I just installed OH2.2 onto QNAP nas, i adddd the LG webos bindings, but my two webos tvs cannot be discovered.
The TVs are on wifi but on the same network.
I added the ip in the paperui / config / settings / network part.
I also added a wlan stick into the qnap nas and changed the ip to this one , same nothing.
Do you have any glue?
One tv is an LF592U 3.21.05 sw version
the second is: LB671 with 5. sw version
none can be discovered
@ewok, when that happens to me, I review the basics as it fixes 80% of my problems:
1- Can the openHAB computer ping the TV
2- You need the TV turned on for it to be discoverable
3- A message will pop up on screen when being discovered ans you have to accept the connection
4- Use wired connections if you can
I try and use wired connection for everything I have in the system as it is much more reliable.
Reply
For me the binding works very unreliably. TV was discovered and working but goes online/offline for no reason I could determine so far. Usually when it works it works ok for a long time. But, frequently, the next time I switch the TV on it is shown to be offline. No method found to get it back working without restarting openhab.
