I’ve just upgraded from OH 2.1.0 to 2.2.0 and noticed that my LaunchDaemon is not working any longer.
The following is shown in the log file:
2017-08-30 12:50:54.536 [WARN ] [org.jline ] - Unable to create a system terminal, creating a dumb terminal (enable debug logging for more information)
2017-08-30 12:52:23.786 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at http://10.0.55.5:9080
2017-08-30 12:52:23.792 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at https://10.0.55.5:9443
2017-08-30 12:52:26.190 [INFO ] [thome.io.rest.core.item.ItemResource] - Received HTTP PUT request at 'items/Zaehler_WP/state' for the unknown item 'Zaehler_WP'.
2017-08-30 12:52:54.413 [INFO ] [.dashboard.internal.DashboardService] - Stopped dashboard
Sorry - deleted my previous reply, because I thought it is about the “org.jline” log message, but reading the log more closely, I see that it is about openHAB shutting down…
Do you have anything in your addons folder? If so, you might be stumbled over this issue.
I have the same issue, Also tried it already with UserAgent to have the current user.
and
Launching the openHAB runtime...
Listening for transport dt_socket at address: 5005
e[31m e[0m __ _____ ____ e[0m
e[31m ____ ____ ___ ____ e[0m/ / / / | / __ ) e[0m
e[31m / __ \/ __ \/ _ \/ __ \e[0m/ /_/ / /| | / __ | e[0m
e[31m/ /_/ / /_/ / __/ / / / e[0m__ / ___ |/ /_/ / e[0m
e[31m\____/ .___/\___/_/ /_/e[0m_/ /_/_/ |_/_____/ e[0m
e[31m /_/ e[0m 2.2.0-SNAPSHOTe[0m
e[31m e[0m Build #1065 e[0m
Hit 'e[1m<tab>e[0m' for a list of available commands
and 'e[1m[cmd] --helpe[0m' for help on a specific command.
Hit 'e[1m<ctrl-d>e[0m' or type 'e[1msystem:shutdowne[0m' or 'e[1mlogoute[0m' to shutdown openHAB.
Error in initialization script: /Users/peterbanniza/Downloads/openhab-2-2/userdata/etc/shell.init.script: String index out of range: 0
openhab>
I also already modified the system.properties file with
I mentioned the problem but got no helpful feedback up until now. Seems to be there’s no solution or the software is far too beta…I switched back to stable release.
Cheers,
M
I tried to upgrade to the stable release of OH 2.2 and have exactly the same error:
"Unable to create a system terminal, creating a dumb terminal"
when using the LaunchDeamon on macOS.
To check if there is a problem with my configuration, I used a clean install: I unpacked the source files without any modification and started it via LaunchDaemon, but the error is the same. A direct start with “./start.sh” works like it should.
I am not sure, if the “Unable to create a system terminal, creating a dumb terminal” really is a problem. I have seen it before, when launching from the shell, and openHAB started without further problems.
Nonetheless starting openHAB 2.2 via launchdaemon fails, I get the following errors:
2017-12-30 18:21:31.415 [WARN ] [lipse.smarthome.io.net.exec.ExecUtil] - Execution failed (Exit value: -559038737. Caused by java.io.IOException: Cannot run program "arping" (in directory "."): error=2, No such file or directory)
I can not say, if it ever worked with openHAB2, I migrated in the last weeks and always started from the command line until now, but it has never been a problem with openHAB 1.x
Any update on this? I am upgrading from 2.0 to 2.2 and get the same error, and it seems Openhab is not completing its start procedure because I keep getting notified Openhab is online when it connects to the myopenhab service.
lot of time went by but this error still exists. RC2.1.0 is working fine but 2.2.0 or 2.3.0-SNAPSHOT are still having this issue. It is not possible to start openhab2 via a launchdaemon.
Is someone able to provide a solution?
Btw I already tried a fresh install so it is not specific to my configuration.
Best regards,
Manolo
is someone still supporting openhab? I know it’s becoming spring and people spent more time outdoor but this issue persists since 8 month at least. @Kai are you able to provide me with a hint how to solve this issue?
I already tried a fresh install fro 2.2 and 2.3 snapshot but still the LaunchDaemon doesn’t work.
Thanks a lot in advance,
Manolo
