today I saw the following WARN in my log file. Is this something that I can fix? Can you give me any hints? Or should I open an issue on git?
Thanks & regards
John
29-Dez-2017 14:03:32.298 [WARN ] [smarthome.config.xml.osgi.XmlDocumentBundleTracker] - The XML document '/ESH-INF/binding/binding.xml' in module 'org.openhab.binding.exec' could not be parsed: The XmlConfigDescriptionProvider must not be null!
java.lang.IllegalArgumentException: The XmlConfigDescriptionProvider must not be null!
at org.eclipse.smarthome.core.binding.xml.internal.BindingInfoXmlProvider.<init>(BindingInfoXmlProvider.java:60) [112:org.eclipse.smarthome.core.binding.xml:0.10.0.b1]
at org.eclipse.smarthome.core.binding.xml.internal.XmlBindingInfoProvider.createDocumentProvider(XmlBindingInfoProvider.java:141) [112:org.eclipse.smarthome.core.binding.xml:0.10.0.b1]
at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker.acquireXmlDocumentProvider(XmlDocumentBundleTracker.java:181) [108:org.eclipse.smarthome.config.xml:0.10.0.b1]
at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker.addingObject(XmlDocumentBundleTracker.java:206) [108:org.eclipse.smarthome.config.xml:0.10.0.b1]
at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker.parseDocuments(XmlDocumentBundleTracker.java:350) [108:org.eclipse.smarthome.config.xml:0.10.0.b1]
at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker.processBundle(XmlDocumentBundleTracker.java:336) [108:org.eclipse.smarthome.config.xml:0.10.0.b1]
at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker.access$3(XmlDocumentBundleTracker.java:331) [108:org.eclipse.smarthome.config.xml:0.10.0.b1]
at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker$2.run(XmlDocumentBundleTracker.java:307) [108:org.eclipse.smarthome.config.xml:0.10.0.b1]
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source) [?:?]
at java.util.concurrent.FutureTask.run(Unknown Source) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(Unknown Source) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source) [?:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) [?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) [?:?]
at java.lang.Thread.run(Unknown Source) [?:?]
I’ve just installed a new system on 64Bit Debian and have the same error with the exec and network bindings on boot, although everything seems to work.
I wonder if its anything left over from my previous install as I copied the contents of /var/lib/openhab2 and /etc/openhab2 into the new machine before doing the install to preserve all my settings, which it did, and I expected the installer to get rid of everything it was replacing which is what I’ve seen it do in the past, however I have gone from a Pi3 to an intel chip running the amd64 build of Debian in case that’s relevant.
Do you have both network and exec bindings loaded?
Interestingly I just set the system location / language etc, and corrected a bad path in basic UI, and it rebooted cleanly, although I did get this instead
2018-01-17 20:28:16.000 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at https://null:8443
2018-01-17 20:28:15.995 [WARN ] [g.eclipse.smarthome.core.net.NetUtil] - Invalid address '192.168.xx.xx/24', will use first interface instead.
2018-01-17 20:28:15.993 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at http://null:8080
2018-01-17 20:28:123.123 [WARN ] [g.eclipse.smarthome.core.net.NetUtil] - Invalid address '192.168.123.123/24', will use first interface instead.
The address it said was invalid was in fact correct. I wonder if there is some ip6 weirdness going on
Further update, this seems to come and go. I cleared out the cache and tmp folders in case there was something lingering that shouldn’t be there, but the error still occasionally happens after a reboot. It may be my imagination, but it seemed to occur less often after I moved all the rules away on reboot and brought them back in stages once a known item had been initialised
Well, yes somehow… I don’t see the error anymore in my logfile but I haven’t changed the config (at least I’m not aware of). Sorry, that I cannot provide more details.
I did not change anything and I got this error too with the yeelight binding:
18:36:45.509 [WARN ] [fig.xml.osgi.XmlDocumentBundleTracker] - The XML document '/ESH-INF/binding/binding.xml' in module 'org.openhab.binding.yeelight' could not be parsed: The XmlConfigDescriptionProvider must not be null!
at org.eclipse.smarthome.core.binding.xml.internal.BindingInfoXmlProvider.<init>(BindingInfoXmlProvider.java:60) [116:org.eclipse.smarthome.core.binding.xml:0.10.0.b1]
at org.eclipse.smarthome.core.binding.xml.internal.XmlBindingInfoProvider.createDocumentProvider(XmlBindingInfoProvider.java:141) [116:org.eclipse.smarthome.core.binding.xml:0.10.0.b1]
at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker.acquireXmlDocumentProvider(XmlDocumentBundleTracker.java:181) [112:org.eclipse.smarthome.config.xml:0.10.0.b1]
at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker.addingObject(XmlDocumentBundleTracker.java:206) [112:org.eclipse.smarthome.config.xml:0.10.0.b1]
at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker.parseDocuments(XmlDocumentBundleTracker.java:350) [112:org.eclipse.smarthome.config.xml:0.10.0.b1]
at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker.processBundle(XmlDocumentBundleTracker.java:336) [112:org.eclipse.smarthome.config.xml:0.10.0.b1]
at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker.access$3(XmlDocumentBundleTracker.java:331) [112:org.eclipse.smarthome.config.xml:0.10.0.b1]
at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker$2.run(XmlDocumentBundleTracker.java:307) [112:org.eclipse.smarthome.config.xml:0.10.0.b1]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
Did you guys update Java? I think that is the only thing I did in the last couple days?..
The binding.xml looks okay to me:
<?xml version="1.0" encoding="UTF-8"?>
<binding:binding id="yeelight"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:binding="http://eclipse.org/smarthome/schemas/binding/v1.0.0"
xsi:schemaLocation="http://eclipse.org/smarthome/schemas/binding/v1.0.0 http://eclipse.org/smarthome/schemas/binding-1.0.0.xsd">
<name>Yeelight Binding</name>
<description>This is the binding for Yeelight product.</description>
<author>Coaster Li</author>
</binding:binding>
Big problem is that all of my lamps stopped working… that is a critical hit and my gf is quite upset and annoys me now…
Edit: Took about 2 hours to find and install an older java version (152) - but still not working. I do not receive that error anymore, but the lamps are still offline…
