeoutException: Idle timeout expired: 30001/30000 ms
at org.eclipse.jetty.io.IdleTimeout.checkIdleTimeout(IdleTimeout.java:161)
at org.eclipse.jetty.io.IdleTimeout$1.run(IdleTimeout.java:50)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293)
Edit: Sorry, forgot to add the exception…
