Hi all,
after updating to Openhab version 2.2 I’m having issues with Homegear and Homematic.
I’m using the HM-MOD-RPI-PCB adapter on my Raspberry Pi 3, on version 2.0 everything works fine.
In PaperUI every Homematic device is online, but when I switch a light in basic UI nothing happens.
For me it looks like that receiving data from the devices to Homegear is working…
But sending from Openhab to Homegear and then to the devices isn’t?!
I hope you guys can help me… tried to summarise some infos, hope this helps…
If you need more logfiles let me know.
Matthias
Openhabian infos
Release = Raspbian GNU/Linux 8 (jessie)
## Kernel = Linux 4.9.35-v7+
## Platform = Raspberry Pi 3 Model B Rev 1.2
## openHAB 2.2.0-1 (Release Build)
IP address 10.10.203.2/24
Homegear Version
[16:57:31] openhabian@pi-openhab:~$ homegear -v
Homegear version 0.7.14-1563
Copyright (c) 2013-2017 Sathya Laufer
Git commit SHA of libhomegear-base: -
Git branch of libhomegear-base: -
Git commit SHA of Homegear: -
Git branch of Homegear: -
PHP (License: PHP License):
This product includes PHP software, freely available from <http://www.php.net/so ftware/>
Copyright (c) 1999-2017 The PHP Group. All rights reserved.
openhab.log
2018-01-24 17:32:43.809 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway '618eedaa' not available, disabling support
2018-01-24 17:32:43.818 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'HMIP' on gateway '618eedaa' not available, disabling support
2018-01-24 17:32:43.832 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway '618eedaa' not available, disabling support
2018-01-24 17:32:43.842 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'GROUP' on gateway '618eedaa' not available, disabling support
2018-01-24 17:32:44.061 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=HOMEGEAR,type=Homegear,firmware=0.7.14-1563,address=VBC1476541,wired=false,hmip=false,cuxd=false,group=false]
2018-01-24 17:33:00.838 [ERROR] [ematic.handler.HomematicThingHandler] - -100 No answer from device. (sending setValue()
OEQ0243032:4
MANU_MODE
15.0
java.io.IOException: -100 No answer from device. (sending setValue()
OEQ0243032:4
MANU_MODE
15.0
at org.openhab.binding.homematic.internal.communicator.parser.RpcResponseParser.parse(RpcResponseParser.java:47) [251:org.openhab.binding.homematic:2.2.0]
at org.openhab.binding.homematic.internal.communicator.client.BinRpcClient.sendMessage(BinRpcClient.java:78) [251:org.openhab.binding.homematic:2.2.0]
at org.openhab.binding.homematic.internal.communicator.client.BinRpcClient.sendMessage(BinRpcClient.java:90) [251:org.openhab.binding.homematic:2.2.0]
at org.openhab.binding.homematic.internal.communicator.client.BinRpcClient.sendMessage(BinRpcClient.java:66) [251:org.openhab.binding.homematic:2.2.0]
at org.openhab.binding.homematic.internal.communicator.client.RpcClient.setDatapointValue(RpcClient.java:293) [251:org.openhab.binding.homematic:2.2.0]
at org.openhab.binding.homematic.internal.communicator.AbstractHomematicGateway$1.execute(AbstractHomematicGateway.java:571) [251:org.openhab.binding.homematic:2.2.0]
at org.openhab.binding.homematic.internal.misc.DelayedExecuter.start(DelayedExecuter.java:61) [251:org.openhab.binding.homematic:2.2.0]
at org.openhab.binding.homematic.internal.communicator.AbstractHomematicGateway.sendDatapoint(AbstractHomematicGateway.java:550) [251:org.openhab.binding.homematic:2.2.0]
at org.openhab.binding.homematic.internal.communicator.AbstractHomematicGateway.sendDatapoint(AbstractHomematicGateway.java:529) [251:org.openhab.binding.homematic:2.2.0]
at org.openhab.binding.homematic.handler.HomematicThingHandler.handleCommand(HomematicThingHandler.java:175) [251:org.openhab.binding.homematic:2.2.0]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) [109:org.eclipse.smarthome.core:0.10.0.b1]
at org.eclipse.smarthome.core.internal.common.InvocationHandlerSync.invoke(InvocationHandlerSync.java:59) [109:org.eclipse.smarthome.core:0.10.0.b1]
at com.sun.proxy.$Proxy159.handleCommand(Unknown Source) [251:org.openhab.binding.homematic:2.2.0]
at org.eclipse.smarthome.core.thing.internal.profiles.ProfileCallbackImpl.handleCommand(ProfileCallbackImpl.java:72) [116:org.eclipse.smarthome.core.thing:0.10.0.b1]
at org.eclipse.smarthome.core.thing.internal.profiles.SystemDefaultProfile.onCommandFromItem(SystemDefaultProfile.java:49) [116:org.eclipse.smarthome.core.thing:0.10.0.b1]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) [109:org.eclipse.smarthome.core:0.10.0.b1]
events.log while switching a homatic device in basicUI
2018-01-24 17:33:10.821 [hingStatusInfoChangedEvent] - 'homematic:HG-HM-CC-RT-DN:618eedaa:OEQ0243032' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR)
2018-01-24 17:33:11.794 [hingStatusInfoChangedEvent] - 'homematic:HG-HM-CC-RT-DN:618eedaa:OEQ0243032' changed from OFFLINE (COMMUNICATION_ERROR) to ONLINE
2018-01-24 17:33:12.031 [me.event.ThingUpdatedEvent] - Thing 'homematic:HG-HM-CC-RT-DN:618eedaa:OEQ0243032' has been updated.
homegear -r
[17:45:54] openhabian@pi-openhab:~$ homegear -r
Connected to Homegear (version 0.7.14-1563).
> families list
ID │ Name
0 │ HomeMatic BidCoS
254 │ Miscellaneous
> families select 0
Device family "HomeMatic BidCoS" selected.
For information about the family's commands type: "help"
(Family)> ls
ID │ Name │ Address │ Serial Number │ Type │ Type String │ Firmware │ Config Pending │ Unreach │ Low Bat
1 │ Dachgeschoss Büro │ 51A01D │ NEQ1489970 │ 0095 │ HM-CC-RT-DN │ 1.4 │ No │ No │ No
2 │ Dachgeschoss Badezimmer │ 51A00C │ NEQ1489987 │ 0095 │ HM-CC-RT-DN │ 1.4 │ No │ No │ No
3 │ Dachgeschoss Küche │ 51A018 │ NEQ1489977 │ 0095 │ HM-CC-RT-DN │ 1.4 │ No │ No │ No
4 │ Dachgeschoss Schlafzimmer │ 51A005 │ NEQ1489985 │ 0095 │ HM-CC-RT-DN │ 1.4 │ No │ No │ No
5 │ Dachgeschoss Wohnzimme... │ 51A985 │ NEQ1488399 │ 0095 │ HM-CC-RT-DN │ 1.4 │ No │ No │ No
6 │ Dachgeschoss Wohnzimme... │ 51A9B7 │ NEQ1488386 │ 0095 │ HM-CC-RT-DN │ 1.4 │ No │ No │ No
7 │ Erdgeschoss Badezimmer │ 569AD2 │ OEQ0243032 │ 0095 │ HM-CC-RT-DN │ 1.4 │ No │ No │ No
8 │ Erdgeschoss Wohnzimmer... │ 567BFE │ OEQ0242336 │ 0095 │ HM-CC-RT-DN │ 1.4 │ No │ No │ No
9 │ Erdgeschoss Wohnzimmer... │ 567C00 │ OEQ0242338 │ 0095 │ HM-CC-RT-DN │ 1.4 │ No │ No │ No
10 │ Erdgeschoss Wohnzimmer... │ 567C01 │ OEQ0242339 │ 0095 │ HM-CC-RT-DN │ 1.4 │ No │ No │ No
11 │ Erdgeschoss Hauswirtsc... │ 567C04 │ OEQ0242342 │ 0095 │ HM-CC-RT-DN │ 1.4 │ No │ No │ No
12 │ Kellergeschoss Fittnes... │ 567C4A │ OEQ0242362 │ 0095 │ HM-CC-RT-DN │ 1.4 │ No │ No │ No
13 │ Dachgeschoss Wohnzimme... │ 5A0CF6 │ OEQ0473427 │ 0069 │ HM-LC-Sw1PBU-FM │ 2.8 │ No │ No │ No
14 │ Dachgeschoss Esszimmer... │ 4ADE1A │ NEQ0389308 │ 0068 │ HM-LC-Dim1TPBU-FM │ 2.9 │ No │ No │ No
(Family)>
homegear.log
01/24/18 17:24:00.359 Starting Homegear...
01/24/18 17:24:00.359 Homegear version 0.7.14-1563
01/24/18 17:24:00.359 Git commit SHA of libhomegear-base: -
01/24/18 17:24:00.359 Git branch of libhomegear-base: -
01/24/18 17:24:00.359 Git commit SHA of Homegear: -
01/24/18 17:24:00.359 Git branch of Homegear: -
01/24/18 17:24:00.361 Info: Setting allowed core file size to "4294967295" for user with id 0 and group with id 0.
01/24/18 17:24:00.361 Info: Core file size now is "4294967295".
01/24/18 17:24:00.361 Info: Setting maximum thread priority to "4294967295" for user with id 0 and group with id 0.
01/24/18 17:24:00.361 Info: Maximum thread priority now is "4294967295".
01/24/18 17:24:00.439 Info: Backing up database...
01/24/18 17:24:00.683 Initializing database...
01/24/18 17:24:00.687 Info: Loading family module mod_miscellaneous.so
01/24/18 17:24:00.691 /etc/homegear/families/miscellaneous.conf
01/24/18 17:24:00.691 Info: Loading family module mod_homematicbidcos.so
01/24/18 17:24:00.703 /etc/homegear/families/homematicbidcos.conf
01/24/18 17:24:00.705 Info: Loading family module mod_homematicwired.so
01/24/18 17:24:00.710 /etc/homegear/families/homematicwired.conf
01/24/18 17:24:00.711 Info: Setting up physical interfaces and GPIOs...
01/24/18 17:24:00.712 Info: Dropping privileges to user homegear (110) and group homegear (116)
01/24/18 17:24:00.713 Info: Homegear is (now) running as user with id 110 and group with id 116.
01/24/18 17:24:00.719 Starting script engine server...
01/24/18 17:24:00.727 Initializing licensing controller...
01/24/18 17:24:00.727 Loading licensing controller data...
01/24/18 17:24:00.727 Loading devices...
01/24/18 17:24:00.728 Loading XML RPC devices...
01/24/18 17:24:01.891 Loading device 2
01/24/18 17:24:01.891 Module HomeMatic BidCoS: Info: Central address set to 0xFD7392.
01/24/18 17:24:01.892 Module HomeMatic BidCoS: Loading peer 1
01/24/18 17:24:01.910 Module HomeMatic BidCoS: Loading peer 2
01/24/18 17:24:01.926 Module HomeMatic BidCoS: Loading peer 3
01/24/18 17:24:01.943 Module HomeMatic BidCoS: Loading peer 4
01/24/18 17:24:01.959 Module HomeMatic BidCoS: Loading peer 5
01/24/18 17:24:01.976 Module HomeMatic BidCoS: Loading peer 6
01/24/18 17:24:01.994 Module HomeMatic BidCoS: Loading peer 7
01/24/18 17:24:02.011 Module HomeMatic BidCoS: Loading peer 8
01/24/18 17:24:02.029 Module HomeMatic BidCoS: Loading peer 9
01/24/18 17:24:02.047 Module HomeMatic BidCoS: Loading peer 10
01/24/18 17:24:02.065 Module HomeMatic BidCoS: Loading peer 11
01/24/18 17:24:02.083 Module HomeMatic BidCoS: Loading peer 12
01/24/18 17:24:02.101 Module HomeMatic BidCoS: Loading peer 13
01/24/18 17:24:02.112 Module HomeMatic BidCoS: Loading peer 14
01/24/18 17:24:02.154 Info: Not initializing device family HomeMatic Wired, because no physical interface was found.
01/24/18 17:24:02.154 Info: Disposing family module mod_homematicwired.so
01/24/18 17:24:02.154 Loading XML RPC devices...
01/24/18 17:24:02.158 Loading device 1
01/24/18 17:24:02.158 Initializing RPC client...
01/24/18 17:24:02.158 Starting XML RPC server RPCServer1 listening on :::2001...
01/24/18 17:24:02.162 Starting XML RPC server RPCServer2 listening on :::2002, SSL enabled...
01/24/18 17:24:02.162 RPC Server (Port 2001): Info: RPC Server started listening on address :: and port 2001
01/24/18 17:24:02.195 Starting XML RPC server RPCServer3 listening on :::2003, SSL enabled, authentication enabled...
01/24/18 17:24:02.195 RPC Server (Port 2002): Info: RPC Server started listening on address :: and port 2002
01/24/18 17:24:02.227 Starting CLI server...
01/24/18 17:24:02.227 RPC Server (Port 2003): Info: RPC Server started listening on address :: and port 2003
01/24/18 17:24:02.227 Initializing event handler...
01/24/18 17:24:02.227 Loading events...
01/24/18 17:24:02.228 Starting flows server...
01/24/18 17:24:02.233 Starting IPC server...
01/24/18 17:24:02.238 Start listening for packets...
01/24/18 17:24:04.239 Startup complete. Waiting for physical interfaces to connect.
01/24/18 17:24:04.240 All physical interfaces are connected now.
01/24/18 17:24:04.240 Starting UPnP server...
01/24/18 17:24:04.242 Info: UPnP server: Binding to address: 10.10.203.2
01/24/18 17:24:04.242 UPnP Server: Info: Started listening.
01/24/18 17:24:06.681 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Info: Firmware version: 1.2.1
01/24/18 17:24:06.688 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Info: Serial number: NEQ1332224
01/24/18 17:24:06.704 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Info: Init queue completed. Sending peers...
01/24/18 17:24:07.067 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Info: Peer sending completed.
01/24/18 17:24:16.466 HomeMatic BidCoS packet received (My-HM-MOD-RPI-PCB, RSSI: -49 dBm): 0FD78610567BFE0000000A9CBB0B4100
01/24/18 17:24:16.467 Module HomeMatic BidCoS: Info: ACTUAL_TEMPERATURE on channel 4 of HomeMatic BidCoS peer 8 with serial number OEQ0242336 was set to 0x00BB.
01/24/18 17:24:16.468 Module HomeMatic BidCoS: Info: BATTERY_STATE on channel 4 of HomeMatic BidCoS peer 8 with serial number OEQ0242336 was set to 0x0B.
01/24/18 17:24:16.468 Module HomeMatic BidCoS: Info: BOOST_STATE on channel 4 of HomeMatic BidCoS peer 8 with serial number OEQ0242336 was set to 0x00.
01/24/18 17:24:16.468 Module HomeMatic BidCoS: Info: CONTROL_MODE on channel 4 of HomeMatic BidCoS peer 8 with serial number OEQ0242336 was set to 0x00.
01/24/18 17:24:16.468 Module HomeMatic BidCoS: Info: FAULT_REPORTING on channel 4 of HomeMatic BidCoS peer 8 with serial number OEQ0242336 was set to 0x00.
01/24/18 17:24:16.503 Module HomeMatic BidCoS: Info: PARTY_START_TIME on channel 4 of HomeMatic BidCoS peer 8 with serial number OEQ0242336 was set to 0x00.
01/24/18 17:24:16.503 Module HomeMatic BidCoS: Info: VALVE_STATE on channel 4 of HomeMatic BidCoS peer 8 with serial number OEQ0242336 was set to 0x41.
01/24/18 17:24:17.444 HomeMatic BidCoS packet received (My-HM-MOD-RPI-PCB, RSSI: -48 dBm): 0F2A861051A00C0000000A88B20A0040
01/24/18 17:24:17.445 Module HomeMatic BidCoS: Info: ACTUAL_TEMPERATURE on channel 4 of HomeMatic BidCoS peer 2 with serial number NEQ1489987 was set to 0x00B2.
01/24/18 17:24:17.445 Module HomeMatic BidCoS: Info: BATTERY_STATE on channel 4 of HomeMatic BidCoS peer 2 with serial number NEQ1489987 was set to 0x0A.
01/24/18 17:24:17.445 Module HomeMatic BidCoS: Info: BOOST_STATE on channel 4 of HomeMatic BidCoS peer 2 with serial number NEQ1489987 was set to 0x00.
01/24/18 17:24:17.445 Module HomeMatic BidCoS: Info: CONTROL_MODE on channel 4 of HomeMatic BidCoS peer 2 with serial number NEQ1489987 was set to 0x01.
01/24/18 17:24:17.445 Module HomeMatic BidCoS: Info: FAULT_REPORTING on channel 4 of HomeMatic BidCoS peer 2 with serial number NEQ1489987 was set to 0x00.
01/24/18 17:24:17.469 Module HomeMatic BidCoS: Info: PARTY_START_TIME on channel 4 of HomeMatic BidCoS peer 2 with serial number NEQ1489987 was set to 0x00.
01/24/18 17:24:17.469 Module HomeMatic BidCoS: Info: SET_TEMPERATURE on channel 4 of HomeMatic BidCoS peer 2 with serial number NEQ1489987 was set to 0x22.
01/24/18 17:24:17.469 Module HomeMatic BidCoS: Info: VALVE_STATE on channel 4 of HomeMatic BidCoS peer 2 with serial number NEQ1489987 was set to 0x00.
01/24/18 17:24:28.002 HomeMatic BidCoS packet received (My-HM-MOD-RPI-PCB, RSSI: -46 dBm): 0F1A861051A9B70000000A88A90D1740
01/24/18 17:32:26.421 Module HomeMatic BidCoS: Info: ACTUAL_TEMPERATURE on channel 4 of HomeMatic BidCoS peer 1 with serial number NEQ1489970 was set to 0x00AB.
01/24/18 17:32:26.421 Module HomeMatic BidCoS: Info: BATTERY_STATE on channel 4 of HomeMatic BidCoS peer 1 with serial number NEQ1489970 was set to 0x0A.
01/24/18 17:32:26.422 Module HomeMatic BidCoS: Info: BOOST_STATE on channel 4 of HomeMatic BidCoS peer 1 with serial number NEQ1489970 was set to 0x00.
01/24/18 17:32:26.422 Module HomeMatic BidCoS: Info: CONTROL_MODE on channel 4 of HomeMatic BidCoS peer 1 with serial number NEQ1489970 was set to 0x00.
01/24/18 17:32:26.422 Module HomeMatic BidCoS: Info: FAULT_REPORTING on channel 4 of HomeMatic BidCoS peer 1 with serial number NEQ1489970 was set to 0x00.
01/24/18 17:32:26.422 Module HomeMatic BidCoS: Info: PARTY_START_TIME on channel 4 of HomeMatic BidCoS peer 1 with serial number NEQ1489970 was set to 0x00.
01/24/18 17:32:26.422 Module HomeMatic BidCoS: Info: SET_TEMPERATURE on channel 4 of HomeMatic BidCoS peer 1 with serial number NEQ1489970 was set to 0x22.
01/24/18 17:32:26.422 Module HomeMatic BidCoS: Info: VALVE_STATE on channel 4 of HomeMatic BidCoS peer 1 with serial number NEQ1489970 was set to 0x07.
01/24/18 17:32:43.693 RPC Server (Port 2001): Info: Connection from ::ffff:127.0.0.1:50956 accepted. Client number: 13
01/24/18 17:32:43.693 RPC Server (Port 2001): Info: RPC server client id for client number 13 is: 0
01/24/18 17:32:43.695 RPC Server (Port 2001): Info: Client number 13 is calling RPC method: getDeviceDescription (1) Parameters:
(String) BidCoS-RF
01/24/18 17:32:43.760 RPC Server (Port 2001): Info: Connection from ::ffff:127.0.0.1:50960 accepted. Client number: 14
01/24/18 17:32:43.761 RPC Server (Port 2001): Info: RPC server client id for client number 14 is: 1
01/24/18 17:32:43.765 RPC Server (Port 2001): Info: Client number 14 is calling RPC method: listBidcosInterfaces (1) Parameters:
01/24/18 17:32:44.092 RPC Server (Port 2001): Info: Connection from ::ffff:127.0.0.1:50982 accepted. Client number: 15
01/24/18 17:32:44.092 RPC Server (Port 2001): Info: RPC server client id for client number 15 is: 2
01/24/18 17:32:44.094 RPC Server (Port 2001): Info: Client number 15 is calling RPC method: init (2) Parameters:
(String) binary://10.10.203.2:9126
(String) RF-618eedaa
01/24/18 17:32:44.094 Info: Client with IP ::ffff:127.0.0.1 is calling "init".
01/24/18 17:32:44.095 Info: Adding server "binary://10.10.203.2".
01/24/18 17:32:44.095 Info: Calling init methods on server "binary://10.10.203.2".
01/24/18 17:32:44.107 RPC Server (Port 2001): Info: Connection from ::ffff:127.0.0.1:50984 accepted. Client number: 16
01/24/18 17:32:44.107 RPC Server (Port 2001): Info: RPC server client id for client number 16 is: 3
01/24/18 17:32:44.108 RPC Server (Port 2001): Info: Client number 16 is calling RPC method: listDevices (2) Parameters:
01/24/18 17:32:44.235 RPC Server (Port 2001): Info: Client number 16 is calling RPC method: getDeviceInfo (2) Parameters:
01/24/18 17:32:44.299 RPC Server (Port 2001): Info: Client number 16 is calling RPC method: getParamsetDescription (2) Parameters:
(String) NEQ0389308:0
(String) MASTER
01/24/18 17:32:44.314 RPC Server (Port 2001): Info: Client number 16 is calling RPC method: getParamsetDescription (2) Parameters:
(String) VALUES
01/24/18 17:32:44.320 RPC Server (Port 2001): Info: Client number 16 is calling RPC method: getParamsetDescription (2) Parameters:
(String) NEQ0389308:1
(String) MASTER
01/24/18 17:32:45.283 RPC Server (Port 2001): Info: Client number 16 is calling RPC method: getParamsetDescription (2) Parameters:
(String) OEQ0473427:1
(String) VALUES
01/24/18 17:32:45.299 RPC Server (Port 2001): Info: Client number 16 is calling RPC method: getAllSystemVariables (2) Parameters:
01/24/18 17:32:45.314 RPC Server (Port 2001): Info: Client number 16 is calling RPC method: getAllScripts (2) Parameters:
01/24/18 17:32:45.457 RPC Server (Port 2001): Info: Client number 16 is calling RPC method: getParamset (2) Parameters:
(String) OEQ0242339:0
(String) MASTER
01/24/18 17:32:45.483 RPC Server (Port 2001): Info: Client number 16 is calling RPC method: getParamset (2) Parameters:
(String) OEQ0242336:0
(String) MASTER
01/24/18 17:32:45.491 RPC Server (Port 2001): Info: Client number 16 is calling RPC method: getParamset (2) Parameters:
(String) MASTER
01/24/18 17:32:45.495 RPC Server (Port 2001): Info: Client number 16 is calling RPC method: getParamset (2) Parameters:
01/24/18 17:32:47.051 RPC Server (Port 2001): Info: Client number 16 is calling RPC method: getParamset (2) Parameters:
(String) NEQ1489977:0
(String) VALUES
01/24/18 17:32:47.075 HomeMatic BidCoS packet received (My-HM-MOD-RPI-PCB, RSSI: -48 dBm): 0F4C861051A9850000000A88AB0D0640
01/24/18 17:32:47.076 Module HomeMatic BidCoS: Info: ACTUAL_TEMPERATURE on channel 4 of HomeMatic BidCoS peer 5 with serial number NEQ1488399 was set to 0x00AB.
01/24/18 17:32:47.077 Module HomeMatic BidCoS: Info: BATTERY_STATE on channel 4 of HomeMatic BidCoS peer 5 with serial number NEQ1488399 was set to 0x0D.
01/24/18 17:32:47.077 Module HomeMatic BidCoS: Info: BOOST_STATE on channel 4 of HomeMatic BidCoS peer 5 with serial number NEQ1488399 was set to 0x00.
01/24/18 17:32:47.077 Module HomeMatic BidCoS: Info: CONTROL_MODE on channel 4 of HomeMatic BidCoS peer 5 with serial number NEQ1488399 was set to 0x01.
01/24/18 17:32:47.077 Module HomeMatic BidCoS: Info: FAULT_REPORTING on channel 4 of HomeMatic BidCoS peer 5 with serial number NEQ1488399 was set to 0x00.
01/24/18 17:32:47.077 Module HomeMatic BidCoS: Info: PARTY_START_TIME on channel 4 of HomeMatic BidCoS peer 5 with serial number NEQ1488399 was set to 0x00.
01/24/18 17:32:47.077 Module HomeMatic BidCoS: Info: SET_TEMPERATURE on channel 4 of HomeMatic BidCoS peer 5 with serial number NEQ1488399 was set to 0x22.
01/24/18 17:32:47.077 Module HomeMatic BidCoS: Info: VALVE_STATE on channel 4 of HomeMatic BidCoS peer 5 with serial number NEQ1488399 was set to 0x06.
01/24/18 17:32:47.096 RPC Server (Port 2001): Info: Client number 16 is calling RPC method: getParamset (2) Parameters:
(String) NEQ1489977:1
(String) MASTER
01/24/18 17:32:47.099 RPC Server (Port 2001): Info: Client number 16 is calling RPC method: getParamset (2) Parameters:
(String) VALUES
01/24/18 17:32:47.103 RPC Server (Port 2001): Info: Client number 16 is calling RPC method: getParamset (2) Parameters:
(String) NEQ1489977:2
(String) MASTER
01/24/18 17:32:49.511 RPC Server (Port 2001): Info: Client number 16 is calling RPC method: getParamset (2) Parameters:
(String) NEQ1489987:6
(String) MASTER
01/24/18 17:32:49.515 RPC Server (Port 2001): Info: Client number 16 is calling RPC method: getParamset (2) Parameters:
(String) VALUES
01/24/18 17:32:55.679 RPC Server (Port 2001): Info: Client number 16 is calling RPC method: setValue (2) Parameters:
(String) OEQ0243032:4
(String) MANU_MODE
(Float) 15
01/24/18 17:32:57.032 HomeMatic BidCoS packet received (My-HM-MOD-RPI-PCB, RSSI: -63 dBm): 0FE98610567C040000000A90AD0B2000
01/24/18 17:32:57.033 Module HomeMatic BidCoS: Info: ACTUAL_TEMPERATURE on channel 4 of HomeMatic BidCoS peer 11 with serial number OEQ0242342 was set to 0x00AD.
01/24/18 17:32:57.033 Module HomeMatic BidCoS: Info: BATTERY_STATE on channel 4 of HomeMatic BidCoS peer 11 with serial number OEQ0242342 was set to 0x0B.
01/24/18 17:32:57.033 Module HomeMatic BidCoS: Info: BOOST_STATE on channel 4 of HomeMatic BidCoS peer 11 with serial number OEQ0242342 was set to 0x00.
01/24/18 17:32:57.033 Module HomeMatic BidCoS: Info: CONTROL_MODE on channel 4 of HomeMatic BidCoS peer 11 with serial number OEQ0242342 was set to 0x00.
01/24/18 17:32:57.033 Module HomeMatic BidCoS: Info: FAULT_REPORTING on channel 4 of HomeMatic BidCoS peer 11 with serial number OEQ0242342 was set to 0x00.
01/24/18 17:32:57.034 Module HomeMatic BidCoS: Info: PARTY_START_TIME on channel 4 of HomeMatic BidCoS peer 11 with serial number OEQ0242342 was set to 0x00.
01/24/18 17:32:57.034 Module HomeMatic BidCoS: Info: VALVE_STATE on channel 4 of HomeMatic BidCoS peer 11 with serial number OEQ0242342 was set to 0x20.
01/24/18 17:32:58.255 RPC Server (Port 2001): Info: Connection from ::ffff:127.0.0.1:51240 accepted. Client number: 25
01/24/18 17:32:58.255 RPC Server (Port 2001): Info: RPC server client id for client number 25 is: 4
01/24/18 17:32:58.256 RPC Server (Port 2001): Info: Client number 25 is calling RPC method: setValue (2) Parameters:
(String) MANU_MODE
(Float) 15
01/24/18 17:33:00.843 RPC Server (Port 2001): Info: Client number 25 is calling RPC method: setValue (2) Parameters:
(String) OEQ0242336:4
(String) MANU_MODE
(Float) 15
01/24/18 17:33:01.392 Module HomeMatic BidCoS: Info: Setting peer to unreachable, because the queue processing was interrupted.
01/24/18 17:33:01.392 Module HomeMatic BidCoS: Info: Queue is not finished (peer: 7). Retrying...
01/24/18 17:33:03.414 RPC Server (Port 2001): Info: Connection from ::ffff:127.0.0.1:51290 accepted. Client number: 26
01/24/18 17:33:03.414 RPC Server (Port 2001): Info: RPC server client id for client number 26 is: 5
01/24/18 17:33:03.415 RPC Server (Port 2001): Info: Client number 26 is calling RPC method: setValue (2) Parameters:
(String) MANU_MODE
(Float) 15
01/24/18 17:33:04.399 Module HomeMatic BidCoS: Info: Setting peer to unreachable, because the queue processing was interrupted.
01/24/18 17:33:04.399 Module HomeMatic BidCoS: Info: Queue is not finished (peer: 7). Retrying...
01/24/18 17:33:05.988 RPC Server (Port 2001): Info: Client number 26 is calling RPC method: setValue (2) Parameters:
(String) OEQ0242338:4
(String) MANU_MODE
(Float) 15
01/24/18 17:33:06.503 Module HomeMatic BidCoS: Info: Setting peer to unreachable, because the queue processing was interrupted.
01/24/18 17:33:06.504 Module HomeMatic BidCoS: Info: Queue is not finished (peer: 8). Retrying...
01/24/18 17:33:07.606 Module HomeMatic BidCoS: Info: Setting peer to unreachable, because the queue processing was interrupted.
01/24/18 17:33:07.606 Module HomeMatic BidCoS: Info: Queue is not finished (peer: 7). Retrying...
01/24/18 17:33:08.553 RPC Server (Port 2001): Info: Connection from ::ffff:127.0.0.1:51340 accepted. Client number: 27
01/24/18 17:33:08.554 RPC Server (Port 2001): Info: RPC server client id for client number 27 is: 6
01/24/18 17:33:08.554 RPC Server (Port 2001): Info: Client number 27 is calling RPC method: setValue (2) Parameters:
(String) MANU_MODE
(Float) 15
